Idle
Puerto Rico-Maxima Lover
Idle
Problem:
I have asked this before and still I have the same issue. Car runs perfect, when in operating temp the car tends to turn off. I haven't been using it a lot as I got another car. The other day I was warming up the car, making sure everything is in order. I accelerated the car and the RPM's went up and down in a normal way. but did it again for a second time and the rpm's went all the way down, the car turn off, what could be the problem?? TPS maybe? Temp is up again and have a few parts that needs to be replaced.....
Problem:
In either case, I would: i) Check for any pending codes, ii) Check/clean the MAF, and as last resort iii) Check/clean TPS, CPS. BTW, I had similar problem when my car would die as I shifted fronm D to N, for example when coasting to a Stop/light. It was my MAF, no code.
MAF is still good, codes are the normal oxygen sensors, will check the tps. the car run great, but when it is in D for while with the brakes on, it tends to shutter a little bit, and I have cleaned everything.... the only thing I haven't looked at is the tps
If you're sure the MAF sensor is still good, I would also suggest giving the TB a good deep cleaning - remove it from the car and clean both sides really well (as opposed to spraying cleaner on one side and wiping it out while it is still mounted).
Good luck!
Good luck!
I want to amend my earlier post (above).
If your car shuts off while driving, check out your CAM and CRANK Position Sensors. And read this TSB by Nissan: http://x.nissanhelp.com/forums/Knowledgebase/links/289/ .
If your car shuts off while driving, check out your CAN and CRANK Position Sensors. And read this TSB by Nissan: http://x.nissanhelp.com/forums/Knowledgebase/links/289/ .
if you decide to clean your TB... please do not spray anything into or onto the TB. It should only be cleaned with a small soft wire brush and terrycloth towels that have TB cleaner or MAF cleaner on them.
if the TB is sprayed/flooded with carb/TB cleaner it will damage the IACV inside the housing and cause even more trouble than you already have.
Thanks for your help
you're right, 02-03 is finicky and messing with the butterfly screws up idle and/or tb. but if i'm understanding him correctly i think he's saying in general it's a good idea not to flood the tb with cleaner but spray it on a towel or brush and clean with that instead. maybe spraying cleaner all over (inside) the tb could potentially damage the iacv on the 01
TKHanson
11-24-2018 01:39 AM
Unclejunebug
04-02-2016 05:42 AM
