[HELP] My AirCon works only at the Lowest Temp (A33)
Old 11-11-2015, 01:36 AM
NeoBlitz's Avatar
Hi guys I hope I am posting this in a right place. My Aircon flow is ok. It's just that the aircon works only when it is set to lowest temp.. anything other than that, it blows the heater
I tried to change the whole controller panel at the dash, it does not solve the problem.. what other things i should look at.
I cant find a good source of info to investigate this.
you can see the controller photo in the attachment.
In this zone the lowest temp is 18 degree. If i set to 18.5 - the heater kicks in.
I am so lost
Any tips will be highly appreciated!
Attached Thumbnails [HELP] My AirCon works only at the Lowest Temp (A33)-fullsizerender-2.jpg
NeoBlitz is offline
Old 11-11-2015, 07:51 AM
DennisMik's Avatar
As you know, you have the auto climate controls that will keep the cabin temperature at whatever you set it at.
In order to do this, there are 4 (I think) temperature sensors built into the car. One of these sensors is probably bad. To check/test these sensors, you can run the built-in self diagnostic.
But first, check to see that you have not blocked the in-cabin sensor air intake grille. It is located on the dash forward of the ignition switch.
To run the self diagnostic, you need to follow the procedure in the service manual. Click on the link below and go to page 37.
http://boredmder.com/FSMs/Nissan/Maxima/2001/HA.pdf
When the test is running, one part (test 3 I think) takes maybe minute, so don't start thinking that the test got hung up and isn't running.
DennisMik is offline
Old 11-24-2015, 06:55 PM
NeoBlitz's Avatar
Sorry for late reply. I am going to follow up with this. THANKS A LOT for the manual .. I am probably going to print it out to find the locations of the sensors. I will also provide this to the workshop so they might be able to inspect the issues.
NeoBlitz is offline
Randy
08-09-2018 08:09 AM
rbarnes
12-28-2015 04:32 AM
pieterm
23
12-15-2015 01:52 PM
trimmer
11-08-2015 06:00 AM
Genes1s
10-29-2015 09:24 AM
Quick Reply: [HELP] My AirCon works only at the Lowest Temp (A33)
