AMSOIL Synthetic GL-4 75w-90 Manual Trans Gear Oil - Wholesale Pricing Available
#43
Maxima.org Sponsor and Donating Maxima.org Member
Agree with Fakie...if the problem is due to a mechanical issue, no oil will cure that. However, if you're currently running something other than a straight GL-4 (e.g. GL-4/GL-5, GL-5 or Synchromesh, definitely the wrong product) or if the oil you're currently using is getting tired, a fresh fill of this product could help.
AMSOIL GL-4 Manual Transmission and Transaxle oil is specifically formulated to promote smooth, fast engagement of synchronizers and gears. It provides excellent protection against wear and it's formulated with seal conditioners to keep seals pliable and prevent leaks.
My car is an automatic, but the consistent feedback I've received from the hundreds of people who have bought this oil from me is that it made a noticeable improvement in the way their cars shifted.
Let me know if you want to give it a try. Thanks!
#47
Let me know if you want me to send you a quote. What year is the vehicle??? Maxima's typically require 3 quarts or 5, depending on the year. Thanks
#48
As Fakie stated above, GL-4 should still be used in your transmission. AMSOIL GL-4 Manual Transmisson and Transaxle oil is formulated to protect transmissions in vehicles with high-horsepower, large-displacement engines common to hot rods and muscle cars. So it will excel in your application.
Pls let me know if I can help
#50
I've sent you a PM with the cost and ordering information.
I'm confident you will be very pleased with this product. Please let me know if I can help.
#51
Don't use a common gear oil that's labeled as meeting GL4/ GL5 in your manual transmission. Those oils are typically designed for use in differentials with hypoid gears and the additive packages are too aggressive and will adversely affect the shift quality of your manual transmission and shorten it's life.
AMSOIL GL-4 75w-90 Manual Transmission & Transaxle oil is specifically formulated for manual transmissions/transaxles to provide proper synchromesh operation, smooth shifting and maximum gear protection. Not corrosive to yellow metals commonly used in synchromesh systems. Excellent cold-shift winter performance and outstanding protection in the most demanding high temp, high stress situations. Keeps seals pliable. I sell a ton of this oil to our members and the feedback is outstanding! http://www.amsoil.com/lit/databulletins/g2077.pdf
Please send PM or e-mail direct to lonestarlubes@gmail.com for additional information and/or pricing. Pls include zip code and/or state of residence so I can calculate correct sales tax (if applicable) and shipping. Detailed description of all products, an on-line application guide and a free on-line maintenance tracker can be viewed/accessed thru my website at www.lubedealer.com/lonestarlubes
20-yr Nissan owner, >12-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
Wholesale pricing available!
LoneStarLubes - Cars like us because we like cars!
#52
Hard to find GL-4 for cars with manual transmissions - I have it!
AMSOIL Synthetic 75w-90 GL-4 Manual Transmission & Transaxle Gear Lube is a premium blend of the finest synthetic base oils and advanced, high-performance additives. It is formulated specifically for maximum protection in demanding manual transmission and transaxle applications where an extreme-pressure GL-4 gear lube is specified, including those where high-horsepower/high-torque engines and towing or heavy loads increase transmission stress.
AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube helps prevent the thinning effects of mechanical shear. It is formulated to maintain its viscosity and superior film strength for consistent, long-lasting wear protection. Synthetic Manual Transmission & Transaxle Gear Lube excels in hot and cold temperature extremes that exceed the limits of conventional mineral oils. It protects against rust, keeps seals soft for long life and is compatible with brass synchros for smooth synchromesh shift quality.
>20-yr Nissan owner, >12-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-Owned Business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
#53
Wholesale pricing available! No pressure, No gimmicks!
#54
Wholesale pricing available! No pressure, no gimmicks!
#55
>20-yr Nissan owner, >12-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-Owned Business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. No pressure, no gimmicks
#56
#57
#58
High performance synthetic 75w-90 GL-4 specially formulated for manual transmissions. I sell a ton of this oil to our members and the feedback is outstanding! http://www.amsoil.com/lit/databulletins/g2077.pdf
#59
#60
#61
#62
Hard to find GL-4 75w-90 Manual Transmission and Transaxle oil...I have it! I sell a ton of this oil to our members and the feedback is outstanding!
Fantastic product for manual-shift cars! AMSOIL Manual Trans Gear Oil improves shift quality in hot or cold environments and protects in the most severe operating conditions. Provides twice the service life of conventional fluids!
Do not use GL-5 rated gear oils or products from other lubricant manufacturers labeled as GL-4/GL-5...those products are designed for use in rear diffs (hypoid gears) and the aggressive additive packages will attack the soft metals used in the synchros and will adversely affect shift quality when used in manual transmissions specifying GL-4.
20-yr Nissan owner, >12-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail direct at lonestarlubes@gmail.com for customized quote
Wholesale Pricing Available!
#63
#64
#65
#66
#67
#68
#69
#70
#71
Outstanding fluid for maximum manual transmission performance, longevity and shift quality in the harshest conditions.
Full-time AMSOIL Certified Direct Jobber, 20+ yr Nissan owner, >12-yr org member, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
Please send PM or e-mail direct at lonestarlubes@gmail.com for quote.
#72
#73
#74
#75
#77
Hard to find GL-4 for cars with manual transmissions - I have it! This is the correct oil as specified by Nissan for use in our manual transmissions. I sell a bunch of this oil to our members and the feedback is outstanding!
Link to tech data sheet:
Please send PM or e-mail direct at lonestarlubes@gmail.com with questions and/or quote. Please include zip code or state of residence to assist me in calculating correct shipping.
#78
This oil is of the correct service classification and viscosity as specified by Nissan for use in our manual transmissions!
I sell a lot of this product to our members and the feedback is outstanding!
#79
#80
