Rear toe out of spec, debating options.
Been a while since I've been on the boards but I've still got my 5th gen and she's going strong at nearly 200k. That said, I've got a bit of an issue with rear toe. Most recent alignment shows the left @ -0.40 and right @ +0.41 with spec being -0.13 to 0.22.
I realize adjusting rear toe isn't normally possible and usually means there's some sort of suspension damage/issue. Pretty sure I'd remember hitting curbs on both sides so I'm not exactly sure what happened. Regardless, the best I can tell is I've got three options:
- Have an experienced shop use some shims to re-align the sub axle/spindle as best they can.
- Have the rear beam "bent" back into shape.
- Ignore it and hope my tire wear/tracking isn't an issue.
I am actually. Tein H-Tech's with a relatively mild 1" drop. Am I right to assume most people with slight drops don't have toe issues?
I mean, I realize any height adjustment will always affect camber/caster/toe to some degree, but this feels excessive. Especially when both are pointing to the left of the car (toe out L, toe in R) implying something is out of whack.
How's your tire wear been with it? Considering toe is the real tire-killer, I'm hoping it's been manageable.
Really? Well that's exactly what I'm running so I guess that just might be it. Weird that they both go the same direction instead of symmetrical, so maybe one of my friends or some attendant rolled a curb at some point.
I drive ~22,000 km a year
Look wise, I can hide the tires going inwards with the coilovers via slamming but the h-tech you can see it
Justin Kroll
09-02-2015 11:06 AM
