Replace Full Wheel Hub assembly or just berring.
Hello I have a 2005 nissan altima: I've been driving on a sticking rear caliper for about 5,000KM's before I actually noticed today, From my quick inspection today I'm thinking it just sticking slide pins and I wont have to change the calipers, however with the heat that has generated I think the wheel hub bearing must of seized (I'm going to see if vibration continues after I replace slider pins tomorrow. My question here today is since I don't have a press for the push bearing should I just spend the extra $50.00 and replace the whole wheel hub assembly? I's it fairly easy and is it better than just changing a bearing?
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
He's talking about the rear.
To the OP, the rear is SUPER easy to replace with the whole assembly. I wouldn't even bother with a new bearing and pressing it on. I don't know where you are in Canada but usually local napa's carry that stuff or they can at least order it in.
Derrick2k2SE
46
11-16-2016 07:17 PM
