07 Maxima won't accelerate in drive ..
I'm having several different problems with my car at the moment & need some input on what it might be.. I do have the common knowledge most should know about a vehicle but I'm no mechanic.. so I was on the way home from work and while I was driving it seems like my car lost power , then the battery & brake light both came on. I pulled over and cut my car off (was going to try just restarting it). Well when I crunk my car up , it sounds good, revs up great (while in nuetral) but once I switch it to drive it has no power & just creeps forward .. mind you it will also creep in reverse , but will only idle up when in nuetral or park.. PLEASE help or suggest if you've had this problem before ..
(UPDATE: Ive seen a lot of posts that are similar to mine saying the cause of this may be the camshaft sensors. I have now replaced both the front & back sensors and I am still running across the same problem)
I just had my alternator checked, and let me tell you, taking the alternator off is a pain in the ***, so look on the forums for volt testing procedures
I am having same issues with my daughters 05 maxima and today I am getting ready to check her catalytic converters I think they could be plugged up some where there is no check engine light. So I hope I can figure this out.
David McNamara
08-08-2016 05:24 AM
lyte805
08-03-2016 05:56 PM
