Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Schmelly's VQ35 Swap Dyno
Old 10-19-2013, 10:37 PM
schmellyfart's Avatar
Finally got a chance to dyno the swap today. I decided to spring the extra $10 for an AFR reading since my EU is disconnected. Grand total: $30 for two pulls.
Same shop/dyno I used for my previous pulls with the 3.0.
Minor changes that might affect readings:
~New tires 245/50R16.
~Finally had the car aligned after the swap.
Current setup:
+02 VQ35 w/3.0 timing, DE-K Injectors & FPR, return fuel setup
+Stock 5th gen intake w/ bomz cone filter
+PFTB
+NWP BOP
+NWP 5pc spacers
+Altima headers w/ 3" y pipe back
VQ30 Spark Plugs
Fuel and timing are bone stock, no adjustments made.
236.96whp/221.51wtq
schmellyfart is offline
Old 10-19-2013, 11:59 PM
D I R T Y I 3 0's Avatar
Lol wot, wow I have missed a lot. The max has come a long way man
D I R T Y I 3 0 is offline
Old 10-20-2013, 07:42 AM
I've only been swapped for 8 months now.
Old 10-20-2013, 07:54 AM
95naSTA's Avatar
Nice #s for the mods.
Is this a baseline for other things like a more agressive tune, larger intake, etc. ??
95naSTA is offline
Old 10-20-2013, 10:07 PM
I plan to go back and rent some dyno time to test a bunch of parts. SSIM, MAF, Intake, TB and maybe the stock VIAS depending how well the tune helps my low end because the power sucks under 3700rpm.
Old 10-21-2013, 04:06 PM
Rods03Max619's Avatar
Nice Numbers man...
Rods03Max619 is offline
Old 10-23-2013, 06:01 AM
Damn, still a decent amount of time. Nice work man, I want to learn how to do engine swaps one day
Old 10-24-2013, 11:12 PM
Nice Numbers man...
Thanks man. You gonna hop on the dyno anytime soon?
Old 10-25-2013, 02:39 AM
Fakie J Farkerton's Avatar
6 speed swap it with an '04+ Sentra SpecV and get that 4.1 FD.
Fakie J Farkerton is offline
Old 10-25-2013, 04:25 PM
Its on the todo list. Just waiting for a good deal.
Old 10-25-2013, 04:41 PM
Let me know if you find the hook up on a timing ring for it.
Old 10-25-2013, 10:16 PM
Will do.
Old 10-26-2013, 02:56 PM
Yeah going to try hopefully before the 15th of Nov...
Old 10-26-2013, 09:31 PM
MaxPR0908's Avatar
nice..
MaxPR0908 is offline
Old 10-31-2013, 05:05 AM
Turbo 3.5
t6378tp's Avatar
nice #'s just need to lean it out alittle and throw some timing at it and get the mid 240 range, maybe even 250
t6378tp is offline
Old 10-31-2013, 06:47 AM
dot dot dot ...
NmexMAX's Avatar
I bet that thing boogies! Thanks Johnathan.
NmexMAX is offline
Old 10-31-2013, 08:13 AM
My goal is 270 before heads/cams if I do go that route. Whether or not it's attainable, I'll find out one way or another.
Originally Posted by NmexMAX
I bet that thing boogies! Thanks Jonathan.
Quick and dirty I want the car running intake. I chopped off the MAF flanges a while back so I couldn't use the 5th gen airbox as well.
Old 10-31-2013, 10:57 AM
dot dot dot ...
NmexMAX's Avatar
Ahhh, I made a lot of power (233/231) with minimal mods with my JWT set-up just like that, headers, & 17ºBTDC.
Hoepfully you've got a V-stack in there.
NmexMAX is offline
Old 10-31-2013, 11:06 AM
Nope, its just a cheap 3" filter that came with my eBay sri years ago.
Old 10-31-2013, 02:18 PM
dot dot dot ...
NmexMAX's Avatar
Either way, that's the best bang for the buck before starting the modded MAF scheme. In my experience anyway.
NmexMAX is offline
Old 11-02-2013, 07:11 PM
I have a couple velocity stacks sitting in the garage. Just need to get some ECU wiring issues sorted out before I can do any tuning.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
mclasser
22
11-12-2020 01:58 PM
ef9
10-04-2015 08:43 AM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: Schmelly's VQ35 Swap Dyno
