3 Windows Not Working -- Please Help!
Would love if any of you can help me out with this. I have a 2002 Nissan Maxima. Last week, the windows started acting up. My driver side window works perfectly fine, however, the other 3 windows (passenger and two back windows) do not go up or down using the switches. I tried using the master switch to open the three (3) windows, but nothing is happening. I also used the switches on each of the doors, but those are also not opening the windows either.
Also, when I try to press the "lock" button on the driver side door, the doors lock, then immediately unlock by themselves.
Does anyone know what I can do? Is this an issue with the master switch on the driver side door? any help will be appreciated.
Thanks for your responses, but its not the window lock. Another reason it is not the window lock is because when I press the lock button on the master switch, the doors lock and then unlock by themselves. If the issue was with pressing the window lock, I would not have had this problem.
Also, although the driver window was working fine, it is now also giving me issues. Sometimes it goes up and down, and sometimes its stuck. Any other advice?
jerrod99_se-l
08-27-2015 08:27 PM
kjm900r
08-05-2015 07:14 AM
