Finally trying new cam sensor, ran into unexpected problem...please help!!!
Old 11-29-2015, 12:52 PM
kingkai1990's Avatar
So I got the OEM sensors today. Everything was fine, I know where the cam sensors are....only problem is that I CAN'T get the friggin' bolt off the first one (the one closest to the front of the car, with one bolt). Looks like my wrench won't exactly fit in the crowded space. Any tips on what to do?
kingkai1990 is offline
Old 11-29-2015, 01:50 PM
Max139617's Avatar
Not sure how big your wrenches are but, might have to pick up a smaller one from harbor freight and hit it with some pb blaster before you go at it. Fwiw mine came off really easy
Max139617 is offline
Old 11-29-2015, 06:30 PM
Brudface's Avatar
Yes, get a socket set. Much easier. Those two spots are kinda tight, especially with the small amount of overlap/ledge that the valve covers sit on.
Brudface is offline
Old 11-29-2015, 09:25 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Wrenches? Those are like ancient technology and are only used as a last resort
Child_uv_KoRn is offline
Old 11-30-2015, 06:20 AM
Derrick2k2SE's Avatar
As others have said, use a socket.
You'll round it off trying to get a wrench on it and not pulling exactly straight.
If you're going to do any work on cars you need a socket set. The bare minimum would be a 3/8" drive ratchet, sockets from 8mm to 19mm and a few extensions of different lengths.
Eventually you'll want a 1/4" drive set too and deep well (long) sockets in both drive sizes.
If you have a decent sized local flea market you can piece together a workable set for pretty cheap.
Derrick2k2SE is offline
Blasterguy
11-10-2019 05:23 AM
808_vq
28
12-02-2015 07:03 PM
GNCMaxima
11-26-2015 07:49 AM
LocalMaxima
11-25-2015 08:11 PM
Quick Reply: Finally trying new cam sensor, ran into unexpected problem...please help!!!
