VQ30DE-K swap for Dummies
Old 12-07-2007, 12:29 PM
  #41
3.5 in the works
DandyMax's Avatar
Originally Posted by Ceasars Chariot
photo 8 - ha its an illusion, didnt notice that last night. its just a patch of water that was left from taking out the radiator I guess. looks half way dry. you had me worried though... lol !
Hehe I figured it probably was just an illusion...
man i tried getting off the stock pulley from the DE-K yesterday, ha...useless. I didnt even bother trying to take off the UDP after having such a hard time. i will have to sit under nearest tree and dream up something. or if i lived in the states maybe i could buy an amazon kindle with the haynes manual on it, and have a read under the tree? that thing sucks !
Put it in 5th gear, get K to step on the brakes for you as hard as she can and then try it. Or an impact gun if you can borrow one...
1. OK Saturday morning here. Ive done all the prep work I was asked to do. Anything else I could do that would be helpful?
2. Also I had some questions regarding the fluids in the engine, Should I go ahead and drain the oil, and transmission fluid ?
There'll be other things that need to come off... axles, starter, disconnect all the rad hose, coolant lines to the heater etc, PS and alternator can be taken off once the engine's out unless you're really bored lol... and yeah why not drain all the fluids. You know about the 2 water plugs on each side of the block (plus the rad)?
What do I need to buy to test the knock sensor?
If you don't already have one, a digital multimeter. You can probably find a basic one that will measure various voltages, resistances, currents, check circuit connectivity etc and not be too expensive. I forget what kind of stores you got down there but places like Autozone, Canadian Tire, maybe Home Depot etc would have them. Here's an example of what I'm talking about... Basic multimeter for $30.
DandyMax is offline
Old 12-07-2007, 02:29 PM
  #42
KRRZ350's Avatar
http://forums.maxima.org/showthread.php?t=547254
Here you go, for FUTURE reference, no sense in putting the tranny back in.
KRRZ350 is offline
Old 12-08-2007, 12:03 AM
  #43
Old Maxima Legend
Ceasars Chariot's Avatar
im still using the a32 frankencar midpipe. what is the difference in the de-k berk midpipe or something like it. see post #1 that setup has got to go. im thinking i need something straight out of the TB then work my way to the battery area. then work on a custom cold air intake setup with the filter behind the fog light, since i removed mine. i would just need to remount the odyessy battery.
Ceasars Chariot is offline
Old 12-08-2007, 12:12 AM
  #44
KRRZ350's Avatar
This one guy brought me an '02 max for some work and I LOVED his intake set-up. It was basically your typical WAI w/the large K&N, except he had two seperate things of ducting feeding cold airto the area near the filter and he also had some heatsheilding so that the hai was sectioned off to the openings of the duct work. I wish I had pics, it definitly fed straight up cold air to it without the nasty bends that typical cai's have, or the radiator heat issue of injens types.
KRRZ350 is offline
Old 12-08-2007, 12:23 AM
  #45
Old Maxima Legend
yeah injen was pretty but was lame, mine got stolen so i hope someone is having fun with the hot radiator air intake system by injen they stole off me.
yeah i just need a straight pipe coming out the tb then cut the whole and run another pipe maybe something like they used for the place racing design or cattman cai. is there any ebay cai that are not injen style. i had a look yesterday but only saw those, will have a look again. a custom job will be so much cheaper if i can find the right bends.
im a bit confused though, do i need a de-k intake or de ? im setup for de, but the de-k piping has one less nipple ?? i might could make this work, and add in a bit of extra piping to get the filter sucks from right behind the fog light. (mine are removed).. I know I know ... what if it rains. no biggy for drag racing only. drive around with hot air setup
http://cgi.ebay.com/ebaymotors/Nissa...QQcmdZViewItem
Old 12-08-2007, 04:16 AM
  #46
Old Maxima Legend
found an old photo at owners place of the VQ30DE-K I bought. Cost me $800 NZ or $530USD. Lets hope this old barnyard DE-K will get up and go !
Old 12-08-2007, 04:19 AM
  #47
Old Maxima Legend
In searching for DE-K threads I came across a nugget. Source was from an 00VI swap thread, but when swapping in a DE-K and using the 4th Gen ECU, you will need something to activate the VIAS (controls the switchover point for the Upper Intake Manifold) Best activation point (dandymax did lots of testing)
5000 rpms
what can you use to activate the switchover point (Vias)
- summit rpm switch
- greddy emange ultimate
- V-AFC II
- MSD #8969 (digital)
- ARWS @ www.bakerelectronix.com
- Harlan
Harlan vs Summit debate or reviews: http://forums.maxima.org/showthread.php?t=363079
Old 12-08-2007, 04:23 AM
  #48
XAugusta MoonX's Avatar
YES SIR! But you have EU don't you? As far as I remember, the EU can be used to activate the VIAS.
XAugusta MoonX is offline
Old 12-08-2007, 05:12 AM
  #49
Old Maxima Legend
I contacted JeEvE for some input but found some information searching around he provided after doing his DE-K swap.
Many people are asking what needs to be done to swap in the motor. Ill list everything I can think of.
-splice A33 injector plugs into A32 harness
-extend A32 TPS plug to reach A33 throttle body to reach
-remove A33 IACV and fab cover plate under throttle body
-plug swirl valve vac (if calli)
-plug throttle body coolant lines
-mount EVAP on DE-K manifold and hook up vac
-swaped over the EGR, MAP, EVAP solenoids and run correct vac lines
-plug any other open VAC sources on A33 manifold
-use A32 exhaust manifolds and EGR setup w/ A33 guide tube
Old 12-08-2007, 11:14 AM
  #50
Most of which is found in any of the other 00VI swap threads such as my own or PMOHR's when using all 5th Gen parts. Also, don't forget to set-up the VIAS using an RPM Switch, a VAFC or VAFC-II, or EB or EU. Lots of options.
Old 12-08-2007, 11:25 AM
  #51
jmeister's Avatar
VAFC (1st version) can't activate the VIAS
jmeister is offline
Old 12-08-2007, 11:52 AM
  #52
Mine does. You're thinking SAFC I think. VAFC= Vtec Air Flow Converter. Use the Vtec wires for the VIAS. SAFC= Super Air Flow Converter if I'm not mistaken.
Old 12-08-2007, 02:18 PM
  #53
jmeister's Avatar
Mine does.
Please share... it wouldn't work for me, the VAFC-II did
jmeister is offline
Old 12-08-2007, 03:39 PM
  #54
Old Maxima Legend
dats right ! EU wired and ready to go, thanks dandymax !
Old 12-08-2007, 03:41 PM
  #55
Old Maxima Legend
R.I.P. VQ30DE
1997-2007
173,105 miles
Old 12-08-2007, 03:58 PM
  #56
Old Maxima Legend
im going to see if the DE front valve cover fits on the DE-K. If it fits and the coils feel like the go on right. does anyone see a problem here ? I like the way the DE front valve cover looks vs the DE-K. I believe dandymax said I wouldnt have any worries using the DE 3 front coils. swapping the front valve cover would make it easy to mount them in. just mechanically speaking even if it fits would i be over looking something ?
Old 12-08-2007, 04:12 PM
  #57
Are you talking about the actual metal valve cover or just the little plastic thing?
Jmeister, I don't know what to tell you. Mine works just fine.
Old 12-08-2007, 04:23 PM
  #58
Old Maxima Legend
metal cover, going out to have a look at it now. and post back. you know on the DE-K the oil cap has to sit up like its on some sort of throne, on the DE it way low and hiding.
Old 12-08-2007, 04:54 PM
  #59
3.5 in the works
DandyMax's Avatar
You should be able to switch them up Chris.
PS got your PM's, will try to get some pics/diagrams done for you in the next day or two.
DandyMax is offline
Old 12-08-2007, 05:23 PM
  #60
KRRZ350's Avatar
That thing looks clean, I'd have no worries about it firing up, vq's are near bulletproof anyways.
Appears to be cali spec, remove the swirlvalves & there actuator rods ftw imho. Yeah it adds some work but better now right?
KRRZ350 is offline
Old 12-08-2007, 05:28 PM
  #61
Old Maxima Legend
yeah dan, i just fitted the DE front valve cover (if thats what you call it) on the DE-K. Fits the same, just looks different. If it turns out that one of the DE-K coils are bad for example, at least I know all my DE coils are good and I can swap the DE front valve cover onto the DE-K and will have a perfect way to mount the coils. (DE-K 1 10 mm screw, DE 2 8mm screws).
With the DE front valve cover mounted I popped the DE coils in. They fit and feel just like they did on the DE. When you pull them out though they just come out.
With the DE-K coils when you pull them out you can feel a hair of resistance and almost hear a pop or something when they come out. Redneck theory makes you think they fit better or something.
I dont know much about coils at all. I dont recall the mileage they are supposed to get like change them every 100,000 miles for example. But I thought since mine are 10 years old I would give the DE-K ones a shot and see how it goes.
DE-K A33 Redtop
DE A32 Blacktop on DE-K
Both front valve covers weighed in at 7 lbs. each, regardless of the DE-K oil cap barstool it sits on, lol !
And just like you said dan, the DE coils clip right in to the DE wiring connectors.
Old 12-08-2007, 05:34 PM
  #62
Old Maxima Legend
its crazy new zealand spec. scroll through this thread
http://forums.maxima.org/showthread....ap+for+dummies
if your talking about the removing the swirl valves from the LIM, its done, even had the holes welded.
if there are more swirl valves then that sucks !
Old 12-08-2007, 05:37 PM
  #63
Old Maxima Legend
would there be an any sort of number on the engine to find out what year car it came out of ? In New Zealand the VQ30DE-K was used from 2000 to all the way to the 6th Gen Maxima thinking 2004.
Old 12-08-2007, 06:46 PM
  #64
Old Maxima Legend
sniplet from http://maxmods.dyndns.org/index.php which is in serious need of updating.
VQ30DEK Motor Swap
Description: Engine taken from the 2000-2001 Maxima/I30. The swap is generally known to be cheaper and easier to complete versus the VQ35DE swap. The main mechanical pro over the VQ35DE is that it is overall a smoother engine. The obvious con for choosing a DEK over a VQ35 is less power. An EXCELLENT replacement for a blown VQ30DE for the less mechanically inclined. Search "DEK" on forums.maxima.org to find scattered details on the swap.
Cost: You can easily find a DEK on www.car-part.com for $400 with low miles. Be ready to dish out more money for the RPM switch and other items required to complete the swap.
Old 12-08-2007, 06:54 PM
  #65
MorpheusZero's Avatar
I very much approve of this thread, as when my tired old DE gives out this will be the swap I'm doing (if I'm so inclined to do such a swap).
MorpheusZero is offline
Old 12-08-2007, 08:36 PM
  #66
Old Maxima Legend
would anyone care to comment on this statement ?
all else being equal a DE with 00VI has better top-end power potential than a DE-K due to the DE intake cams having 8 degrees more duration (later intake valve closing).
Old 12-08-2007, 09:41 PM
  #67
KRRZ350's Avatar
It's da troof. DE intake cams > DE-K
The other reason is that on a de equipped car, when you add the larger de-k injectors and use an afc to take fuel away you are also adding timing.
KRRZ350 is offline
Old 12-09-2007, 11:09 AM
  #68
3.5 in the works
DandyMax's Avatar
There's a serial number stamped on the top of the block at the rear where it mates with the bell housing. Dunno if you'll be able to tell the year directly off that number though...
DandyMax is offline
Old 12-09-2007, 11:40 AM
  #69
Bacon Lover
Tatanko's Avatar
I didn't have to do this with my 00VI swap. Didn't find it necessary. It doesn't have a whole lot of slack to work with, but it's not stretched tight or anything. I even had it that way back when I used a 4th gen TB and it was extended out further due to the adapter. Didn't change anything when I swapped a 5th gen TB on.
Tatanko is offline
Old 12-09-2007, 06:27 PM
  #70
KRRZ350's Avatar
Should be a metal vin tag somewhere near the rear header also, maybe only a us-cpec thing though
10th digit = year
t='96 u=97 v=98 etc etc and than I *think* it starts back at "A" again? dunno?
KRRZ350 is offline
Old 12-10-2007, 09:52 PM
  #71
Old Maxima Legend
im not seeing this de-k wiring harness/connector on the DE. Looked around on the DE wiring but didnt see anything like it?
close up
Old 12-10-2007, 11:15 PM
  #72
If you can't find anything for it, don't use it. I know there's a few harnesses on my DE that aren't connected to anything. Leave it in just in case then when you start-up, if you don't need it, cut it.
Old 12-11-2007, 12:48 AM
  #73
Old Maxima Legend
point taken ! in that same area an o2 sensor comes up through there in the same area on the DE but nothing like this that i can see now on the DE in the DE-K photo.
Old 12-11-2007, 05:27 AM
  #74
KRRZ350's Avatar
It's there, it goes to your camshaft pos sensor & oil-pressure. BUT, for some reason I want to say that on the 4th gen it doesn't have a subharness and comes directly out of the rear injector loom, that's a definite IIRC though.
KRRZ350 is offline
Old 12-11-2007, 04:53 PM
  #75
Old Maxima Legend
Had a good look around under the car today, the wiring in photos #71 is on the DE, instead of a connector its just wired into everything.
should be able to use my DE wiring and connect everything up. everything looks the same around the oil pan area, its just that connector up top on the DE-K thats not the same on the DE
Old 12-13-2007, 02:33 AM
  #76
Old Maxima Legend
Old 12-13-2007, 02:39 AM
  #77
Old Maxima Legend
Clutch
kev doing the swap had a look at my clutch, he asked where the nearest trashcan was? said this clutch was wasted, lol ! in photo below that is basically some charcoal looking film over metal, there was nothing there but some stains and crumbs?
also said oil was getting on the flywheel area causing it to get slippery, overall said it was all a mess. so im going to get a new clutch, and have the flywheel machined. im thinking once this is fixed up my 60 fts should be sweet, i knew something was going on in that area but didnt have enough mechanical knowledge to know. seeing first hand was cool.
in photo above (VQ30DE) we had a look on the VQ30DE-K it looked like a brand new engine, not soaked in oil. this is good ! it was good to get in and have a look at where the oil dripping on to the concrete under the car was coming from.
Old 12-13-2007, 02:40 AM
  #78
Nice. When does the DE-K go in? Are you done with all the prep work?
Old 12-13-2007, 02:58 AM
  #79
Old Maxima Legend
well i have to deal with the transmission which is going to slow things down since i got to order (as for as I know) my clutch kit from the states, ive also got to get the flywheel machined. so it could be as long as two weeks. im not sure what to do about the input shaft bearing in the transmission, im pretty sure its a mess.
as soon as i get that sorted then we will just put the de-k in !!
ACT-NM1-HDMM Clutch Kit
http://www.modacar.com/products/Nissan/Maxima/MODACLS/
can anyone recommend a reliable place online to buy this clutch ? these days im a bit out of the loop on where to buy our mods ??
Old 12-13-2007, 04:38 AM
  #80
Why not buy from that website?
Quick Reply: VQ30DE-K swap for Dummies
