Pulsing Vibration
Old 08-22-2016, 08:09 PM
Aleiben's Avatar
Pulsing Vibration
So I recently replaced my Radiator Fan Assembly and now when I'm idled it makes the car vibrate in pulses.
Any thoughts?
Aleiben is offline
Old 08-23-2016, 04:34 PM
Cotozic's Avatar
Mine does the same thing. Not OEM fans, but it's pretty normal. Ideally the fans should only run after the car reaches a certain temperature, and they have a high and low speed.
Cotozic is offline
Old 08-23-2016, 05:23 PM
mclasser's Avatar
I don't even notice the fans kicking on/off unless I have the windows open.
You sure everything's bolted on tight and not rubbing against the rad?
mclasser is offline
Old 08-24-2016, 12:09 AM
Donkeypunch's Avatar
Ok. Can you wiggle the radiator?
That means the bushings that hold it down are worn.
Pull out your 1080p phone and lets hear it.
If you're saying the engine is vibration more then it's unrelated.
Donkeypunch is offline
Old 08-24-2016, 07:40 PM
Aleiben's Avatar
Gonna go to the mechanic and see if anything is fishy.
But Ill record the sound and see if its something else if the mechanic cant see whats wrong.
Aleiben is offline
03VQMAX
23
05-22-2017 03:58 PM
ColdCananda
04-15-2016 01:13 AM
Turbobink
02-25-2016 10:41 AM
ColdCananda
02-16-2016 03:50 PM
Eric L.
09-23-2000 01:55 PM
Quick Reply: Pulsing Vibration
