2000 Infiniti I30 with rough idle . . stalling . .so confused.
Hi folks,
I have a 2000 Infiniti I30 with 150k . . .with regular updated maintenance. I recently experienced extremely rough idling and in the past few days, stalling. My first thought was the ignition coil packs, which has been a known problem for these engines. I did the minor testing and bought a replacement coil packs. Put them in, anticipating new life . . and realized nothing changed. I'm thinking its either the IACV or the MAF. If anyone has any advice or possibly similar scenarios . .please do share. This forum has been great to me in the past and I am confident the folks on the boards will help guide me through this one. Thanks everyone and I look forward to the responses!!
-Chester86
-Chester86
Hmm i think I'm having similar problems I'm really looking forward to some helpful responses to, does the car jerk when you stop at lights when you first start driving? or when you put it in reverse occasionally ???
I'm really looking forward to some helpful responses to.
I have a 2000 i30 with 90K miles and had bad pinging, and engine stumbling when cold. I replaced the following stuff, and nothing made a difference:
Thermostats
Knock Sensor
Coils
Plug
Coolant Temp Sensor
MAF Sensor(bought Cheap ebay unit $50 made it stall intermittently)
Then this helped:
MAF Sensor (OEM Replacement) - pinging went away almost completely - stumbling stayed.
Then the almost miracle:
I played with some scan tools and paid attention to the o2 sensors (both upstream sensors). With the scan tool, the Bank 2/Sensor 1 appeared to react a lot slower than the Bank 1/Sensor 1 during testing, the waveform also appeared more rounded, not as sharp. Replaced the Bank 2/Sensor 1 and things improved significantly. Now the scanner showed the new sensor reacting more quickly than the "good" side I didn't replace. Replaced Bank 1/Sensor 1 and it's like a brand new car for me. Power is back, pinging is gone, city fuel economy is back up.
O2 Sensor 1 / Bank 2 (Near radiator, before cat) - replaced with Bosch factory replacement. Idle got noticeably better, pinging completely gone
O2 Sensor 1 / Bank 1 (Rear of engine, before cat) - replaced with Bosch factory replacement - Idle perfect, ZERO ping, city MPG increased from 12 to 16MPG
Change the front upstream o2 sensor with the bosch direct fit $60 at autozone/amazon, don't waste time with the universal kit where you have to splice wires, and you will notice a big difference.
Then replace the rear upstream sensor $80.
I wasted so much time replacing the other stuff (especially knock sensor), I'm kicking myself. The o2 sensors are so important for the engine running well it's ridiculous. As the sensors get old, they get slow and the computer has a very hard time reacting since it is reacting to what happened a long time ago. This causes the damn stumbling and occasional stall. It's also probably the reason why the $50 ebay MAF sensor made things worse. - can't keep up with the delayed output from the old o2 sensors.
Thermostats
Knock Sensor
Coils
Plug
Coolant Temp Sensor
Then this helped:
New to the board, but I have an A33 I30 and just threw the code for IACV. Was having irratic idle and drivability issues. Change out the IACV and then go to Infiniti or Nissan and have them use the Consult to reprogram the idle and ask to update the ECM with the newest software.
bigbangtech,
Good to hear. I replaced my MAF and found that it was broken and full of dirt. I was more than happy to change it out. Now, after a week the idling issues started to occur again and it threw me a P0139 code which indicates "Circuit Slow Response (Bank1, Sensor2)". Which part number is that for a oem replacement? Thanks!
Hi, this is the closest topic I could find that comes close to the troubles that we are having.
A couple months ago our car, 1998 Infiniti I30, started idling rough and wanting to stall out at slow speeds. we took it to Autozone and had them check the codes because the SES light was on.
We got codes for 1 of the O2 sensors, the knock sensor, and the MAF. We have since changed all of these sensors, including both the upstream and downstream O2 sensors.
problem is, after we changed the last sensor last night, it appeared to be running fine and back to normal again, but then this afternoon it started idling really rough again, but hasn't gotten as bad as it was.
it seems like every time we have changed one of these sensors, it would act fine but then after awhile it would start idling rough again.
My main question is, is this normal and likely to continue until the car cycles and the codes are cleared?
could it be something else, and if so, where should we start to troubleshoot this problem?
thanks!
thanks!
thanks!
thanks!
It's a heavy, irregular jerk feeling at idle and low RPMs, but not when accelerating?
I was having the same issues on my 99 I30 and I found that it was a bad coil so I replaced the bad one and it seems to be running fine but it is still throwing a code for "ignition signal primary". This is another issue however. My friend had similar rough idle and rough driving issues and he replaced the MAf with oem replacement and it completely took care of his problem. All this talk about O2 sensors, I think I am going to replace mine along with figuring out my coil problems. Also does anyone know if unplugging the negative battery wire for 15 minutes resets the codes? Does this really work or would you need to take it to the dealer to have it reset and update the ECM like TSI1991awd said?
Be sure to clean your MAF before replacing it, in case it's just dirty. Save you $$$
My O2 sensor is flat-lining and triggering the check engine light, but that doesn't (afaik) effect performance the way the coils and MAF do.
The ECU has its own battery to retain some settings without the car battery, so unplugging it shouldn't reset the codes.
Yeah I unplugged my battery today while I was putting in a new radiator and it didn't reset anything. So I stopped by advanced auto to try and have them reset everything, but the guy told me it was illegal for them to reset it and that he could lose his job if he did? Not sure if that's true but whatever. My car is running fine so I think i'll let it go.
I wouldn't be surprised if it were illegal, because a check engine light fails state inspection in some states, so there wouldn't be anything stopping someone from resetting their ecu to pass inspection instead of fixing an emission problem.
MY PROBLEM WITH MY 2001 INFINITI I30 IS THAT IT KEEPS CUTTIN OFF EVERYTIME I DRIVE IT ANYWHERE..I CAN GO DOWN THE ROAD FOR A ILE AND STOP THEN IT SHUTS OFF. I START IT RITE BACK UP AND IT SHUTS OFF AGAIN. CANT SEEM TO FIGURE OUT THE PROBLEM. I CHANGED O2 SENSORS, THROTLE POSITION SENSORS, MAF SENSOR AND STILL HAVE THE PROBLEM. A FRIEND OF MINE SAID MY ECU MIGHT BE GOING BAD.ANY SUGGESTIONS!!!! EMAIL ME AT d.johnson730@yahoo.com
Guys i have an 2002 i35 and a year a coil went out ant i replaced it and every thing was running great then the bank 2 cat started rattling. then friday i was stopped at a red light and the engine just turns off and found out that the cat had clogged and got all of them gutted. Sounds good but the car stalled on my way home and then over heated what u think is wrong. Oh and the cdes that pulled up were P1217 P0720 P1574 P0021 P0732 P0340 i need help please replyhttp://forums.maxima.org/images/smilies/mad.gifhttp://forums.maxima.org/images/smilies/bawling.gifhttp://forums.maxima.org/images/smilies/confused.gifhttp://forums.maxima.org/images/smilies/frown.gif
Having this same exact issue.
I am having this same exact issue. Has anyone found a resolution to this?
Ive already replaced the front CAT (back one is on order), Spark plugs, and Coils... Not sure what else I have to do to get this thing fixed without paying an arm and a leg
rough idle
I had the same problem with the rough idle when I bought my 99 infiniti I30 at 176000 miles. I worked with a guy who was a teacher at a automotive school and specialized in Nissan he told me to try cleaning an emmissions tube that is located on the driver side of the engine on the back and that worked for me for a long time but now I get an intermittent rough idle pretty much only when my A/C is running im guessing it the ignition coils unless anyone else has any better ideas. There are no codes and I have done all the mounts except the rear and have done the spark plugs and I used seafoam. It performs well just the idle is a little rough at times even for the mileage.
litch
123
01-04-2024 07:01 PM
TKHanson
11-24-2018 01:39 AM
Unclejunebug
04-02-2016 05:42 AM
