Help me customize my gearbox swap
Looking for opinions from people who have done the 4.133 final drive 6sp gearbox swap into their 5.5gen.
If you guys could change anything about gears 2-4 within a 4.133 finaldrive gearbox, what would it be? Why? Ex: make 2nd gear taller? Make 3rd taller? 4th shorter?
I recently picked up a 2006 6sp hlsd gearbox to swap into my 5.5gen. Wanting to keep the nice low rpm cruising gear like the 5.5 gearbox, I'm going with a .54 6th gear. Also going with a .733 5th gear so the shifting difference isn't so substantial between 5th & 6th (per SR20DEN). I ordered them about 6 weeks ago and they should be arriving in the next month or so.
Finding them was quite a chore....hours so many hours..... but I won't go into all that lol. These threads were super helpful, many thanks to those who posted with all the info:
https://maxima.org/forums/all-motor/...lick-here.html
https://maxima.org/forums/all-motor/373331-mfa60.html
It did get me thinking, since I'll have to crack open the gearbox to install the new 5th & 6th, why not customize everything and space out the gears nice and even? For example I really prefer how 3rd and 4th gear feel in a 5sp (although I hate how close 5th is to 4th) compared to a 5.5gen. I don't like the short 3rd in a 5.5gen, which will feel even shorter on the 6th gen I presume.
Probably obvious but I not going to change the 4.133 final drive. What gear ratios would you guys suggest to space things out perfectly and still keep the gearing in the sweet spot?
I've been researching and have found a few interchangeable options for the RS6F51H gearbox.
What about this setup?
Stock to proposed:
1st Gear Ratio 3.153
2nd Gear Ratio 1.944 (1.842 ?)
3rd Gear Ratio 1.392 (1.296 ?)
4th Gear Ratio 1.055 (.947 ?)
5th Gear Ratio 0.809 (.733 done)
6th Gear Ratio 0.63 (.54 done)
This setup would lengthen gears 2-4, but with the shorter final drive it should still allow for cycling through the gears faster, yes? Or maybe I should just leave 2-4 as is and not change anything? I've never driven the 4.133 final drive......if you have, lmk what you think.
As a reference these are the interchangeable options I've found:
'02 Sentra se-r 5-speed
2nd 1.842
3rd 1.258
4th 0.947
Qashqai 2.0 M1D - Diesel
3rd - 1.322
4th- 0.947
X-Trail 5-speed
3rd = 1.258
4th = 0.947
Delta - 5-Speed / MFA60 (GK Tiburon V6)
3rd = 1.296
4th = 0.943
Delta - 6-Speed / MFA60 (GK Tiburon V6)
3rd = 1.333
Stock to proposed:
2nd 1.842
3rd 1.258
4th 0.947
3rd - 1.322
4th- 0.947
X-Trail 5-speed
3rd = 1.258
4th = 0.947
3rd = 1.296
4th = 0.943
3rd = 1.333
Teemu
I've had some experience with 5spd and 6spd gearboxes, I've swapped Sentra 6spd internals, open diff -> HLSD conversions, rebuilds, etc.
Here's some info to help you along the way:
The way our 5spd and 6spd are made, 1st gear and 2nd gear are cast into the Shaft itself, meaning whatever year/model donor you choose, you have to use those shafts for the whole build, 1st gear 2nd gear and final drive have to correspond, for both MAIN Shaft and INPUT shaft
Gear ratio options to use:
Maxima 02-03
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .630
Rev. 3.002
FD: 3.812
for 04-06 Maxima and 04-06 Sentra spec-v
gear ratios are exactly the same 1st-6th+rev, but
FD: 4.133
Altima 02-05 (5speed, used same parts as the 6spd)
1st 3.153
2nd 1.842
3rd 1.258
4th .947
5th .772
Rev. 2.272
FD: 3.812
02 Sentra spec-v
1st 3.417
2nd 1.944
3rd 1.258 - (X-trail 5spd gearing)
4th .947 - (X-trail 5spd gearing)
5th .773 - (YOUR new 5th gear)
6th .630
Rev. 3.252
FD: 4.429
03 Sentra spec-v
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .673
Rev. 3.002
FD: 4.133
These are the commonly obtainable gearsets (I think I have a spare of each)
I would recommend using a 03-06 specv gearset as donor because they use triple cone synchros to start with.
4.133 FD is very good, it's the sweet spot of quicker acceleration, and still decent MPG with 6th. Since you're changing that 6th to much longer, you're making the gearbox much more versatile for highway cruising with regard to MPG in 6th.
What you have to ask yourself is your driving style: City cruising + Highway cruising + Street and Highway Racing combined.
Ask yourself how/where each gear will benefit you, and you will come up with a winning solution.
Do you want More Shifting (shorter gears),
OR
Do you want to Stay In Gear for a longer time like on the highway (longer gears).
^^^I think this will be key in deciding your 3rd and 4th gear ratios, as those gears put you to about 125mph+
Personally I don't use 4th that much in a 5spd (unless I'm racing over 100mph)
but with 5th in a 6spd, since 1-4th are plenty for typical acceleration and get you up to (125+) speed in no time, I don't use 5th, because 6th is the REAL MPG saving gear.
Maxima 02-03
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .630
Rev. 3.002
FD: 3.812
FD: 4.133
1st 3.153
2nd 1.842
3rd 1.258
4th .947
5th .772
Rev. 2.272
FD: 3.812
02 Sentra spec-v
1st 3.417
2nd 1.944
6th .630
Rev. 3.252
FD: 4.429
03 Sentra spec-v
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .673
Rev. 3.002
FD: 4.133
OR
The 6th part #'s were in the thread I linked above, but the 5th gear wasn't in that post so it took me a very long time to find. And even longer to verify they'd both work. Mainly because the x-trail is a Canadian and Aussie car so I had to call around to a bunch of Canadian dealerships to get the proper info. Then actually finding it online because the prices at the dealer were astronomical. Yeah. My work is your gain, so for anyone else wanting these gears, here are the part #'s. Although I haven't received 'em yet so purchase at your own risk.
Nissan X-Trail 5th gear, .733:
Input shaft gear, 32312-8H510
Main shaft gear, 32341-8H510
6th gear, .54:
Input shaft gear, 32331-8H566
Main shaft gear, 32342-8H565
Purchased through:
http://autopartmaster.com/en/
I really like the longer 3rd in a 5.0gen. 3rd in a 5.5gen feels too short. If I wanted that same feeling in a 5.5gen, what ratio would you suggest? I've found 3 options so far for swapping 3rd:
1.333
1.296
1.258
Is the 1.258 too far away from the stock 1.392?
So my question, Viper. For a turbo car, i want long gears not only to stay in the gears longer to take more advantage of the power but this will be a road trip car as well so highway cruising is very important especially when considering keeping those underhood temps low. I have a 5spd and im just wanting for the inevitable kaboom. So i was thinking of using the 02-03 trans and swapping over the HLSD. I have heard however that the +03 specV trans are better at handling high torque apps(the syncros you were talking about?). In your opinion what would be best for a car that is likely going to hovering around the 400wtq mark, with my criteria in mind.
Doh. Just got an email from autopartsmaster and my order for the input shaft gear 32331-8H566 was cancelled. So I have to buy another....and the only options are at a higher price. Not a big deal I guess but will add another 3-4 weeks plus another 50 bucks.
Back on topic, anyone else have opinions on how to improve gears 2-4?
Yes that would definitely be an option, switching back to the 3.8 final drive. Although the nice thing about the 4.1 is being able to accelerate faster, and switching back to 3.8 negates that.
For me, I'm staying w 4.1. I've already bought the gears and you're right it's expensive so far just for the parts.
I do wonder...... if you put slightly taller gears for 2-4 on a 4.1, if that would make it feel and drive like a 3.8? If that's the case then obviously it's a silly exercise, might as well just change the final drive. But if you'd still cycle through the gears faster.....well then that would be pretty cool.
I'm in the same exact boat: 3.5L + boost
in most instances, 03+ spec v (4.1FD) + .54 taller 6th is the better combo.
gives a good gear ratio for acceleration (track, street dig, and from a roll) always keeping within powerband 4400-6500 between shifts, and with .54 6th upgrade you have the best MPG gear when NOT using the power. Especially when just driving on road trips and long distances doing 50-75mph gets better with .54+4.1FD over .63+3.8FD..
and If MPG is your only concern then .54 with 3.8FD is the way to go.
are you turbo or SC?
IF SC definitely 4.1; IF turbo and depending on your power/setup 3.8 could be better to stay within boost longer/harder.
Crusher103
It's pretty weird ordering this stuff from international websites. My first time doing it......a lot of stuff is in foreign languages..... it took some courage to use my credit card lol. Instantly got the "you've just spent X dollars here, did you mean to do that?" text messages each time I put $$ in the account.
Back to gearing, your post is another reason why I'm thinking of making every gear just slightly taller. I spoke to a dealership Friday and I'm thinking the gearing below would be nice for gears 2-4.
Altima VQ 02-05 & '02 Sentra se-r
2nd 1.842
3rd 1.258
4th .947
I got part #'s for input shaft and main shaft for 3rd and 4th, but for 2nd they could only find the main shaft part #. They couldn't find the input shaft #. They think it's maybe because 2nd isn't sold as it's own gear or something......perhaps it's actually part of the shaft itself? Anyone know this?
So there is no way to change only 2nd gear within a RS6F51x gearbox? If I change 2nd, I have to swap the entire MAIN and INPUT shafts (which would obviously include 1st gear as well)? Am I understanding that correctly?
Ok so let me see if i understand this. Understanding that 3rd gear is usually the weak point in these FWD transmissions. Since I want the 3.8FD i'll start with the 02-03 open diff 6spd:
Buy an +03 spec V trans.
Swap in HLSD
Swap in 3rd, 4th, 5th gear for those stronger syncros
add the .54 6th gear
Transmission done?
Swap in HLSD
Transmission done?
Dang man you already answered my question and I missed it the first time through. Thanks for posting this. I've been trying to get this question answered for a while now. Called a bunch of dealerships and transmission shops and no one knew the answer because the 2nd gear part # wasn't showing up in the fsm diagrams.
Yeah unfortunately that's the only limitation.
MAIN shaft + INPUT shaft + DIFF have to match
as the Reverse, 1st and 2nd, and the matching DIFF gears
all have different # of teeth due to different ratios.
Swap in HLSD
Transmission done?
Swap in HLSD
Transmission done?
if you're going to do all that work.. it would be worthwhile to cryo and shotpeen the stock gears before putting them back in, also buy new synchros for 2nd and 3rd as those will be stressed a lot and a used trans will have them in less than NEW condition (unless you find a 5K mile spec-v donor trans)
I also run a little bit of redline shockproof HDuty gear oil as an additive to MT90/Amsoil.. it really sticks to gears/synchros nicely and adds an additional layer of viscocity for racing/mashing gears
Swap in HLSD
Transmission done?
Swap in HLSD
Transmission done?
A spec V trans would already have hlsd, gears 1-5 (because they're the same as a stock 02-03), and the stronger synchros. So no need to swap in all of those parts. Find a specV and you'd only have to swap in the .54 6th gear and the 3.8 final drive.
Not sure if that's correct but I think that would work.(?)
So your goal is hlsd, stronger synchros, 3.8fd, and .54 6th gear. If that's correct, then how about this:
02-03 with 3.8FD has 61/16 teeth on final drive gear/shaft pinion
04-06 with 4.1FD has 62/15 teeth on final drive gear/shaft pinion
simply putting a 4.1FD with 62 teeth into a 16 teeth shaft will bind and rub the gears, due to incorrect spacing, as there is one extra tooth
All this is so confusing lol
Why not just go with a 5 speed with a full Par Gearset? From what I understand this will be an indestructible 5 speed transmission especially built to handle boost.
If my 97 auto goes thats the route I'll be taking. Im in the process of fully built 3.5 on stock timing SCrgd. I have the VB upgrade, HS torque converter, Tranny cooler plus AEM gauge to monitor temp. Im running Nistune and it will be tuned By Chris Miller when its ready to be dynoed.
-An 02-03 open diff 6spd goes for around $300 around here
-a SpecV HLSD 6spd also goes for $300.
-Plus a 6th gear, overdrive. Around town torque with the 3.5 is not an issue and i would like to keep my RPMs as low as possible around town and on the highway
The internals on the 6spd has more beef on it then the 5spd transmission. So far they have been known to hold up 450wtq reliably, in street applications. Drag racing and track abuse i dont know the figures.
From what i hear, the spec V trans with the 4.1FD is difficult to pop you can really thrash that transmission to break it. It has something to do with that FD to why that transmission can take some abuse.
Also with the PAR gear set you can only swap 3rd and 4th to the PAR gears.(only 3rd gen VE transmission can fully swap, the 4th gen 5spd is different internally from the 3rd gen) So its not a full swap now if your goal is to just strengthen 3rd gear and 4th gear, there you go your done but if you want strengthen the whole transmission.....out of luck. Another thing i had mentioned but we have not discussed is strengthening the case. Because the case flexing puts unnecessary force on the transmission internals through changing the spacing of the gears, less surface area contact. I believe that is usually the downfall of the 5spd which its been documented the transmission cases flex and give way in the FWD SR community(they also swap to the 6spd for strength). Since guys here are not as serious about racing like those B13/14 guys why dont hear much about it but the transmissions internally are almost identical with the bolt pattern bellhousing/clutch plate being the main difference.
The price.
Yes a Par Gearset will cost more but I would rather do it one time and spend the money and be done with it, especially with my engine build and power ill be putting out. They have an entire PAR gearset for the 4th gen last i checked. But yea most opt for 3rd and 4th since those are the weak points.
Im hoping my Auto tranny wont fail anytime soon though since Im dropping a pretty penny getting the current work done on it.
I know of people who have also broken 6spds with no boost. Mostly drag racing or just being complete idiots with their transmissions. Anything will break if you misuse it.
Since i plan on just using this as a weekend/cruising car, as long as it can put up with high torque for short burst is what im really concerned about, most of the time i will baby it, rolling into the throttle, no harsh shifts, no launches. Drag racing is not even in the picture for me, i'll leave all of that to speculation among my friends lol. So a 6spd transmission with shot peening and cryo treating will likely be perfect for my purposes.
The autos however with some money put into them are stronger than the MT transmissions. so provided your doing the right things, the auto should not fail on you because of lack of strength. However if you wanted a MT transmission i dont know why you would spend money the auto just use that to buy the MT trans and all necessary swap parts.
I only started the thread to get people's opinions on gears 2-4 within a 4.1fd gearbox and if they'd change anything about them.
Cool you posted that, I'd never heard of them before. Yikes though have you seen the prices on the par gearsets? Those are racing specific gearsets according to the website and would cost more than the entire car. A bit overkill for a 15 yr old max.
What's confusing? All we're talking about is switching gears within a gearbox.
and Ive dropped a lot of money on this car over the time ive had it hell... my Big break kit costs more than the car lol but you cant all that power and not be able to stop
I'd like to.....that would be my preference. Of course I'd like to completely restore the body on my maxima too but that's never gonna happen. Option 2 is to do it together w a friend who knows transmissions pretty well. Option 3 is take it somewhere and have it done quickly.
