Long rough start?
Long rough start?
When my car sits for a few hours it loses fuel pressure. The pressure is normal when it is running.
I think fuel is getting into the cylinders as it is rough when it starts and has a very very small knocking for 5 seconds. Car takes 5-7 seconds to start
I have replaced:
Both fuel dampers (with new OEM o rings)
fuel pump
fuel filter
fuel pressure regulator (OEM)
fuel pressure regulator o ring (OEM o ring)
fuel sender unit
gas cap (OEM)
fuel pump seal
the only thing that can possibly be leaking would be injectors or injector o rings? What do you think. I replaced everything else. If it were a line seal, I dont think I would have the knocking from what appears to be fuel bleed into the cylinders. Thanks!
I have replaced:
fuel pump
fuel filter
fuel sender unit
gas cap (OEM)
fuel pump seal
I have replaced:
fuel pump
fuel filter
fuel sender unit
gas cap (OEM)
fuel pump seal
I have replaced:
fuel pump
fuel filter
fuel sender unit
gas cap (OEM)
fuel pump seal
So, given the pain we have endured, give us some leeway: First, you did not tell us what the problem symptoms are. Instead, you told us what you think the problem is, and how you think the imagined problem should be fixed. Then, you immediately asked us to approve your solution. Are you kidding me/us?
Let's start from basics:
- What are the symptoms of your problem? - be concise and specific. Symptoms only - no hypothesis of your own allowed.
- What were the symptoms way back - before your replaced all those parts listed above, probably needlessly?
- Obviously, you have a strong believe that the problem is fuel-pressure related. Why do you think that? For example, you said that "when my car sits for a few hours it loses fuel pressure". Why do you think this is a problem?
Your post is a great example of how not to ask for help. Your post is so bad it hurts reading it.
First off what grade of gas are you using? This car needs premium to run correctly, other grades will knock in occasion What the other guy means is you didnt post any useful symptoms (ex. uneven exaust tone, shaking more at certain rpm than others, smells, etc. If its running rough and barely starts look at the plugs. if they are wet with gas then your dumping fuel as you thought. if they are black as heck or anyother brand than denso or ngk plugs you will have those issues. this
New engine, 50K miles on it. Plugs are new, 50K miles. Dont know the brand, will replace.
Rough start, long crank, rough idle (not too rough). No other symptoms. Everything else is fine.
I would idle around 700-800 rpm with my bad plugs and it sits happily at 1k rpm now(5speed version) with the ngk v power i have in now. aslong as you use the proper heat range on the plug any ngk type will do. i would personaly get the v powers. oh and what grade gas do you use, anything lower than 91?
heck i would get your battery and alternator tested aswell. check all grounds to make sure there not corroded. i had an alternator fail on me in a previois car and right before it failed the car had huge driveability issues like sloppy shifting, hard starts, low rpm ide, and soo much more. ohm testing the coils wouldnt hurt either, theres a thread on that somewhete on here.
(NGK 4469 LFR5AIX-11 IX Iridium Plug)
http://www.ngk.com/product.aspx?zpid=9868
- Heat Range: 5
- Longevity: 40-50k
- Gap .043"
I have asked for help on her, and had 3 different mechanics try to fix the long crank issue, all have failed. This would be great to fix.
177K
New engine and transmission (50K on each) (got both with 0 miles)
I hope its not the alternator. I did short out my battery twice. Had to buy a new one. My amplifiers wire touched while driving.. doh.
I'm doubting it's the alternator as the car starts up right after you turn it off.
I use 87 octane. I am thinking about getting these plugs. Is the gap and heat range ok?
- Heat Range: 5
- Longevity: 40-50k
- Gap .043"
Get that 87 out of there!!! everyone that posts these running issues is almost always using 87. you need 91 and heres why. 91 has less of a chance to detonate under pressure. we run 10-1 compression so we need the det resistance. that knocking could be detonating and will absolutely wreck plugs and run like crap. always refer to the uset manual for gas grade type.
how is your mpg and power? usualy it will dump fuel if your using 87 to compensate for not using 91 to suppress knock. Running realy rich can kill your catalytic converter aswell. those ngk plugs should work well.
I get the code p0420 every 4 months. Reset it, and it comes back 4 months later. Odd. Runs fine and passes emissions.
Dude I get 240 miles per tank! Idk what that equates to but i used to get 320. Power seems alright, could be a bit quicker compared to other maxes ive seen on youtube going 0 to 60.
Thats happening due to the 87 im guessing. my acura cl with a huge downpipe leak was getting that kind of mileage on 91 gas and with a smaller gas tank. The ecu will pull your timing and will reduce power to prevent knocking on the 87 especialy under wide open throttle. If the above poster is right about the plugs being killed i wouldnt doubt the precats are on the way out due to always running pig rich to not detonate. Raw fuel is literaly the death of cats
cats have 170K on them. I have a front precat sitting in my closet. It costed me $80. Im nervous to have it installed because its cheap from ebay and not OEM. Probably will wear out in a year.. :/
You may not need them replaced, if the leak is before the rear o2 sensor then it will missread and throw a code. thr exaust leak and the 87 would directly lead to poor mpg and power, those injectora must be dumping a reckless amount of fuel.
That leak may have saved your primary cat from seeing all that rich exaust. it leaked before it hit it hopefully. in that case the rear cat may be in very well condition. Better buy a neck brace aswell, youll need it for your newly found torque.
So 93 over 91 octane is fine?
I just filled up with shell v power 93 octane and felt a power increase instantly when at wot. Idles a little better. Its obvious it still has a huge flex pipe leak though, steering wheel shakes and my entire hood vibrates and rattles like hell. Ugh my poor engine....
I had a crank sensor cause long starts and misfires. It's unlikely, but you can test it just by unplugging and starting it.
Sorry, I don't have any other ideas. If you do a quick restart and it still struggles, then it's not fuel injector. VQs will start and run fine enough on 3 cylinders, so it's pretty much impossible that you have more bad injectors than that.
Out of curiosity, what did the old plugs look like?
It's a shame the ECU isn't spitting out any codes.
Get this issue fixed, gut cats and done.
Im going to return the y pipe i bought. Its aluminized steel and will rot in 3 years. Going to buy a stainless steel one.
Oh, ok, you haven't installed the new plugs, yet. We will be anxiously waiting
I have replaced my air filter with a K&N dry filter 3" cone. I had a spectre 3" cone previously.
I have also filled up with 93 premium.
This has made the engine run much smoother. It accelerates much quicker. The old filter was clogged BAD and the 87 octane was like running the engine on water...
The car starts much easier, but still has a rough start (not a long crank anymore).
I'm guessing this is the y pipe leak.
New y pipe, injectors, and spark plugs, coming soon.
I went from 190 miles per tank.... to 200 miles at half a tank. I will probably get 330 miles out of this tank of 93.
I cant imagine the mileage with the new parts. Kinda excited.
My intake manifold is cool enough to hold my hand on it and not take it off.
The engine accelerates so fast I feel the engine (head gasket) or transmission is going to explode.....
His car is supposed to run 91 and above, read above to see how. his car was running like crap and the 87 just made things worse. that engine has only 50k so it only makes sense that he has decent mpg with an exaust leak. An air filter can make you run leaner aswell if not tuned, using less gas. if your filter is clogged enough you can run pig rich. now that he is using 91 the cpu set greater timing in all rpm and is more efficient when burning. between the shot plugs, exaust leak, and old air filter we dont know how much timing was pulled in the first place but it was enough for op to notice.
I am at 266 miles and i still have 1/3 of a tank left. I will let you know the total miles per tank.
As soon as the gas light comes on, I count that as 1 tank. I do not count any miles after the light is on.
Looks like I'm going to get 330 miles this tank, instead of 190.
Once the y pipe and everything else get put in, I will prob get 350 miles per tank
engines USA
330 a tank isnt enough to say its impossible and think about it, now that it makes more power it can sustain lower rpm operation. for all we know, op had to mash the gas to get the equivilent acceleration as he does now with the tune up and new gas. In this case can we agree that change in driving habits and pressing the gas less can save fuel. If its an auto then that loss in power can cause the torque converter to not lock up at the lower rpms, which is throwing away mpg.
I will upload a pic of the old air filter.... you will then understand why it "almost" doubled.
