Remote Wire
Right, i think something wrong with my remote wire for my after market headunit.
Because you know how like the harness comes with the yellow and red color wires? yellow is the 12v power, and the red is the 12v ignition.
If my remote wire doesn't work, can i go head and attach to the RED one? which is 12v ignition?
Other than that, hooking your amps up to the red wire SHOULD be ok, as long as you aren't pulling too much current from whichever circuit it's on. Relay may be needed.
Here's an article that addresses the very problem of a burned out or non-existent remote wire on a head unit.
http://www.caraudiohelp.com/newslett...emote_wire.htm
Also, in regards to the remote wire, is connecting it to the ACC audio 10 AMP fuse the best way to turn on the amp?
Thanks,
are you sure you are hooked up to the remote wire and not the power antenna wire? they do behave differently. the power antenna wire would turn off every time you switch from radio to cd. they do make low volage triggers relay module so you can use a signal from for example a rear speaker in your trunk and its output can be used as the remote for your amp. same as the PAC TR7 that mendon mentioned
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
