Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
*Question regarding the installation of a new oil drain plug washer...*
Old 07-04-2003, 12:45 AM
clipse's Avatar
I know it's probally a stupid "newbie" question to ask but which side of the washer should be facing when installing. I personally never seen a washer like this before(I'm used to the flat washers) I'm going to be changing my oil tomorrow morning,So any help will be appreciated. Thanks.
Here are some pics:
clipse is offline
Old 07-04-2003, 06:59 AM
VQ35DE's Avatar
Screw the drain plug in from the side facing up in the 2nd (lower) PHOTO.
VQ35DE is offline
Old 07-04-2003, 07:22 AM
clipse's Avatar
So basically have the "new" washer facing up like the second photo when installing it???....
clipse is offline
Old 07-04-2003, 08:09 AM
clipse's Avatar
clipse is offline
Old 07-04-2003, 08:25 AM
Evil Administrator - "The Problem"
bill99gxe's Avatar
you want the flat side of the washer to butt up against the bolt. You want the rounded side of the washer to face the oil pan so it "crushes" against the oil pan, which is more likely to have surface "irregularities" more so than a bolt.
bill99gxe is offline
Old 07-04-2003, 10:10 AM
clipse's Avatar
bill99gxe,Thanks again
clipse is offline
Old 07-09-2003, 12:57 PM
Nissan-R's Avatar
It is neccessary to replace the washer with a new one everytime one changes the oil?
Nissan-R is offline
Old 07-09-2003, 02:26 PM
VQ35DE's Avatar
Yes.
VQ35DE is offline
Old 07-09-2003, 02:46 PM
bill99gxe's Avatar
Either yes or don't use one at all. I haven't had a leakage issue whether I have used one or not.
Old 08-19-2003, 07:14 PM
Pointy Elbows
00MaxSE's Avatar
Do we get these at the dealer?
00MaxSE is offline
Old 08-19-2003, 08:56 PM
Bman's Avatar
Yes, although I imagine any parts store should have them. They're nothing special. My dealer taped one to the box of my Nissan filter without asking.
On a side note, this is the first time I've changed my washer and I discovered I had 2 very thin copper washers mashed up against the bolt. I don't know who did that, but I wasn't impressed with how much trouble they were to pry and mangle off.
Bman is offline
Old 08-20-2003, 08:06 AM
Nissan-R's Avatar
Once you compress the washer, it becomes this way.
Nissan-R is offline
Old 08-20-2003, 04:32 PM
Pointy Elbows
00MaxSE's Avatar
Yeah I think my drain plug is like taht too.
00MaxSE is offline
Old 10-20-2003, 08:52 PM
maximaisokay's Avatar
what the heck are those pictures? What is a washer?
maximaisokay is offline
Old 11-16-2003, 02:22 AM
wcasskicker's Avatar
If you go to the dealer, the washer is called Drain plug gasket, it's copper color. Change it every oil change, or oil leak will occur from the drain plug.
wcasskicker is offline
Old 11-16-2003, 10:51 PM
SunMax's Avatar
I am with Bill on this. My mechanic has been reusing that an old washer for two years. Last week when I did the oil change myself, I decided to change it anyway cause it costs ~$0.60.
Based on the original position, I put the washer up on top of the drain plug as picture #1.
SunMax is offline
Old 02-24-2004, 01:46 PM
dannodotcom's Avatar
I have been doing oil changes on my vehicles for 30 years and have never replaced a washer, never had oil leak from the drain plug either. Had my Max (2000 SE) for 7 months now and have done 2 oil changes and have not replaced the washer and there is NO leak. When I do an oil change, I make sure to clean both mating surfaces (plug and pan). If a leak develops there then maybe I'll change my position on changing washers.http://forums.maxima.org/newreply.ph...ply&p=2484781#
Dannodotcom
dannodotcom is offline
Old 03-18-2004, 11:18 AM
2002 Maxima SE's Avatar
My wifes 93 Sable has been leaking from the drain plug for a long time. I went to PepBoys to see if they had a copper washer for her car.
They had two types of drain plug washers:
1)Nylon (with three raised inner rings on both surfaces)
2)Gasket material
I opted for the Nylon and the leak stopped. These came in a pack of 3 for $0.99. I'm thinking about switching to these for the Maxima, no use is spending $0.90 (my dealer price) on copper crush rings. I'll post a picture later.
2002 Maxima SE is offline
Old 06-14-2004, 12:19 PM
00Max00's Avatar
My local dealer Rothrock Nissan charge $2.40 each. That was insane!!!
00Max00 is offline
Old 10-31-2004, 04:55 PM
OU > *
S00NR1's Avatar
Ya, Bob Moore Nissan here in Norman charged me $1.25 each and I thought that was a bit steep.
S00NR1 is offline
Old 01-02-2005, 05:17 PM
Burny's Avatar
I just did a change in the 04 Max yesterday. 5th one since wife has had the car. I tried to get the washer off but couldnt. Just left it on there. I've been doing oil changes for over 20 years and never had a leak due to a washer not being used or replaced.
Burny is offline
Old 02-12-2005, 04:34 PM
kcryan's Avatar
just thought id let you know ive got a slow leak that i attribute to this, but not a question is it ok to use one made of somthing like a plastic thats pretty darn hard, its what autozone sold me
kcryan is offline
Old 04-05-2005, 03:42 AM
hpro123's Avatar
I would not use a plastic anything down there. It may indeed be the source of your leak.
hpro123 is offline
Old 05-08-2005, 10:11 AM
I miss my VE
VEvolution's Avatar
i still don't understand the point of using a washer on the drain plug. the FSM says to, but seems nobody cares. and in reality, seems doesnt make a difference. or am i wrong?
VEvolution is offline
Old 05-20-2005, 03:28 PM
Pervis Anathema's Avatar
I have had my car for over 4 years. In that time, I have changed my oil 23 times. Of those 23 oil changes, I have never replaced the drain plug gasket and I have had never had a leak from the drain plug.
Pervis Anathema is offline
Old 05-20-2005, 07:11 PM
I miss my VE
VEvolution's Avatar
yeah.. i guess that washer was one of nissans back-up plans for an anti-leak situation
im still feeling like getting one just cause the FSM says so just to feel complete. just dont know why they only tell u to run some oil around the rubber seal on the oil filter and not put any inside.
Old 06-03-2005, 03:55 AM
pruizgarcia's Avatar
I have never replaced the washer and have never had a leak. My thinking is, "If it ain't broke, don't fix it".
Pedro
pruizgarcia is offline
Old 08-14-2005, 03:50 AM
Brushedpewter's Avatar
Pedro
same here. My dealer gave me that washer but I just put it somewhere. I'm still on the original drain plug and washer, meaning it came from the factory.
Brushedpewter is offline
Old 10-19-2005, 03:53 PM
twinkle's Avatar
cause if you do on the VG it will all leak out when you install it, but on a VE its a good idea
twinkle is offline
Old 10-19-2005, 05:13 PM
I miss my VE
VEvolution's Avatar
It was hard, but I got it in on the VG.. Thing is though, I don't think under the VE section it says to put oil in either. I still do though.
Old 10-24-2005, 10:24 AM
I Know Kwaliti
igzy's Avatar
Changed the oil 14 times on my Max so far, I think the original washer is still on the plug... Never replaced it and never seen any signs of leakage... What I do is before I drain the oil, check the oil pan for signs of leaking and if I see any around the plug means it may be leaking, if not - all good... Drain and replace...
igzy is offline
Old 05-19-2006, 08:40 PM
Part of washer broke off and I can't get the other part off. I have to get a new drain plug and a new washer. Car is sitting in the garage with no oil.
Old 05-21-2006, 12:34 PM
kcryan's Avatar
Pliers should get it off, cant be that hard its just a little piece of metal man, get some muscle in there....
kcryan is offline
Old 05-23-2006, 01:30 AM
I couldn't get it off and I even took it to the dealer and they couldn't get it off. They sold me a replacement but it looked different from the original one. The whole experience sucked because I couldn't move my car. The dealer was like "Why don't you just put it like that on the car, the bolt is designed in such a way that you don't need to put the washer on there"
This is coming from the dealer that we leased a new altima from. The engine flodded once, cam position sensor broke, the windows rattle inside the doors had to be "welded" several times, the drivers door handle is broken, engine is leaking oil even AFTER getting this fixed at the dealer, and engine sometimes magically loses power on the freeway. The leased car is 2002 Nissan Altima.
My car is a 1999 altima, if that happened to my car I would of burned it or driven into Mexico and left the keys in the ignition. Seriously no more Nissans, my car is problematic too.
Old 05-23-2006, 09:56 AM
I miss my VE
VEvolution's Avatar
Whos car isn't problematic?
Old 05-24-2006, 06:36 AM
My dad's. He bought an accord.
Old 08-30-2006, 09:20 PM
maximas2005's Avatar
How do I replace the sparkplugs on my 95 Max????
Does anybody know how to replace the sparkplugs on a 95 Max????
maximas2005 is offline
Old 08-30-2006, 09:33 PM
I miss my VE
VEvolution's Avatar
You seem lost.. http://forums.maxima.org/forumdispla...ysprune=30&f=9
Old 09-18-2006, 05:51 AM
maxout!'s Avatar
someone probably already recommended this. here it is again
FRAM sure drain oil plug/valve
get it, use it, live it!
maxout! is offline
Old 09-18-2006, 07:39 AM
I miss my VE
VEvolution's Avatar
Whats that?
Quick Reply: *Question regarding the installation of a new oil drain plug washer...*
