knock?
Old 01-22-2015, 04:14 PM
papalion's Avatar
knock?
Having a weird problem..need help i have a 2001 nissan max se 5speed 3.0 and sometimes when im in 2nd and up gear or at rpms higher than 3k it boggs down like it wants to cut off like its stalling .sometimes it does i was thinking knock but my knock sensor is not attached unless there is second oneive octane boost qnd it sorta corrected it but i wanna know is something else besides gas what about low oil?
papalion is offline
Old 01-22-2015, 05:39 PM
chrome91's Avatar
low oil level is easy, check the dipstick low oil wouldnt really make it stall out and bog though
any codes if you scan it?
chrome91 is offline
Old 01-22-2015, 06:11 PM
maxiiiboy's Avatar
No, low oil is not the cause of your problem. If it's stalling at these RPM's, then it's either starving for fuel (fuel pump, fuel filter) or timing is getting messed up somewhere (Crankshaft PS REF/POS, Camshaft PS, etc.).
maxiiiboy is offline
Old 01-22-2015, 07:31 PM
papalion's Avatar
Any know that....thats nit what i was asking...i said if low oil level can cause engine knock ...only codes is knock sensor(which iSnt attached)
papalion is offline
Old 01-22-2015, 07:44 PM
nestorlugo's Avatar
Yes it can... Why is the knock sensor not attached? Is your oil level low?
nestorlugo is offline
Old 01-22-2015, 08:01 PM
papalion's Avatar
Harness popped never got around to replacing it but i will do
papalion is offline
Old 01-22-2015, 08:06 PM
nestorlugo's Avatar
Well i think the knock sensor is there to retard timing and prevent knocking but hey what do i know
Old 01-22-2015, 08:17 PM
george__'s Avatar
How is your transmission ?
george__ is offline
Old 01-22-2015, 08:30 PM
chrome91's Avatar
it does, which could be a problem
stickshift wont cause a bog like that
chrome91 is offline
Old 01-22-2015, 08:33 PM
george__'s Avatar
OPPPssssss
george__ is offline
Old 01-23-2015, 05:32 AM
papalion's Avatar
but its not attached how can it retard the timing or sense a knock
papalion is offline
Old 01-23-2015, 06:16 PM
chrome91's Avatar
which could be the problem, knock sensor isnt doing its job
chrome91 is offline
Old 01-23-2015, 06:19 PM
papalion's Avatar
Ok thanks just wanted to know before i pull my intake manifold off to replace it
papalion is offline
DC_Juggernaut
09-28-2015 04:07 PM
ac max 92
09-17-2015 07:35 AM
ballerchris510
09-11-2015 05:29 PM
Quick Reply: knock?
