Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
AFT fluid in CVT HELP
Old 07-25-2014, 09:52 PM
mikeo6000's Avatar
Hello all, I have a slight problem at hand. I purchased a 2009 maxima sv with 129,000 miles a few months ago. The car has run very well and now have 137,000 miles. I brought the car to dealer ship for transmission fluid drain/refill and i was told by the dealer that the transmission fluid in the car is a red ATF fluid and it will require a tranny flush ASAP or more quarts of ATF fluid will remain in the system after doing a drain/refill. I refused to flush and told the dealer to proceed with drain/refill. The dealer completed the drain/refill and charged me 209 dollars. Now i want to get rid of the remaining transmission fluid so should i drain/refill with a CVT transmission fluid 3-4 more times within 100 miles interval? or should i do a transmission flush through the inlet port using a CVT fluid?. Doing a transmission flush through the inlet port will only involve turning the engine on &off and draining & refilling 1 quart fluid at a time until old fluid is out of the system. Which of the 2 solution will be the best and safest approach? I plan on doing this job by myself
mikeo6000 is offline
14GmMax
59
08-04-2019 11:26 AM
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
Maxxx10
09-13-2015 03:16 PM
Quick Reply: AFT fluid in CVT HELP
