Sponsored by:
Sponsored by:
Cabin air filter airflow direction
Old 07-19-2016, 10:11 AM
Cipitiox's Avatar
Should I install the filter with the airflow arrow towards me or away from me?
Cipitiox is offline
Old 07-19-2016, 10:47 AM
Richard66's Avatar
If your filter has a pull tab on it then it goes in the bottom of the housing and the tab facing you.
Richard66 is offline
Old 12-03-2016, 07:22 PM
Navydoc's Avatar
Head of the arrow indicates air flow direction.... points towards the cabin...
Navydoc is offline
Old 12-04-2016, 09:05 AM
KGMtech's Avatar
Other than the pull tab issue (some aftermarket filters don't have this) the direction of airflow is not important UNLESS you have managed to remove the old filter and are, for some gawd forsaken reason, going to re-install same filter after cleaning the big chunks.
The new filter media works the same regardless of direction of airflow...cheap activated charcoal ones being the sole exception.
KGMtech is offline
Old 12-26-2016, 05:22 PM
Les7311's Avatar
As you pull the old one look at the directions of the fins. I think Nissan really messed up locating the cabin filter by the passenger foot in a cramped space. Gggrrrrr
Les7311 is offline
Old 04-03-2017, 10:07 AM
jspagna's Avatar
This is the worst design ever. I wouldn't even mind taking **** apart but this is the worst place to locate the CAF and you don't even know if its in there correctly as it's like a black hole!!!!!
jspagna is offline
Old 04-03-2017, 12:49 PM
Richard66's Avatar
Take a drop light into that black hole with you and the job is so much easier.
lowriderman3
04-16-2019 10:20 AM
Socp10
20
05-30-2017 03:33 PM
Reza2016
08-17-2016 07:53 AM
blowitoutyour
26
07-26-2016 06:40 AM
Hikaru12
07-18-2016 11:41 AM
Quick Reply: Cabin air filter airflow direction
