Hot transmission, and wobble under acceleration
Hey guys, I did my best searching for these issues and didn't find what I was looking for. I picked up an 02 6spd about a week ago with 159k on it. Previous owner took good care of it.
I noticed when I first got it a very aggressive wobble under acceleration, any acceleration, above about 60mph or around 40 if I really get on it, that stops the second you take your foot off the gas. I replaced the lower control arms today along with new ball joints and it felt great...for about 10 minutes and immediately came back. Haven't gotten it aligned yet but I don't think that's related to this particular issue.
Aside from that, after performing the free sts mod, I started having a real sticky first gear after the car warms up, to the point that I have to really really muscle it into second upon take off.
This is my first max, coming from a mustang so I'm not very familiar with FWD. Any info would be awesome, thanks.
So, I got it aligned and I thought it helped but to no avail. The wobble is intense at freeway speeds with almost any throttle use. It's the whole car, I feel it in the steering wheel but the interior shakes violently as well. Still lost.
again, what kind of wobble? does the steering wheel wobble back and forth?
Maybe wobble was an incorrect term to use. There is no directional bias whatsoever, more so it's shake. The steering wheel and floor boards are the most noticeable, but it causes the door panels to shake as well. Only under acceleration, like I said the second I let off it goes away.
Intermediate shaft bearing is on the passenger side of the car and it is where the right shaft is attached. The right shaft does not go into the trans.
Some replace the axles with good results, some still have the vibration. The bigger the drop, the more problems.
No guarantees that if the axles were replaced there wouldn't be a continuing problem, but for @ $100 might want to give them a try.
+1 on the axles. I have a similar setup. Solid mounts and a subtle drop, not slammed.
I was getting the same vibration. It was just under acceleration and everything else was in good shape. The axle boots weren't torn and there was no clicking to indicate bad axles. Once I pulled one out I could feel the play in it. A new set cured the problem.
It shouldn't eat the axles unless the car is slammed really low. My car's been dropped since about 07. I had this issue with the axles in 2012 and they were already a few years old when I dropped. I doubt it was even related to the drop.
Also, I'd change the tranny fluid with some Redline MT90 to see if it improves the shifting.
It's important to know that you CAN'T put any GL5 or GL5 blend in the tranny.
ONLY straight GL4.
ONLY straight GL4.
jmlee44
10-02-2022 02:13 PM
Need help
23
10-02-2015 08:56 AM
Pied
09-26-2015 03:29 PM
