LARGER Throttle BODY!!!!! Pathfinder
I do not think they do, since the pathfinder had a 3.3 up til 2002 I believe, then switched over to a 3.5. You would have to check, also you have to remember the 3.5 engine throttle body is all electronic, it not cable drive pedal, it's drive by the wire, so let say, if you were to put it on a 5 gen Maxima, will not work, since it's operated by cable.
Here's some info: https://maxima.org/forums/all-motor/...le-bodies.html
01-02 are the cable driven years.
03-04 are electronic and essentially the same as any other 3.5L TB [Warning, the second half of this statement is purely opinion, I may have had both in my possession, but not at the same time]
I deleted my post because everyone was saying 01+ pathfinder so I was believing it, but then I looked it up again, and sure enough 00-01 is the most discussed, so I should have left my post.
Maybe there is an early 2000 PFTB that isn't cable driven or is smaller, but I haven't seen why everyone here isn't mentioning the 2000 as compatible when it is.
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
REDinLV
10-18-2015 05:31 AM
