TX DFW: Diamond audio 8" DVC
DFW: FSOT Diamond audio 8" DVC
Pics in eBay listing. I bought this to replace the factory sub in my Infiniti. Turned out the factory harness and crossover were out not the sub.
This is a diamond audio cm308d2 dual voice coil 2 ohm sub.
The benefits are you can run it parallel at 1 ohm to be compatible with the factory Bose amp.
Good sub, never used. I opened and mounted it once and when I got into the trunk to begin the install I fixed the issue. Has been on a shelf since, I now own an suv and this won't produce the bass I need. I'm asking $60 plus the ride or local pickup.
Id also consider trade for other car audio (larger sub or amps)
http://www.ebay.com/ulk/itm/191763665261
LocalMaxima
11-25-2015 08:11 PM
Finkle
11-21-2015 09:48 PM
