Passenger Headlight won't work
Chances are you're looking in the wrong fuse box. If I'm not mistaken there is two fuse boxes in the engine bay and the one of them will show you LS and I think RS headlamp. Provide us with more info like how did you determine if the bulb isn't the issue. Did you use a tester to see if there's power going to the bulb, check the fuse or switched it with the other side?
Passenger Headlight will not work
more info. these lights are Xenarc , swapped left and right to determine that bulb was good(both worked in driver side) thanks for info. on fuse box ,just swapped the fuses andstill no luck. other ideas please
If you checked the fuse and it's good and you switched the bulb and it worked on the other side then you need a tester to see if you're even getting power to the bulb. Doubt it's the bulb or balast because they rarely go out but if it is then you have a situation because the OEM is expensive.
Oh yeah, the input looks the same, I'm just not sure about the mounting. The ballasts seal against our headlights, so if the sealing side isn't exactly the same it may not fit correctly. I haven't seen anybody with OEM Gen III or IV ballasts confirm that the Gen V's are directly replaceable.
Dennis Twohy
10-01-2015 06:01 PM
jerrod99_se-l
08-27-2015 08:27 PM
CAN-Other LF: Worn / Broken Parts
george__
08-18-2015 07:06 PM
