FWD vs RWD VQ35 Differences (Lengthy)
No more Maximas...
To try to cut down on the 'can I use a 350z motor in my car', or 'why can't I use a G35 or FX35 or (etc) motor for my swap?' type of questions.
Recently started as a tech at a local Nissan performance shop (AAM), so I had the opportunity to snap some pics (and hopefully be more helpful around here). The following pictures all have the blocks aligned in basically the same exact way for ease of comparison).
RWD Block (350z, FX35, G35, any RWD VQ35DE platform)
FWD Block (Maxima, Altima, Quest [IIRC], any FWD VQ35DE platform)
Mounting Comparison
Accessory/Manifold comparison
Here's two side-by-side pics (blocks are aligned in the same position, however the FWD block has torque plates 'installed'):
Left side
Right side (crappy pic, but you get the point)
Basically, you can definitely use the RWD block in a FWD design, it would just require re-engineering of a lot of things. Not even minor things, but motor mounts, headers/exhaust manifolds, etc.
To use a RWD block in a FWD chassis
Benefits of using a RWD block in a FWD chassis (assuming it will ever be done, not likely)
Long I know, but trying to get the point across. If anyone has any questions, please post them here and I'll try to address them for you.
Mounting Comparison
- RWD:
- Large bolt pattern, maybe 8"x5" (from memory, definitely not accurate)
- Mount cast positioned towards the timing cover
- FWD:
- Small bolt pattern, maybe 4" square (from memory, definitely not accurate)
- Mount cast positioned towards the end of the block
- RWD:
- Exhaust manifolds/headers curve backwards, away from the motor mounts
- Accessory mounting points are located vertically along the front edge of the block (these are for the AC compressor, IIRC)
- FWD:
- Exhaust manifolds/headers head straight down, motor mount is offset and doesn't get in the way
- Accessory mounting points are located horizontally along the lower edge of the block
Left side
- Custom motor mounts that extended towards the trans to utilize the center crossmember. Would most likely be weaker than the stock FWD mounts (on the FWD block) unless you braced the hell out of them.
- Custom headers made to stretch around the custom motor mounts made above - as you can see the RWD mounts are just plain in the way of any sort of manifold that comes straight down.
- Custom mounting brackets for all of the accessories, or try to customize the RWD accessories/mounting rails to work
- Turbo manifolds could go directly over to the driver's side without the typical FWD mount interference
- Engines may be easier to find
- Possible ability to use the revup engine (with all associated electronics of course)
No more Maximas...
The HR is a redesigned version of the VQ35DE; more power, stronger internals, CVTC on both intake and exhaust (like the revup), etc.
mkaresh
03-12-2018 06:48 PM
doctorpullit
12-12-2015 09:39 AM
