No air from vents??
No air from vents??
Hey everyone!
I have done a lot of reading and searching this far but have come up empty handed still. So this morning I went out to go to work and go and behold went to turn ac on and no air coming through the vents. So I tried all the different settings. I have the electronic controlled system. So I kept trying on the way to work. I can hear the ac compressor engage but nothing. So after a few hours I go out and try again. Nothing still. Once I left work, it worked no problem. While driving home they just stopped working again out of no where. I checked some fuses and they look fine. Can someone please direct me to the right place as to what to look for?! Any input is appreciated!
Thank you.
Thank you.
with the auto climate control the blower motor resistors go bad, some replace both the resistor and fan motor since sometimes the high resistance in the motor takes out the resistor.
you can try just the resistor but it is expensive so some bite the bullet and do both just in case it gets knocked out again.
if you are not getting air anywhere when you hit different modes, such as the floor, vent or the dash, then the possibilities are the blower motor, fuse/ relay. Suggestion would be take the blower motor out and check it from your battery and wire to the connection and see if the motor spin, if it does then it quite possibly the relay or fuse. Otherwise, Resistor usually quit working, if you only have one speed such as Hi fan speed.
Hi everyone. Just to revisit this post. I replaced the resistor a while back and all was well. Vents began working again. Today all of a sudden while driving the vents stopped working again. This time I notice the ac compressor doesn't engage when I select the option. Any ideas as to what the issue is? What fuses/relays should I check? Thanks for any and all replies!
Fuse # 19 powers the control panel. Middle row, 2nd from right end, 10 amp.
There are 2 fuses (15 amp) in the under hood fuse panel. The cover is labeled BLOWER MTR. But if these are blown, the compressor should still run unless...
Are you aware that if the outside temperature is below 35º F, the a/c compressor will not run? But you should still have air blowing out of the dash vents.
Thanks for the reply! I didn't think about the compressor not running under 35 degrees until after the fact and it makes sense as it was in the negatives yeaterday. My vents began working again last night randomly and have been working all day today.. I'm not sure what it was/is but I'll continue to monitor or it. Thanks a lot for the re
Hey everyone. Well the issue continues. The vents work at random for a while then go back out. I tried swapping out the resistor again and checking fuses and relays. Any ideas as to what else it may be? Thanks in advance!
Thanks again. I've tried messing with the blower motor a bit with no luck. It still works when it wants though it is much less than it was. I hear a noticeable noise when it does work coming from the motor area. I'm thinking of just replacing the motor this weekend and see if it's the culprit.
Hey everyone. Just needed a little help and was wondering if anyone can advise me as to which blower motor I need. http://shop.advanceautoparts.com/c3/blower-motors/15907?isAllVehicle=false&showTitle=&vehicleIdFromR eq=-1&vehicleIdSearch=49917
There are three to choose from and I don't want to by the wrong part. Any help is appreciated!
All three of those would fit. But the top one does not come with the squirrel cage and I have not been able to remove one from the old fan.
I have used the TYC brand on 2 cars and they fit and worked fine. I just don't understand why advanced auto is charging 3 times the price for the TYC blower motor. It's $34.79 + shipping on rockauto.com and $40.46 on amazon.com including shipping.
similar issue
i think i am having a similar problem. My blower motor only comes on sometimes. I can hear it moving position when i switch it to different vents but it won't come on only randomly, but when it is on it works perfectly fine. Im having the same issue with my sunroof. The switch that opens it fully only works sometimes but the switch that moves it up and down always works. Are these related possibly?
^ Ill add to this list of this issue as well. My fan speeds work selectively as well. Odd thing i have noticed is When i do get it to work off a fresh "restart" of the car...once i turn the fan off (say it gets too cold and i turn it off) if needing to turn it on again it never seems to work until the car is turned off and restarted again. This has happened few times...
just weird.
just weird.
just weird.
just weird.
The 3 relays form a triangle, 2 on top one down. Of the the 2 on top, the one towards the side of the car is the blower motor relay. You can swap it with the relay below it.
It sounds like you need a new blower motor. The brushes in the motor are probably worn out and make intermittent contact.
As for the sunroof, the motor itself is probably OK because there is only one motor that moves the glass. So either the switch in the control panel is bad or the limit switch for movement is bad. But if the limit switch is bad, you may have to replace the motor because it is built into the assembly that is the motor.
I don't think your 2 problems are related. You have 2 separate problems.
IF you have the electronic climate control, there is a way to go in as a "test mode" and it should tell you exactly what it wrong with itself. It's all in the FSM which is around here somewhere.
go into test mode by holding the off button for five seconds within five seconds of turning the key
tarun900
19
12-20-2021 06:57 PM
