Has anyone upgraded their Brakes or Exhaust YET?
Old 11-06-2015, 01:50 PM
wyobbagy's Avatar
I have been looking everywhere for an Axle Back exhaust and Brake upgrade kit. I have found nothing offered by Stillen or AR racing for the 16 yet? everything underneath looks the same as my 7th Gen did Both the Brakes and Exhaust.....but no one will confirm they will fit? would appriciate any help if someone knows what will work!
wyobbagy is offline
Old 11-28-2015, 05:25 AM
wyobbagy's Avatar
I still havent came across any Brake or Exhaust upgrades for the 2016. I did buy a set of the MGP brake capilar covers. the quality looked ok but I was really not comfortable with the mounting stystem and sent them back. the clips hold them on secure but nothing keeps them from moving left to right I was concerned about rubbing the inside of the wheel so I sent them back. Stillen tells me that they are working on the Axle/Cat back system but have seen nothing yet. If anyone out there knows of any upgrades available please post them.
wyobbagy is offline
Old 11-29-2015, 11:14 AM
Sponsor
JM AUTO RACING's Avatar
Are you looking for a Big Brake Kit or just upgrade on Rotors?
JM AUTO RACING is offline
Old 11-29-2015, 07:40 PM
A36-SR's Avatar
I did brembo rotors and custom cat back.
A36-SR is offline
Old 11-30-2015, 11:30 PM
kaulana47's Avatar
Can you post pics? Want to see how to Brembo's look. How does the active noise cancelling do with the exhaust?
kaulana47 is offline
Old 12-01-2015, 02:27 PM
wyobbagy's Avatar
I wasnt going to go that far back for emissions purposes here in PA ....did you switch out the Mufflers as well? did it get you any sound ehhancement? I was looking to replace the calipers....have you found anything? Both Brembo and AP told me they didnt have anything for the 2016 yet yes if you have any pics that would be great to see your progress.
wyobbagy is offline
Old 12-01-2015, 02:31 PM
wyobbagy's Avatar
JM auto racing went to your site found NOTHING for a 2016 Maxima? looking for entire brake kit Brakes Rotors front and rear......ThANKS
wyobbagy is offline
Old 12-01-2015, 03:43 PM
dot dot dot ...
NmexMAX's Avatar
I'm assuming since the rotors are the same as the 04+, the Brembo kit can be used using CGR's brackets. Might need someone to verify measurements though.
Rear will be tricky due to the parking brake set-up since it's not like the 95-03. So the FB-Rear BBK wont work.
NmexMAX is offline
Old 12-01-2015, 06:37 PM
A36-SR's Avatar
I did not did the calipers yet just rotors and pads as my Custom exhaust i did all 2 1/2 pipe remove secondary cat but I keep my oem my mufflers to give the oem look from the back and give the a better sound i don't like chrome mufflers why buy one and they sound rice
A36-SR is offline
Old 12-02-2015, 11:38 AM
dot dot dot ...
NmexMAX's Avatar
I bet those Brembo calipers would fit the 8th Gen using the same brackets if not slightly modified.
With that said, probably any A34 FB Wilwood BBK kits would also fit it.
NmexMAX is offline
Old 01-04-2016, 12:34 PM
Maximum808's Avatar
New Maxima owner, but had a G37 prior. Does anyone know if the Akebono 14" BBK would fit? This was a common upgrade on the 370z and Infinitis. Figured Nissan would same or similar suspension parts, but the front wheel drive components might be different. Thanks any info would be appreciated.
Maximum808 is offline
Old 01-09-2016, 12:41 AM
Maximum808's Avatar
Ok, so I read that the seventh gen can use the Akebono brakes, but the parking brake won't work. Second thing I read was that 7th and 8th gen have same brakes? Can someone confirm this? Thanks
Old 01-09-2016, 07:31 AM
A36-SR's Avatar
Yes they do i have brenbo rotors from a 2012 maxima just rotors
A36-SR is offline
Old 02-06-2016, 10:17 AM
Maximum808's Avatar
Taking this back to the top. Just trying to keep this discussion going. Does brembo make a rear kit?
Old 02-06-2016, 03:43 PM
faze2988's Avatar
Akebono from G37 or 370Z fits and parking brake works fine.
faze2988 is offline
Old 02-06-2016, 05:02 PM
Maximum808's Avatar
Thanks, looks like you know what parts work. How's the pedal feel? Any issues with the advanced cruise control? Are you running coil overs or springs? Your max looks awesome
Old 02-06-2016, 07:18 PM
faze2988's Avatar
Pedal feel is a vast improvement over stock. Idk about advanced cruise control because I dont use it. Im running Tein Coilovers from 2009+ nissan altimas which is essentially the same as 7th gen maxima suspension but I like tein for comfort reasons..ride is just as smooth as stock IMO. thanks for the compliment. Front needs a little more low though.
faze2988 is offline
tam0281
11-12-2015 06:51 AM
mattz300
11-11-2015 11:53 PM
Lowered_a33
11-03-2015 05:29 AM
maximusrising
10-27-2015 07:36 AM
Andy29
10-20-2015 09:19 PM
Quick Reply: Has anyone upgraded their Brakes or Exhaust YET?
