trunk noise
trunk noise
My trunk seems to make a thumping noise on bumpy roads. Dealer was not able to find issue. I removed everything from trunk including spare and its alot better only makes the noise on large bumps and not in any consistent fashion. So I'm guessing the reduction in weight might make this a suspension issue. Issue occurs in normal or sport mode.Any ideas? 2016 max SR
Not sure if this is the problem, but on my previous altimas I had this problem, in the trunk if you look at the top there are 2 thin bars that run across the length of it held together by a clip. If the clips come off, the bars tend to move around and cause a clunky noise when going over bumpy roads.
thanks
Well, this is interesting. I have had the pop/clunk from my front and rear. I finally scheduled an appointment because I found that other thread mentioning Nissan extending and covering a rear link that could make noise and potentially break:
Rear suspension link 10 year warranty extension - Maxima Forums
We went for test drive and they spent two hours looking at it. I was told the rear suspension components were fine and the noise was from the rear glass! They told me there is no threat of breaking a seal of anything catostropic. The expense would be quite large to remove the rear glass and reset it - guess I have to live with the noise.
Concerning my front, they would not diagnose without charging. I think it is my strut mount so may change them once weather gets warmer next year.
