Forced Induction Sell your turbos, supercharger, nitrous, and related items here
FL Split Second Additional Injector controller
Old 03-27-2014, 09:29 PM
aic96max's Avatar
Split second additional injector controller
Built in Map sensor
Tach wire input
2 injector control per boost/rpm
I will include 2 x 440cc injectors
This is a simple way to tune additional fuel while maintaining all factory electronics / maf / ecu etc. This is a little more work to setup than safc2 but works better. no dealing with mafs , changing in the way the car runs , mpg .
for low boost that you can run stock timing this is a great way to tune.
My old maxima made 393 whp with 2 injectors on the charge pipe. I kept the factory suck through maf, stock injectors, still ran 24 mpg.
$200 shipped OBO
aic96max is offline
Old 03-28-2014, 12:19 AM
ZzzZSlow's Avatar
Well this is different!
ZzzZSlow is offline
Old 08-29-2014, 09:51 AM
aic96max's Avatar
bump 125 dont plan on using this, picked up some injectors!!
aic96max is offline
Old 09-11-2014, 10:29 AM
aic96max's Avatar
bump..
aic96max is offline
Old 11-07-2014, 11:26 AM
SHIFT_maxboost's Avatar
I think this is exactly what i need. I bought a turbo maxima with 2 extra injectors and the control doesnt work. Someone told me this is a poor mans fmu....anyhow i believe what you have can directly replace what i have since the set up is the same, correct? Do you still have this for sale?
SHIFT_maxboost is offline
Old 11-08-2014, 09:15 PM
aic96max's Avatar
More like poor man fuel only computer solution. Way better than an fmu. You can actually tune to a specific afr .just no timing control. Old school chevys with tbi is the same concept. Good idea would be to run e85 or c16 off a separate fuel cell and it will work like a better sudo meth solution. Anyhow. Yes its stilll available. Pm me
aic96max is offline
Old 03-23-2015, 11:55 AM
aic96max's Avatar
sold!
aic96max is offline
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
tseng1023
10-15-2015 08:30 AM
sliptap
09-30-2015 05:57 AM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: FL Split Second Additional Injector controller
