2000 complete ignition/key tumbler replacement problems
Okay fellas first post here great site never signed up because all advise I have gotten off here went smooth until tonight. Steering wheel was locking and had to wiggle key for five minutes to start. So I decided to replace ignition everything went smooth, got old one off new one installed solved problem it appeared. Key turns good unlocks wheel so on, hooked battery up and give her a try car started and than went right off? Turns over as normal just will not start and run. What did I do wrong took pictures as I went hooked everything back up right but will no start. Sounds normal just will not fire any suggestions. Did I have to do something else beside just swapping out parts? Any input would be appreciated!
Edit: You can swap the chips.
You can also reprogram NATS, but that's useless money spent at the dealer (but you can buy the cable and nissan datascan II and do it yourself).
No one lives near STL or else I could program it for you
Split the cheapo keys and see if you can fit the old chip inside (I assume you can). Obviously, throw out the new chip if this works.
Just try it and see if it starts, first. You can do the pedal dance to reset the ECU.
http://www.6mt.net/forum/performance...rocedures.html
Now, I'm more curious if it shows a code when it's locked you out and if resetting it only works by ECU reset... Anyone know? I've never felt the need to use the wrong key multiple times LOL
Tape would be a terrible permanent fix as you risk damaging the chip.
ColdCananda
04-15-2016 01:13 AM
slickblack94
02-29-2016 10:33 AM
ColdCananda
02-16-2016 03:50 PM
