p0305?
p0305?
Ok i have been chasing this problem for the longest, finally got it to throw a code.p0335 crankshaft position sensor circuit. I replaced the sensor and the car still throwing the code,bucking and shutting off at times. cars also running really rough. Any suggestions? thanks in advance
A bad crank sensor does not cause those symptoms, afaik. Maybe one of the cam sensors is bad. Cam sensors are known to go bad, of course. Maybe the replacement sensor is bad, too?
Ok I found a dead coil was my problem for the rough idle. Replaced the coil and now that problem I s fix. But I'm still getting the crank sensor code and the car starts breaking up at around 4500-5000 rpm. Anything below that car seems to run fine. I'm all out of suggestions.
metalgod3082
01-22-2013 04:40 PM
kevinoseguera99
18
08-18-2010 04:45 PM
