02 Fuel Injectors
02 Fuel Injectors
Is replacing fuel injectors a pain in the butt??
Does this involve removing the intake manifold off to get to them?
Any one have a guide for it?
I'm thinking of purchasing them OEM but they're fricking expensive.
Are there any other ones that are not OEM and work like a champ?
Car doesn't throw any codes but my car is wasting a lot of gas.
Thanks!
Thanks!
Do you smell or see it losing fuel? Or is it just really bad fuel economy? If it is the fuel economy drop you might replace your knock sensor and see if that helps. If they go out they will generally throw a code (I think p0327 or p0328) but it won't turn your check engine light on. If the knock sensor goes out it retards the timing and you will see a significant drop in fuel economy with no check engine light.
Other obvious things to check would be air filter and fuel filter.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
