How to change manual transmission fluid? Which fluid: GL-4 or GL-5? Best gear oil?
#122
Sorry if this is an old question, but I can't find an answer. What did you use to take the drain plug out of the transmission? Mine started to round off with a 12mm wrench. Should I use another tool, flare wrench? Any help is much appreciated, and do LSD trannies, such as in a 01 AE, need a limited slip additive? Thanks again for the productive comments.
#123
I just used the wrench -- but did the change with only 30 K miles (and two years) on the car. The longer this plug has remained in place, the harder it will be to loosen and remove. You might try spraying the plug with Liquid Wrench and letting it sit on the plug over night. I don't have any other suggestions, sorry.
#124
Hi all:
I used to post here back in 1995 when I purchased my new 95SE max with 5 speed MT.
Recently, my 5 speed transmission position sensor switch started leaking and was replaced by my Nissan dealer. During the job, they topped off the fluid that was lost. It occurred to me that it might be a good idea to completely replace the MT fluid - especially now that I have a blend of the OEM fluid and the dealer fluid. The dealer says they use Chevron Manual Transaxle Fluid GL-4 SAE 75W-90. According to the Chevron site this product uses ISOSYN base stacks and synthetic polymer. The dealer also had Nissan branded MT oil but it was 75-85W. They felt the Chevron was a better choice based on the higher 90W spec alone. They said they only use the Nissan oil for warranty work.
My service manual has no clear choice for SAE weight but it seems 75-90 is a good choice based on upper temperatures expected. Is the Chevron GL-4 product a good choice for a complete drain and refill job? Thanks
#125
I would spend a few bucks more and replace with GL-4 fluid from either Amsoil or Redline. I used the Redline 75w90 fluid because, at the time, Amsoil did not have a GL-4 fluid -- they now do.
If you decide on Amsoil, contact Talkinghorse on this site; he will sell you Amsoil products at a discount.
#127
You don't want a multi grade gear lubricant -- you want a straight GL4 lubricant. Anything else could damage your trannie. I know for a fact that Talkinghorse will not sell you an Amsoil product that is not correct for your Maxima. The people on craigslist will sell you anything, even if it is not correct. Don't save a few bucks on the fluid only to damage your trannie.
#128
So this is not the same stuff as people earlier in the thread were talking about when they said they used Series2000 75w-90 ?
And I didn't plan on putting it in until I was sure it was the right stuff.
I'm not trying to just save a few bucks, I just saw it and jumped on it before someone else had a chance. For 12$ I can find some other use for this, or eBay it if it wont work.
#130
How can anyone possibly tell you where to buy it locally when you don't state where you live?
You should be able to get it at any performance shop? I live in British Columbia and can't help you apart from that. Locally I can get it in several places in Greater Vancouver, so I'm sure you can find it if you try.
Why don't you post on the relevant Regional Forum?
#131
woops... sorry... i coulda sworn i entered in the area....
anyways.... i live in Ft lauderdale FL.
i have checked autozone and advance auto parts.... nothing.
#132
I replaced the dino over 35k ago with the series 2000 amsoil....the logic THEN was that it was okay. I know now that was flawed logic.
I can only imagine what it's done to my tranny.....
Get the AMSOIL GL-4.
Don't bother looking locally - you WON'T FIND IT.
I found a local guy who sells amsoil, but even HE didn't stock the GL-4.
gr
#133
OMG.... im trying to do this... i might be a weakling or something... but i cannot get those plugs to break loose.... is there a certain way to position car... on a jack stand or something to get more leverage....
i need help .... my car is on the stand at the front right now... with a 10mm hex on the drain plug..... need a way to break it loose.
#134
This has to be finessed. Try spraying some liquid wrench in the area of the threads. Give it about 30 minutes to sink in. Then try shocking the plug by lightly pounding on the wrench handle with a rubber mallet. Make certain that the 10mm hex is fully in place while doing this.
If that does not loosen the plug, repeat the same steps above to try and loosen it with liquid wrench.
If you have enough room, you can slide a longer pipe over the wrench handle to get more leverage. But my memory of when I did this process is that there is not much room to do this (unless you are up on a high lift).
Good Luck.
PS: This is why it pays to do this change about every 25 to 30 K miles. Since I now have 35 K miles on my last change, I need to do one again before next summer.
Good Luck.
#135
Good Luck.
Good Luck.
ok thank you... im going to try the rubber mallot or finding a longer ratchet...
as far as the liquid wrench.. iv never heard of it.... but would WD40 be a good substitute?
and also.... is it easier to have the car on the jack (the small kind) or removing any of the wheels?...
#136
Final thought, did you go to the sites that show pictures of your trannie? I found that lying on my back looking up, it was not easy to easily identify the two plugs that needed to be removed. Check the pictures to be certain you are removing the correct plugs.
#137
I would suggest only using a breaker-bar when pounding with a mallet. You don't want to damage the ratchet mechinism in that wrench. This is the job breaker-bars were designed to do -- break loose tight connections.
Liquid Wrench is even lighter weight than WD40 and can penetrate the threads better. As a poor substitute, the WD40 may work.
I had mine up on 2 jack stands -- safer than on any jack (I have a hydraulic floor jack, but still use the stands too). If you have reasonably good light, you don't need to remove any of the wheels.
I got it done...
i dont have a breaker bar... so i took my ratchet and had another long wrench... used the little hole on the end and looped it through my ratched handle... and bought me some leverage... (i hope u understood what i was trying to say)
did the refill... everything....
i do think i did something wrong though... i didnt get new gaskets... and when i was retightening the plugs... i think i tightend really hard... i saw the gaskets bend...
#138
I bought new gaskets from the Nissan dealer, but when I looked at the old ones, they looked just fine. Since I did not pay much for the new gaskets, I used them -- but the old ones (at 30 K miles on the car) looked like they would have done the job, too.
If you did not crack the gaskets, you should be fine.
#139
Been reading a lot of threads in preparation to do this but had a few questions:
1) Does anyone have part #s for the gaskets (you need 2 of them right)?
2) Do people generally prefer amsoil or redline, or is there no real difference?
3) Assuming you use the drain plug, there is no sensor (the one people seem to break) in there right?
4) For those who order amsoil, where do you get it from. I think there is a member here (talkinghorse) but are there any other places to check?
#140
2. I can't comment on differences between AMSOIL and REDLINE, but I like AMSOIL. I don't remember Redline offering a GL-4 blend....
3.No sensor.
4.Talkinghorse will hoook you up, and WITH a discount. I've ordered from him, and he is FANTASTIC! I looked no further....
gr
#141
ghost got it right.
I am using Redline GL-4 because when I bought the fluid, Amsoil had dropped the GL-4 product and talkinghorse would not sell me any other product that was not a GL-4. Shortly after that, Amsoil brought back the GL-4 fluid. When I do my next change, I will be going to that Amsoil product.
#142
ghost got it right.
I've been running the prev. gen. Amsoil 2000 for almost 20k miles, and the gearbox is getting crunchy.
...can't remember who sold it to me, but they shouldn't have!
I just got my Gl-4 and Power Steering FLuid (ATF) from Talkinghorse today, and I'm going to flush & swap it all today. Just in time too...it's getting cold here finally!
gr
#143
thanks gr, you are the resident expert
Is there more than one "gasket" or "crush washer" that I need? Is it one for the drain plug and one for the fill plug or just one for the drain plug. Seems like it would be only one for the drain plug?
#144
I'm going to drain mine today - I'll let you know if there's two washers or not.
Again - I wouldn't worry about it. Not really money well-spent considering it's low pressure, and these things get removed once every 4yrs or so....your choice though.
gr
#146
I see you have an 01, so forget about the crush washer. You won't be able to undo the drain plug in your driveway. There's a bracket that gets in the way and it's nearly impossible to remove the plug when lying on your back. I say try it, but be ready to go the sensor route and have alterante means of transport if you need to go to the stealer to get a new one...
#147
And remember, open the FILL bolt first then the drain bolt.
#148
Chevron Delo Synthetic 75-90 or Mobil 1 synthetic?
Hi all:
I understand the Chevron manual fluid GL-4 has been replaced with Delo Synthetic. Any opinions as to whether Mobil 1 gear oil or Chevron is better for my 95 Max 5 speed?
https://www.cbest.chevron.com/msdsSe...e&lbLanguage=e
#149
Is Mobil1 75W-90 Ok to use now?
Hi all:
There have been some posts in this thread that says we shouldn't use Mobil1 synthetic and to remove it from the initial post of this thread. but....
According to:
http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
it says that:
Mobil 1 Synthetic Gear Lubricant LS 75W-90 is recommended for use in modern high performance automobiles like SUV's, Vans and Light duty trucks requiring API GL-5 and MT-1 level performance
Mobil 1
Synthetic gear Lubricant LS 75W-90 is intended for initial fill, topping-off or refilling differentials, final drives, transfer cases and other gear applications where lubricants meeting API Service GL-5 and multi-purpose or mild EP gear lubricants are recommended
Mobil 1 Synthetic Gear Lubricant LS 75W-90 can also be used in rear axles where API Service GL-4 lubricant is recommended "
Do you folks think that it is really OK for a 95 Max with 5 speed manual transmission? I have the factory service manual for the car and it calls for GL4.
According to:
it says that:
Mobil 1
#150
If it says anywhere on it that it can be used for GL-5 service -- you should stay away from it. You want a fluid that is only made for GL-4 service. Anything else will be wrong -- even if it says it can be used in GL-4 applications. Better to be safe than sorry.
Just order some Amsoil GL-4 lube from talkinghorse on this site. He gives you good prices and will not sell you anthing that should not be used in your Max.
#151
#152
Bumpin this up, I have both the fill plug and the drain plug cracked and ready to go.
1) I just waited an extra day to pick up the drain plug washer (gasket, whatever you call it) from the dealer. I went in there and of course they don't have it (despite telling me they have it in stock, I called multiple times). Tech says they never replace them. Should I wait to get one, or just get on with it? Is it really a special washer? Can I get one anywhere else but the dealer?
2) I just want to make sure I cracked the drain plug, have I circled it correctly in the pic attached?
#153
Just do it.
I've changed my tranny fluid twice now, and not bothered to change the washer.
TOTALLY unnecessary.
I can't tell by the picture what that is.
Your drain/fill plugs should be recessed hex (five point) and I believe it's 10mm.
The drain will be lower on the trans. housing and futher towards the back of the car.
gr
gr
#154
just an "as i'm doing it update" That picture is taken from one of the writeups on the first page and I did correctly circle the drain plug as the fluid came rushing out
Oddly enough drain plug doesn't even have a washer?!
#155
That's unusual. When I changed mine, the washer looked good enough to use again. Because I had a new one, I used it. But suspect that the old one would have been fine.
Without a washer on your plug, my advice is to watch to be certain that you don't develop a leak at the plug.
#156
well danger averted, the crush washer for the tranny is the same as the one for the oil drain plug and I had a bunch of those around. It's made of copper and crushes when tightened on. This is for an 01 5spd
My experience (for anyone who comes after)
1) I was able to do it WITHOUT lifting the car off the ground at all (nice because it has to be level). I am STOCK though, as far as height goes.
2) I was able to squeeze and air gun to free the fill plug from it's rust weld. That made that easy
3) I was able to get the drain plug off with an open ended wrench and a little muscle
4) PB blaster/liquid wrench for everything
5) I had to take my battery out to get the fill funnel to fit in there (probably just because of the funnel I bought)
#157
It was not necessary in my 04 with the proper funnel and extra tubing. (I just used the same funnel and tubing to change the differential fluid in both differentials in my 4-wheel drive Dodge pickup truck.) Get the right equipment, and you don't need to remove the battery. The funnel sat right next to the battery and the tubing reached down into the trannie fill hole.
#158
Well I drove today for my first extended time on the amsoil gl-4, I have to admit I wasn't overly impressed. I figured it might not feel any better but it actually feels a bit more notchy (especially 3rd and 4th).
Does the fluid have a break-in period of any kind or anyone else experienced something like this?
#159
#160
Maxima.org Sponsor and Donating Maxima.org Member
