OIl filter top by-pass valve. How important?
I don't mean to start another mindless debate on oil filters, or argue which is the best brand. But I haven't found much at all about this topic when I searched. I am curious on opinons regarding the importance of a top by-pass valve on an oil filter versus one located on the bottom of the filter.
As I understand it, the value of a top by-pass valve is that it substantially lessens the possibility of oil flowing back over the dirty side of the filter in the event the filter actually goes into by-pass mode, and then reintroducing that dirt to the engine again. I for one could never tell if a filter runs in by-pass mode. But IF it ever did, flushing matter big enough for the filter media to catch in the 1st place back into the engine strikes me as a big bad boy, and a fairly important consideration in selecting filters. Especially the longer a filter is in use.
My question is, is it even worth worrying about? Especially when you consider that most filters (as best I can determine) have that valve located on the bottom of the filter, not the top...including Nissan oem, Mobil, Bosch, Purolator, K&N, SuperTech, Fram, and STP (I think). Brands I've found with the top by-pass are few: Motorcraft, Wix, and NAPA Gold. I simply don't know about the rest, like Amsoil, Hastings, AC Delco, & Baldwin.
To me, as one prioritizes filter features, this one ranks right up there with good anti-drain back valves and may be more important that media efficiency. But it also thins down the field of contenders considerably.
Does it depend on application (normal vs extended drain)? Am I making this more important than it needs to be? If not, why are there so few filters with the top by-pass design?
Obviously , Chuck.
Obviously , Chuck.
As per the EvilBill
Quoted by Bill Oil Master Guru
VQ Oil Filter Part Numbers
VQ30DE and VQ35DE models (OEM uses M20 x 1.5 thread type and 14 psi bypass valve):
Oversized:
Optimum filtration at 20 microns
STP: S6941 ($6.99) 17-22 psi bypass valve
Purolator PureONE: PL24458 ($5.99) 8-10 psi bypass valve
Amsoil: SDF-36 ($9+) 7-9 psid bypass valve
OEM sized:
Optimum filtration at 20 to 25 microns
Nissan OEM: 15208-9EOOO or 15208 -00001 (newer number) (approx. $4 - $6 at dealer) 14 psi bypass valve
Nissan OEM: 15208-00006 (new on late 2k1 to 2k3 Maximas) 14 psi bypass valve
Amsoil: SDF-20 ($10+) 20 psi bypass valve
Optimum filtration at 15 microns
Bosch: 3323 ($5.49)
Optimum filtration at 10 microns
Mobil 1: M1-110 ($12)
Purolator PureONE: PL-14620 ($5.99)
Thimble-sized:
Supertech: ST6607 ($1.97); available at Wal-Mart only
STP: S6607 ($2.99)
Amsoil: SDF-13 ($12+) 12-16 psi bypass valve
Mobil 1: M1-108 ($12)
Purolator PureONE: PL-14622 ($5.99)
Oversized:
OEM sized:
Bosch: 3323 ($5.49)
Thimble-sized:
STP: S6607 ($2.99)
Originally posted by VQ35DE
The M1-110 is longer than the 108 & 106, the 104 is no longer than 110 but larger diameter, and 105 is same length as 104 but even larger diameter than 104.
I have a VQ30DE engine
I've used the Mobil 110 and the Bosch 3323. The by pass valve on them sure looked like it was on the bottom of the filter to me, not the top. I'll have to give the 105 a look see next time I'm in the store to inspect the valve location. The Wix 51356 clearly has a top valve, and seems to fit the "oem sized 20 micron optimum" category.
I've used the Mobil 110 and the Bosch 3323. The by pass valve on both sure looked like it was on the bottom of the filter to me, not the top. I'll have to give the 105 a look see next time to see where the valve is located. The Wix 51356 fits the VQ30, and clearly has a top valve. It seems to fit the "oem sized 20 micron optimum" category. No NAPA store is close to me, but I know Wix makes the gold line for them.
I guess I'm just curious on the need for and perceived value of a top located by-pass valve.
JoshG
51
09-21-2015 10:41 PM
97_GXE
20
09-17-2015 08:12 PM
97_GXE
09-15-2015 06:47 AM
sdotcarter
09-02-2015 09:53 PM
