Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
MODERATED DYNOS: POST >>> HERE <<<
Old 09-24-2003, 08:03 AM
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
Moderated Timeslips Post >>> HERE <<<
Since the dyno post queue is broken on the new software for now, please post any dynos for the moderated section of the dyno forum in this thread. We will move them into the moderated section from here into the official section that way.
Please post them in the same format that you would in the moderated section as per the guidelines HERE
Originally Posted by Y2KevSE
We would appreciate if you followed these simple instructions before submitting your dyno number
  • In the subject line, use the format:
    XXX.X hp - XXX.X tq - YEAR TRIM TRANNY
  • In the message area, describe what car you have, what transaxle it is (manual or automatic), what mods you have, what gear you dyno'ed in, what model dynomometer you dyno'ed on, what the correction factor was (CF), what the air/fuel ratio was, etc.
  • You may post an image of your dyno graph
If you have a thread in the forum, please add new times to it (do not create new threads).
Please note: All threads/posts will be validated by a moderator before appearing in the forum. Not following these instructions might result in the denial of your thread/post.
The post below shows an example of what we are looking for.
Thanks,
- Maxima.org Staff
SteVTEC is offline
Old 02-06-2004, 11:10 AM
^ Jeff™
MrEous's Avatar
Please add the following chart to my already posted dyno sheet in the moderated section.
I have added Stone Racing Headers/Y-pipe since last dyno.
MrEous is offline
Old 02-06-2004, 12:22 PM
detailerdaveb@gmail.com
maximadave's Avatar
My 2002 6-speed -- no mods
maximadave is offline
Old 02-22-2004, 06:28 PM
Toolman's Avatar
430whp, 412ft lbs
1990 Turbo Taurus SHO , 12.5 psi
Why post a Tuarus? I figure we have similar engine designs/displacement/etc, so some of you might be interested.
mods: forged pistons, 60-1 HIFI, FMIC, EH intake, ungraded fuel system, cryo IC sprayer (390whp, 394ft lbs without sprayer)
Toolman is offline
Old 07-28-2004, 12:40 AM
A32Matt's Avatar
139.8HP-145.9TQ-'95 Auto SE
Magnaflow muffler, bypassed KS. i really don't like these numbers. Roll in pull until 100mph with O/D off.
A32Matt is offline
Old 08-19-2004, 03:59 AM
Zack342's Avatar
1999 Nissan Maxima SE-L
Car Now Has 103,993 miles on it
Car is a California Spec car
JWT Popcharger
Sun Automobile Hyperground System
Warpspeed Y-pipe
Catco High-Flow Cat.
Greddy SP Catback
10w30 Synthetic Motor Oil
93 octane shell v power gasoline
Car Ran 15.129@93.12MPH prior to exhaust install
Run Conditions 86.26 degrees F,29.82 in-Hg, SAE: 1.01
176.03WHP@5500RPM
190.86WTQ@4500RPM
Zack342 is offline
Old 10-09-2005, 02:21 AM
Old Maxima Legend
Ceasars Chariot's Avatar
182 hp - 194 tq - 1997 SE "Manual"
1997 Nissan Maxima SE
Transmission: Manual
Mileage: 160,000 miles
Mods:
-- Frankencar Intake/K&N Filter
-- Cattman Headers
-- Cattman Catback
-- Unorthodox Racing Underdrive Pulley
-- Technosquare Upgraded ECU
Dyno Gear: 3rd
Model Dynomometer: unknown
Correction Factor: 0.979 (SAE)
Dyno Graph
Ceasars Chariot is offline
Old 12-02-2005, 07:34 PM
killerVQ30DE's Avatar
Nissan Cefiro 1994 VQ30DE Auto
(MEVI installed but disabled)
K&N Pod filter
Standard exhust
Was gutted they tested in 2nd gear, I have mevi but the control solenoid wasn't working during the run.
Can some one please explain the air/fuel ratio, I think my car is running rich as I can smell gas from the exhaust is that what the lower graph is showing?
I also notice I have pretty good torque figures, I'm sure with a better geared run and MEVI working I would get closer to 120-125kw
Click here to see Video
killerVQ30DE is offline
Old 01-15-2006, 11:43 AM
ynot411's Avatar
239.12 hp - 245.25 tq - '02 SE 6SMT
2002 SE 6MT
Mods:
--- Injen CAI
--- Cattman Headers
--- Cattman Cat-back w/Power Tech Muffler
--- A'pexi S-AFCII
--- Place Racing Motor Mounts
--- HP Short Throw Shifter
--- And more...
239.12hp @ 5610rpm and 245.25ft-lbs torque @ 4400 rpm
Dynojet 248x, SAE Corrected (CF 0.96)
61.01 degree F 30.06 in.Hg.
248.54hp @ 5610rpm and 254.92ft-lbs torque @ 4400 rpm
Uncorrected
Video: http://files.filefront.com/23912whp2.../fileinfo.html
ynot411 is offline
Old 01-20-2006, 04:56 PM
Hoooper
194.4 hp, 195.5 ft.lbs 02 SE Auto
mustang dyno... y-pipe, injen CAI, 17* timing, DC muffler
Old 01-25-2006, 06:57 PM
95BLKMAX's Avatar
191WHP-195WTQ 95 SE 5-Spd
This was done on Dec 17th, 05. This was a Dynojet, not sure the model. These are STD #s, its the standard used at this dyno place. I had 121k miles at the time, running Mobil 1 10W-30 and 93 octaine gas.
Mods
-HAI with stock resonator box
-Port and polished IMs, slightly bored out TB
-WS Ypipe
-Gutted Cat
-Motostorm UDP
-5th Gen Clutch
-ES Motor Mounts
-SAFC-1
95BLKMAX is offline
Old 01-26-2006, 09:33 AM
Maxima Owner
MaximaSE96's Avatar
Dyno Dynanics Chassis Dyno
178.8 FWHP
185.5 FWTQ
Custom 2.5" Cat-back exhaust is the only mod
MaximaSE96 is offline
Old 01-30-2006, 08:00 PM
VQ35DE-T
shyestsparks's Avatar
This dyno was before cams:
shyestsparks is offline
Old 10-31-2006, 05:57 AM
95BLKMAX's Avatar
220WHP - 223.8WTQ 1995 SE 5spd
Mods-
-VQ35 Swap
-Short Ram Intake
-Modified 3.5 TB
-Motostorm UDP
-Greddy knock off AFPR
-3.0 stock headers/ WS Y-pipe
-Gutted cat
-Spec Stage2 clutch
-somewhat tuning with the SAFC (taken from the 10s and 9s up to the 12s, so not up to where it should be yet)
This is a dynojet. I hit the dyno the weekend after I got done with the swap. Keep in mind 2 things, elevation (for some DUMB REASON) is set to 4500ft. Also, i had an exhaust leak at the time.
I'll do a few more things to my setup (hush!) and retune.
95BLKMAX is offline
Old 01-15-2007, 10:26 PM
MaxpowerGLE's Avatar
dam, nice dynos you guys! I'm new to the maxima power area. I have modded my bro's 05 Type S hondata, etc and it ran low 14's a fun little car. And he now has a 12 Sec STi and I am very knowledgeable with those cars and some others, but the maxima, I really need help. I am currently an owner of a 99 Maxima SE 5 SPD and I am thinking of getting a stillen short ram intake, Greddy SP2 exhaust, custom testpipe, and a Stillen short shifter since the dam throws suck!!!! I am spoiled with driving a Type S and STi so when I jump back into the dam maxima it feels like a truck shifter. Especially when they both have short shifter kits on them. What do you guys think? What could my power numbers be like with those mods?
MaxpowerGLE is offline
Old 02-22-2007, 11:17 AM
gtr_rider's Avatar
posting for aic96max
Originally Posted by aic96max
gtr_rider is offline
Old 03-06-2007, 12:38 PM
viper32909's Avatar
2000 nissan maxima (auto) @ 60,000 miles
Any feedback welcomed.
2000 nissan maxima (auto) 60,000 miles
stock = 194.6 hp @ 5750, 211.6 tq @ 3750
50 shot = 206.9 hp @5500, 247.3 tq @ 3250
75 shot = 220.2 hp @ 5500, 272.2 tq @3250
Mustang Dynanometer
viper32909 is offline
Old 05-06-2007, 12:52 PM
renman's Avatar
172 HP 186 ft-lbs TQ - 1996 I30 Auto transmission
Dynoed on a Dynojet (not sure about model #) with the following mods:
Place Racing CAI with K&N Filter
Budget Y- Pipe
Budget B - pipe
5th gen muffler (lol)
Hayden 403 transmission cooler
VAFC II (not tuned at all until I get a WB O2)
Check out that drop after 4700 rpms! And my pretty flat AF curve.
renman is offline
Old 05-31-2007, 07:53 PM
520whpNashville's Avatar
i will be removed (hopefully moved) here goes as of now no dyno but in late june 07 i should be in the low 500 mark thats with nitrous used without im looking for 450 or so not sure on torque i feel i have one of the most built 4th gens and itll be ready in a month see it to believe it Crower rods CP pistons 9:1 full port polish blueprinted ss lifters apr headbolts ( a 7,000 block) I30 VLSD auto tranny built 2400 stall converter JWT cams & ecu flash matty kit with vortech supercharger sq 3.124 pulley 740cc inj. AEM wideband z32 maf stillen oil cooler tranny cooler intercooler NX wet with genx2 kit cattman hdr 3'' exhaust new time chain starter alt. everything. sway & strut bars jclaw traction control arm brace bushings tokico 5ways eibachs cut walbro 255 vortech FMU cold air intake cross drilled rotors with ss lines HIDs 8k R34 one piece blk. carbon hood & trunk tinted lenses huge weight reduction boston pro series boston amp eclipse head poodle hair & osterich bagaaaack !
520whpNashville is offline
Old 06-01-2007, 08:51 AM
Please quit posting about what you "think" you're gonna have! Haven't you learned by now? Two of your posts have been deleted in other threads for this same thing. I truly hope you break 500hp, but until then.......
No dyno, no care........
The Wizard is offline
Old 06-01-2007, 09:13 AM
96sleeper's Avatar
He will not make anything close to 450 or 500hp with a 3.125 pulley. We will believe it when we see it.
96sleeper is offline
Old 06-23-2007, 11:07 PM
2of9's Avatar
those are nice numbers!
2of9 is offline
Old 08-28-2007, 11:56 AM
DasYears
234.54hp - 225.17 2002 SE 6spd
2002 SE 6spd
Mods: custom intake, SSIM, 17* base tiiming (possibly 16*), y-pipe, race pipe, VAFC-2 tuned
CF's: STD: 236HP-229 TQ, SAE: 229HP-219 TQ (IIRC)
Rough conditions: 84*F, 30"HG, 22% RH
Pulled in 4th on dynojet 248x
Old 09-25-2007, 11:37 AM
636specman's Avatar
325.6hp - 347.3tq - 03 Sentra VQ 6Spd
2003 Nissan Sentra VQ35DE
Mods:
Custom Nismo Intake
Shorty Headers
FI-R Y-Pipe
Apex WS2
SAFC2
NX 51/26
Spec V 6Speed
dynodynamics 4th gear
636specman is offline
Old 02-15-2009, 04:48 AM
rich2342's Avatar
232whp/233wtq
rich2342 is offline
Old 02-15-2009, 04:51 AM
rich2342's Avatar
2005 Altima 3.5 Se
racingline y-pipe
nismo Exhuast
JWT clutch/lightweight Flywheel
rich2342 is offline
Old 05-14-2009, 06:28 PM
Toolie
knight_yyz's Avatar
253.7WHP-249.8TQ-03 SE 6spd
Here's my latest dyno.
HP mods are , cattman gen 3 headers, fastcat and catback, NWP spacers, custom short ram intake, tuned with greddy e-manage blue at 12.2 AFR WOT.
Non HP mods which contributed to the numbers, fidanza flywheel, exedy stage 1 clutch, and a brand new 06 6spd with HLSD.
knight_yyz is offline
Old 12-06-2009, 09:05 AM
HotshotVQ35's Avatar
mods in sig
HotshotVQ35 is offline
Old 10-27-2010, 10:03 AM
corykalina's Avatar
dynojet 2000. dont have the print out. 178 whp 192 lb-ft tq no air/fuel. dynamometer doesnt seem to give a/f for nissan lol injen cold air intake/ short ram greddy sp2 exhaust megan racing hi flow cat warpspeed y pipe ported intake manifold waiting to go on and i will dyno once more
corykalina is offline
Old 10-27-2010, 04:58 PM
ajcool2's Avatar
What year is your car and what transmission?
ajcool2 is offline
Old 12-16-2010, 09:44 AM
Nissan Unlimited's Avatar
**sorry Mods, i think this is where my thread should have been.**
Hey guys, I've told alot of people i would be posting this for everyone to get an idea what certain mods might do to your vehicle..
Car was Dyno'd @ Power Fab Automotive in Houston, TX
Unfortunately i never dyno'd in BONE stock, but i tend to say the vehicle is "stock"
Specs: 03 Nissan Maxima 4AT 74k (original engine/miles)
First run made 183whp w/:
1. Injen CAI
2. Stillen Ground Kit
3. Tsudo 2.5" Exhaust
Second Run made 193whp w/ only 1 additional part:
4. Megan Test Pipe
Cons about Megan Test pipe:
It DID NOT line up right. Test pipe was too long and needed
to be cut are Rewelded, Thanks to the boys @ Power Fab It was
taken care of!
If you can see close enough on the 193whp run, at about 5,500rpm it started gaining a bit horsepower until around 6200rpm it gained almost 16whp towards the top end w/ ONLY a Megan Test Pipe.
DYNO SHEET TIME!!!
*** This is my GFs Grocery Getter/Weekend Warriror/Daily Driver! Props goes out to her for understanding and Joining my Passion for Cars! Great support from her and i don't know how i would get through all my builds w/o her!***
Nissan Unlimited is offline
Old 12-16-2010, 07:02 PM
aackshun's Avatar
190.3 whp - 210.1 wtq - 1999 SE-L 5MT
Originally Posted by aackshun
^ My best run from march (apparently I did 177/190) vs. My best run today.
The A/F dipped to 13.5 but worked it's way back up to 14.8 (no A/F on my first dyno)
These vids are in HD btw, gotta love teh flip HD.
^ And no those are NOT the rollers you hear @ the beginning, that's my tranny.
Mod List in March:
Bomz SRI
Stock Shorty Exhaust Manifold
Warpspeed Y-Pipe
Magnaflow High Flow Cat (2.5 ID)
Stock Catback
Unorthodox Racing UDP
Amsoil 10w30XL
GM Redline Synchromesh 80w Gear Oil
G35 Coupe Rims (7.5")
Michellin Pilot Sport PS2 235/45/17
Around 170k miles on the original motor.
Final List:
Bomz SRI
OBX 3.5 Equal Length Headers
Magnaflow high flow cat (2.5 ID)
Cattman 3" Catback
Amsoil 10w30XL
Napa 80w Gear Oil
Hankook Optimo's 225/50/17
190,5xx miles on the original motor.
Both dynos in 4th gear.
There, that's it!
Please add! Thanks.
aackshun is offline
Old 02-16-2011, 03:13 PM
mightyMax95's Avatar
hmmm, well i guess i can update when i get my tune but...
solid line is first run, dotted is... not, lol. dyno was done in 4th gear.
car: 1995 Nissan Maxima GLE
mods:
- stock 3.0 w/~ 230k+ miles
- SRI (i think, lol)/autozone cone
- 00VI with custom, and very ghetto, adaptors; 4th gen TB; functioning 4th gen IACV; 4th gen fuel rails/injectors
- WS y-pipe
- stock cat
- 2.5" cat-back, crush bent with thrush turbo muffler, no resonator
- 6 speed MT with 4.133 final drive ~60k miles
- 3rd gen sawblades with stock 205/65/15's
- ebay fstb if anyone cares, haha
dunno if it matters but i spun off my idler pulley on the first run, , lol. so the only thing connected for the second is powersteering (no alt or a/c)
mightyMax95 is offline
Old 10-18-2011, 04:52 AM
ranmas2004's Avatar
2002 Maxima SE 6 Speed
MODS: Cattman Headers, Fast Cat, 3" catback exhaust, Stillen UD Pulley, NWP Spacers, Custom Short Ram intake, AEM filter w/ BPI Vstack.
Other Mods: Fidanza Flywheel, SPEC Stage II Clutch.
NO TUNE, NO SSIM, NO LRMAF, NO 3.5" Intake Tubing!!
Run 1: 256hp & 250 ft-lbs.
Run 2: 258hp & 249 ft-lbs.
Run 3: 259hp & 251 ft-lbs.
Run 4: 256hp & 247ft-lbs.
LAST 2 RUNS:
ranmas2004 is offline
Old 02-03-2012, 08:46 PM
RotaryHead's Avatar
140hp - 160tq -- '89 Manual
'89 GXE 5 Speed
VG30
Mods:
-Custom Y-pipe
-Custom Duel Exhaust 2.5" to 2.25"
-Custom Intake With Velocity Stacks
-No Cat
-MSD 6AL-2 w/ Blaster SS Coil
-Exhaust Wrap
DynoJet Dyno
4th Gear Pull
140.3Hp @ 5300 160.0 @ 3200
RotaryHead is offline
Old 08-21-2012, 11:27 PM
ajahearn's Avatar
Dyno before and after CAI.
I posted this along time ago when I was evaluating a cold air intake. There was a lot of discussion about whether my dyno was accurate given that the before and after had been done over a 6 month period. I will leave it to the reader to decide. The first 3 pages shows the dyno runs with the stock car, at the time it was 7 months old, but using summer fuel. The last page shows the dyno runs with the Injen CAI installed, the car now 12 months old, but using winter fuel. I have not exhaustively looked but what I read does not suggest that winter versus summer fuel will cause this kind of torque degradation.
The CAI was definitely louder than stock so if that is what you like then I would certainly suggest it. Floor the throttle and there is no mistaking that sound. But a drop in almost 20 lbs torque just didn't seem like a positive to me so I pulled it and sold the CAI.
I'm going to do the 100k plug/coil change and I will probably do another dyno run to see where I stand.
ajahearn is offline
Old 08-22-2012, 06:34 AM
dot dot dot ...
NmexMAX's Avatar
Can you post a link? That would be helpful.
Also, I've been charting my dyno runs since 2005, some in the summer, some in the winter (Dynojet, so variable correction factors), but, with Dynojets, I'm confident it's as close to apples to apples as you can get, especially if it's the same machine, which in my case, it has been.
NmexMAX is offline
Old 08-22-2012, 09:03 AM
ranmas2004's Avatar
This is why I like Dynojet, regardless if people say they read high or not. With a Dynojet it is what it is, there is not inputting anything to change the dyno. With other dynos you can put in inputs to make dyno read higher or lower, depending on who is dynoing, but with Dynojet you cant do that and thats the reason I like dyno jet. Take a car making 260whp on a dyno dynamics and put it on a dynojet....I guarantee it will make a different number. Another thing I love about dynojet is that you can get runfiles and just view and them in detail and make different graphs of them and share them with anyone that has the runfile viewer (which you can download for FREE off the dynojet website). I haven't seen other dynos that offer this. With the other dynos you just have to take a pic of the dyno on paper unless there is something I dont know....
Old 09-14-2015, 06:52 PM
kasey07's Avatar
04 Spec V VQ swap
04 Sentra SER Spec V
05 350z CX ECU
Headers with custom true duel exhaus
4"intake/NWP big bore throttle body
Unported plenum wit VIAS delete
LW Stillen flywheel
2JR clutch
2JR dyno jet tune
2003 maxima lsd trans with 3.8FD
Car made 267whp/257wtq
kasey07 is offline
Old 10-10-2015, 09:50 AM
schmellyfart's Avatar
kasey07, what changes were made between the two runs on that graph?
schmellyfart is offline
Quick Reply: MODERATED DYNOS: POST >>> HERE <<<
