OEM HID Headlight
OEM HID Headlight
I've been trying to figure this out but I can't find a picture of it to confirm. What do the OEM HID headlights look on the Maxima if it came factory equipped with the HID option? Everything I'm seeing looks like they don't have projectors, which makes me think they're retrofits. Did they somehow find a way to use HIDs without a projector at that time or something, or was there not a factory HID option? Just confused, I've seen lots of Maximas with HIDs and the factory looking headlights but none ever have projectors that I'm seeing and thought those were required to properly diffuse the light from the HID bulb.
it was one of the first cars with stock HID, so not long after prolly within a year or two most cars had hid but with projectors, even nissan in the same window changed over to projecters in the 350z
search a little further its all out there
So this explains why there was a higher theft rate on these headlights when they first came out. Always wondered what it was about it. Is the reflector housing literally any different from the one that takes a regular bulb, or is it just the inclusion of the ballast and a specially designed HID bulb that turns the regular headlamp into an HID one? I always assumed someone retrofitted HIDs into my Maxima but couldn't ever see any of the 5.5 gens with projectors besides ones with the cheap eBay headlights or custom jobs.
Manufacturers are not allowed to just stick HIDs in halogen headlights. They wouldn't meet DOT standards.
Yeah, the factory HIDs aren't bad though.
As long as the headlight is clean, they don't glare. The bulb itself has a special cut off coating on it and the reflector is designed differently.
This shows the difference between the D2R(Reflector) bulb and the D2S(Projector) bulb.
Aside from the coating, the bulbs are virtually identical and use the same plug. Just have a different cut out as to where a tab fits so you can't interchange them without cutting that piece out.
I put in 5.5 gen lights on my 5th gen. The cut off on these is actually very good and flat. Changed the bulbs to 6000k. White light output on the road, slight blue tint when looking at the car. No glare though.
i remember i didnt like the look of projectors at first, they looked like alien eyes to me haha.
like look at that puny projector on the earlier 350z , looks gross to me.
That tiny projector actually uses D2R bulbs as well lol Because it isn't a true HID projector like the later years. Just a projector lens in front of the bulb kind of like those cheap ones you can find on ebay for S13s.
thanks man
am I pretty close in saying the maxima or 350z was one of the first few cars with stock HID ?
i remember the acura tls had them too around the same era so prolly all car companys at that time did it
i remember the acura ones always turned pink, it was like every 3 acuras I saw with that stock hid had pink early dying bulbs
doctorpullit
10-28-2019 10:58 PM
knight_yyz
11-01-2015 01:34 PM
Dennis Twohy
10-01-2015 06:01 PM
