coil spring isolators?
Old 10-01-2015, 06:22 PM
5thgendriver's Avatar
ok...only had the maxima for a few weeks. I am going to change out most of the front suspension and the rear shocks and lowering springs. I have all the components except I have not purchased any coil spring isolators. I have not inspected the isolators that may be on the car now and I do not have the car here with me. so...my question is do most ppl just transfer the isolators from the stock springs and reuse them or what. since my goal is to lower the car while swapping suspension parts I want to make sure I do not add to the height with isolators. so...what have you guys done when swapping in lowering springs? new, old or didn't use any? if new, what did you go with.
thanks
5thgendriver is offline
Old 10-02-2015, 10:06 AM
DennisMik's Avatar
I didn't lower my car but I have changed the struts. Nissan uses a piece of paper as an isolator. Mine were in semi-good shape and I re-used them. If I lived up north, I'm sure they would have been no good. However I really should have replaced them, but I didn't want to stop putting in the struts to go get some.
DennisMik is offline
Old 10-02-2015, 11:03 AM
and this is what I don't want to do...thanks for the reply. I've never see any paper ones...any idea where I can purchase them?
Old 10-03-2015, 02:18 PM
DennisMik's Avatar
On the bottom of the spring, Nissan uses what it calls "Seat-Rubber, Front Spring", part number 54034-31U20, suggested list price $22.78.
The top of the spring uses a part with the same name, "Seat-Rubber, Front Spring", but a different part number, 54034-AG001, suggested list price $23.05. These 2 parts do not look like each other.
(http://www.nissanpartsdeal.com/parts...agram=401_A002)
I found the upper one on rockauto.com for $6.41, but not the lower.
Couldn't find them on autozone, found universal ones on O'reilly Auto but I don't know if they are in your area. Search for coil spring insulator or coil spring isolator.
Old 10-04-2015, 06:22 AM
great...thanks for the footwork dennis.
Old 10-08-2015, 08:26 PM
crazy97's Avatar
You didn't look hard enough..
https://www.rockauto.com/catalog/x,c...h%2Bfor%2BMOOG
crazy97 is offline
Old 10-08-2015, 09:41 PM
Bad *** Newb
Child_uv_KoRn's Avatar
I don't use anything. I put some grease on it just in case, but that's it.
It's totally unnecessary to have anything on the mounts (I just put coilovers on everything lol).
Child_uv_KoRn is offline
Old 10-09-2015, 06:30 AM
i'm actually looking at getting a thicker isolator for the rear so it can be closer to level with the front as i'll be installing a set of vogtland lowering springs. from the pics I've seen with these springs the rear is a tad bit lower than the front.
CRizz
41
06-07-2021 05:42 AM
Huttig2009
09-25-2015 03:31 PM
soon2ownmax
08-13-2015 02:19 PM
classymax420
08-06-2015 06:35 PM
xUNIxPanther
08-05-2015 09:31 AM
Quick Reply: coil spring isolators?
