power steering pump leak.
maybe it could be the lines.
For my maxima it was leaking quick and by the end of the day i have to put more. I checked both lines and there was the problem. i just tighten the one line and kinda bend it by accident and from that day till now it has not leaked.
^^this^^
It's the line that runs from the strut tower and down the firewall. Pull back the insulation and look for fluid. That line tends to split and leak. It's easy to check before going after the pump.
I've not heard of many 5th gen pumps failing. If it's that someone else will have to answer.
^^this^^
ill have to take a better look. so far I changed the feed hose though. I'm actually seeing fluid on the power steering belt so I was assuming it was leaking behind the pulley. Pump works fine though....
lowpost99
05-16-2021 11:18 AM
RWCreative
09-21-2015 11:01 AM
pears
09-18-2015 05:25 AM
