P0335 - Interesting issue
Old 10-18-2014, 07:28 AM
ateick's Avatar
Well as you may know I struggled with a bad flywheel after a MT swap. Thursday I replaced it with a new Luk model from RockAuto. When I had it mounted I noticed the timing ring was bent in a few places from shipping. Damn! No way I was going to take it off and wait a week for a new one so I did my best to straighten it. Slapped everything together and it fired right up. Starts and runs like a champ however I noticed the CEL came on right away. I jumped on Car Gauge and saw the code is P0335 - Crank Position sensor. I reset it and it kept running fine until I restarted the car and the CEL came back on. Same code. Reset again and doesn't come back on until I restart. Car runs great though
Do you think it's possible that if a portion of the timing ring is off just enough that the sensor misses a signal at startup only - triggers a code- but then runs fine once running? I would assume that if it is missing information it would start and run like crap but that's not the case.
ateick is offline
Old 10-18-2014, 10:05 AM
DennisMik's Avatar
My guess is that the ECU misses a pulse or two while cranking. The speed that the flywheel teeth move past the sensor makes a difference in the strength of the signal in a transducer, which is what the crankshaft sensor is. Cranking speed is much slower than idling speed.
Check the spacing between the flywheel teeth and the transducer in a spot that didn't have any damage and compare it to the area(s) that had damage. It may be a pain in the butt, but check all the teeth. There may be a bent spot that is small and you didn't catch it. There are 360 teeth on the ring, so mark your starting point.
DennisMik is offline
Old 10-18-2014, 12:28 PM
ateick's Avatar
Thanks Dennis. Always a wealth of information. I'll pull that sensor and rotate the engine and see what might be causing the code. Hopefully I can bend what I need to straight through the sensor hole. At least to the point that it won't trigger the CEL.
ateick is offline
Old 10-18-2014, 09:16 PM
Bad *** Newb
Child_uv_KoRn's Avatar
I doubt the ring is responsible unless it's severely bent. I had a ring falling off the flywheel (big gap & misaligned, literally 3 screws holding it in) and it never threw a code.
However, a bad sensor will throw a code whether the car starts normal and runs or not I'd swap it with an oem one and see (junkyard time).
Child_uv_KoRn is offline
Old 10-19-2014, 05:20 AM
ateick's Avatar
I've still got the auto cps so I'll try that first.
ateick is offline
Old 10-22-2014, 12:40 PM
ateick's Avatar
No luck with the auto CPS but I think I found the culprit....
No wonder. It was shipped to Canada in the original OEM box with no protection. I saw the timing ring was bent but I missed this. Now I'm screwed for emissions testing here because it throws a code.
ateick is offline
Old 10-22-2014, 04:58 PM
Bad *** Newb
Doesn't look like much of anything to me.
Old 10-22-2014, 05:40 PM
ateick's Avatar
It's the only thing that I can see that could be triggering this code. The rest of the ring looks in good shape and pretty straight. This appears to be the only defect. I'm just speculating at this point though.
ateick is offline
Old 10-22-2014, 06:28 PM
Bad *** Newb
I dropped my flywheel and didn't bother straightening the ring
Old 10-22-2014, 09:41 PM
DennisMik's Avatar
If that little chipped tooth is the problem, the signal strength from the transducer would have to be almost too weak.
Trying to relate the problem to the flywheel change, the only theory I can come up with is that the diameter of the new timing ring is slightly smaller than the original. Increased distance between the sensor and flywheel timing ring would mean a weaker signal.
Maybe the crankshaft sensor itself is somehow becoming weaker. I don't know how you feel about taking a wild guess and replacing the crankshaft sensor.
Old 10-23-2014, 01:09 AM
cdoublejj's Avatar
could anything related to this cause high idle?
cdoublejj is offline
Old 10-23-2014, 11:57 AM
ateick's Avatar
I May have to try a new sensor. Not sure if that will do it but it will point me in the right ddirection.
ateick is offline
Old 10-23-2014, 03:16 PM
Bad *** Newb
Make sure the subharness is good.
Old 10-27-2014, 05:55 AM
ateick's Avatar
Does anyone know the resistance across terminals 2 and 3 on the crank position sensor? The FSM doesn't give a value. I am measuring 1.25K ohms on one of my sensors.
ateick is offline
Old 10-27-2014, 02:43 PM
nestorlugo's Avatar
I think it a voltage reading you suppose to take while removing a screwdriver away from the magnet.iirc
nestorlugo is offline
Old 10-27-2014, 02:59 PM
ateick's Avatar
I believe it develops 2.4V if you test it with the engine cranking over but the FSM is vague on an ohm reading. Just says "Except 0 and infinity"
ateick is offline
Old 10-27-2014, 03:16 PM
nestorlugo's Avatar
Yup i know but
I asumme a lot of things i don't know about you,so that would leave me to belive if any other number except 0 is present then it's good.
Old 11-04-2014, 11:23 AM
ateick's Avatar
Update - problem solved by $10 junkyard crank position sensor. Weird. The two other ones I had performed flawlessly before the flywheel change. I put in a 12 year old one from an auto I35 and bam! I'm all good.
ateick is offline
Old 11-05-2014, 10:42 AM
Bad *** Newb
Electronic crap is finnicky. Good thing we don't have BMWs (I have an e34 lol)
Old 11-05-2014, 08:59 PM
nestorlugo's Avatar
Glad to hear !!!i had a similar situation with a cam sensor ,i just went with the $10 I30 sensor and code went away
mvm062
11-30-2020 09:00 AM
03-12-2020 12:06 AM
conansriver
11-18-2015 02:46 PM
gustavison
10-04-2015 06:50 PM
wingnut2006
09-19-2015 06:13 AM
Quick Reply: P0335 - Interesting issue
