Help! No reverse after solenoid change!!!!
So I had to replace the solenoid pack in transmission. Everything went great, not a bad job at all. Car runs and drives fine but I have NO reverse.. What did I do wrong?
27 views and no help? Lol. Update.... Disconnects battery to reset all computers. Checked fluid level and fluid is low. Picking up fluid tomorrow to fill it up. Hopefully that's it. Any other suggestion will be appreciated! Thanks!
^You done FuUCCKed up. It could be all your fault or just luck.
put the old one in see if you get reverse if you do then send the new one back.
China part?
Also on the reverse drum there are plastic oil rings that if they let oil through you will lose revers.
check those that they are not crushed or cracked.
China part?
Although its not a solution to the problem, I had a similar issue when replacing my stock valvebody with a modded Maxxtuning Stage 2 valve body. I put my stock solenoids into the maxxtuning VB only to find that I didn't have DRIVE. Never found a solution because in was too frustrated at the time. Did you get any codes? When my car didn't have drive, I had codes PO745 and PO740. You might have to reseat the solenoids again.
James92SE
142
01-02-2024 09:23 AM
RWCreative
09-21-2015 11:01 AM
lrb6805
09-17-2015 04:49 PM
