code p0507 idle problem
Old 07-26-2015, 08:26 AM
Maxboy23's Avatar
The check engine light came on and codes popped up code p0507 saying the rpm is idleing to high and code p0171 saying bank 1 system to lean...sounds like a 02 sensor i already replaced bank 1 sensor 1 but never replaced bank 1 sensor 2 could it be a bad o2 sensor thsts causing a problem? Some people are saying it might be the throttle body is dirty but i cleaned it not to long ago and i did pop open the butterfly valve thing so maybe i have to so the idle relearn procedure i dont know
Maxboy23 is offline
Old 07-26-2015, 02:52 PM
DennisMik's Avatar
for the P0507, see page 433 in this link:
http://boredmder.com/FSMs/Nissan/Maxima/2003/EC.pdf
DTC P0171 is for the bank 1 sensor 1 oxygen sensor. Bank 1 sensor 2 has a different code. How long ago did you replace the sensor? But whatever it was, it appears to have gone bad. I don't know what brand you put in, but I would suggest you use the Bosch brand.
DennisMik is offline
Old 07-26-2015, 03:26 PM
Maxboy23's Avatar
I literally replaced bank 1 sensor 1 like 100 miles ago with the oem bosche sensor so it cant be that maybe its the second upstream because no its saying bank and i did the idle relearn trick about turning the key and pressing gas etc and the car idles normal i reset the code so I'm going to give it a couple days but that lean bank thing worrys me what bank is the second upstream i hear its behind the engine on the back header is that bank 2 sensor 2?
Maxboy23 is offline
Old 07-26-2015, 04:03 PM
nestorlugo's Avatar
Bank 1 is the firewall side Bank2 is the radiator side...
Perhaps you could exchange the o2 sensor if it has warranty
nestorlugo is offline
Old 07-26-2015, 04:15 PM
Maxboy23's Avatar
Im sorry it was bank 2 is lean but isnt rhat downstream? The upstream is more important right?
Maxboy23 is offline
Old 07-26-2015, 08:56 PM
DennisMik's Avatar
Well, you gave us code P0171.
P0171 is for bank 1 sensor 1.
P0174 is for bank 2 sensor 1.
And like Nestor said, bank 1 is next to the firewall. Bank 2 is next to the radiator.
Yes, the upstream sensors will have a more detrimental effect on the car's performance than the downstream sensors. Downstream sensors won't have any effect on performance. What Nissan calls sensor 1 is the upstream sensor. Sensor 2 is the downstream sensor.
03-12-2020 12:06 AM
bryants95max
10-02-2015 12:52 PM
97_GXE
20
09-17-2015 08:12 PM
Steven Orozco
09-12-2015 10:41 PM
NissanNismoZ
09-12-2015 07:30 AM
Quick Reply: code p0507 idle problem
