O2 thread chaser experience?
Old 08-30-2014, 09:09 PM
Unclejunebug's Avatar
Anyone ever used one of these?
http://www.autozone.com/autozone/acc...er=607067_0_0_
Over the past week I replaced all but the secondary bank 1 O2 sensor, which I replaced some time ago. I realized I didn't use any anti-seize on it so I removed it to put some on. The sensor did not come out easily and several of the threads were all messed up. I'm going to order a new one but I assume I'll need to use one of these thread chasers before installing the new sensor. I've just never used one of these and have no experience with them.
Are they really as easy to use as they sound?
Unclejunebug is offline
Old 08-31-2014, 03:36 AM
Black Lion
maxprivate's Avatar
Just use the proper socket and have good leverage when using it. These just basically retab the threads so they are correct/repaired for the new sensor. If the threads are damaged, that is what you need. Make sure its the right re-thread tool.
maxprivate is offline
Old 08-31-2014, 05:28 PM
Yeah, I'll need to clean out the bung threads before installing the new sensor for sure so I think this is exactly what I need.
I've considered replacing the sensor with a Bosch universal but I'd prefer to have the Bosch OEM fit replacement with the wire and connector. The only problem is I'd have to order the OEM fit sensor and wait until Thursday or so for shipping. Any reason I couldn't plug the bung after re-threading and drive the car? I'm sure my SES light would come on but that's to be expected. I don't think the downstream sensors control anything air/fuel ratio wise.
Old 08-31-2014, 06:55 PM
Rit
Rit's Avatar
You should be fine.
Rit is offline
Old 09-01-2014, 06:20 AM
Black Lion
maxprivate's Avatar
Old 09-01-2014, 06:36 PM
The thread chaser worked like a charm and the new sensor went in like butter. Ended up using the Bosch universal but it should be fine.
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
HOKUSMAX
11-13-2017 04:34 AM
MaxLvr21
10-17-2015 12:11 PM
Pied
09-26-2015 03:29 PM
Quick Reply: O2 thread chaser experience?
