Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
6gen Brakes swap into 4gen that fits 16s
Old 04-09-2015, 10:01 AM
  #41
I like Maximas
vipervadim's Avatar
Originally Posted by nestorlugo
Stock 5spoke 16"s
Hmmmm nestorlugo
you might need to use a small spacer (5mm) with stock OEM 95-99 16"SE rims, you have to check the clearance with the spokes (I think the spokes curve inward toward edge of rim and since rotor is all the way out it can rub in that one spot)
TEST FITMENT.. TEST FITMENT.. AND TEST FITMENT AGAIN
and when you're 200% sure you've got it set, then you paint them.
Good luck and post some pics of fitment.
vipervadim is offline
Old 04-09-2015, 02:22 PM
  #42
nestorlugo's Avatar
Cool
Originally Posted by vipervadim
Hmmmm nestorlugo
Thanks for the heads up vipervadim.....
I grinded the top part flush almost but i got a set of 5mm handy jic.
Hopefully i have time to attempt the install this weekend , the rotors have been turned and im contemplating painting the center.
I'll post plenty of pics......
nestorlugo is offline
Old 04-09-2015, 02:57 PM
  #43
nsnrider's Avatar
always nice to paint the rotors so they don't rust so quickly. (not the braking surfaces of course).
nsnrider is offline
Old 04-09-2015, 06:16 PM
  #44
nestorlugo's Avatar
First test fit.... No spacer(it's at home) No rotor(they're in my friends trunk) BUT......check it out :gaptheeth: only need to take it down about 1mm on this and the opposite corner and it should clear without a spacer
Old 04-09-2015, 10:18 PM
  #45
Maximeltman's Avatar
Those don't look like the same stock 16s that I have, you have 00-01 rims? Mine are 1999 se. But still looks good although very small clearance.
I'm getting my calipers back tomorow but doubt that I'll be installing until next week maybe week after.
Maximeltman is offline
Old 04-10-2015, 06:30 AM
  #46
nestorlugo's Avatar
Yes i got a 5gen ...and 17" s are not an option well unless i get some 5spoke altima 17"
Good Luck with your install...
Old 01-07-2016, 11:53 AM
  #47
Blackwind's Avatar
Appreciate the info.
I have that same dynalite kit if you want it, you just have to source mounting bolts
Blackwind is offline
BkGreen97
04-02-2016 05:47 AM
I<3 A32's
09-10-2015 11:07 AM
JoshG
09-05-2015 10:10 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: 6gen Brakes swap into 4gen that fits 16s
