Rack and pinion
Rack and pinion
Have a 2003 Maxima GLE
Went under the car for routine oil change and noticed a fluid leak of some sort. Talking with a co-worker it was narrowed down to possibly rack and pinion issue. I checked my steering fluid and saw it was indeed low.
The hose the arrow is pointing at was completely saturated and the assembly to the left was covered in gunk. Turned the car on and turned the wheel. Saw fluid actively coming out.
Conducted a search on forums and read some posts regarding this hose commonly breaking. Does my description fit in line with a new hose or a rack and pinion replacement? Anything else I should check out?
(side question)Heated passenger seat went out about a year ago, common? (Loose wire? Fuse?)
Any cost saving measures are appreciated.
It looks like you need to replace your Power Steering hose. This thread https://maxima.org/forums/5th-genera...hose-02-a.html should help.
Seems to be the year of power steering hose failures...handful of people i know with the same issues recently. Replace the hose.
Transmission dexron fluid in there is new to me tho as suggested few posts above..
should be and put ATF fluid in there as suggested above. You'll drain practically all your PS fluid during hose replacement so ATF would be a good upgrade.
pro tip: This is actually a fairly easy job despite people's hardships. When installing the bracket use long needle nose pliers to squeeze it together with your right hand and thread the bolt with your left. Using a longer bolt can definitely help as mentioned before. The bracket bends easily if you need a little more room.
I bought a hose off ebay that said it was a Gates (51 bucks). Looks like good quality and there's no whining whatsoever like many have reported.
^^ Congrats on the fix.
I've got the same job sitting on the back burner right now, have to get this done in next few days. I'm doing both the high pressure hose and return hose, because like nestorlugo said above ^^ the return hose often keeps leaking when you replace the HP hose.
All Nissan hoses for me, because the aftermarket hoses don't work the same. Mine just started seeping, no big leaks yet, but have to get this done asap.
And yes, ATF and PS fluid is basically the same thing minus a few additives.
mikeg75
11-30-2015 05:12 PM
fastcarny
10-12-2015 07:06 AM
Serotta33
09-17-2015 12:14 PM
