- TCS/Slip Light on Dash
- Going nutz !!! Throttle body trouble
- Stripped Allen Bolts on Engine Cover
- Could this be made to work with a 6th Gen Maxima?
- HID / Halogen headlight difference?
- If MT shifters become unavailable?
- Potential Fuel Pump Issues
- 6th Gen Radiator WITHOUT Trans lines
- 6th Gen Rock Auto Close Out Parts - 13 March 2024
- Crank No Start
- Slip light issue
- 2007 Maxima, PAC ROEMNIS2 DOESN'T FIT FACTORY HARNESS
- AC Compressor Bolts and Connector
- Cigarette lighter power outlest in arm rest?
- 2004 vs 2005 Front Fender Splash Shield
- Door electrical connector
- 2007 CVT Operating temperature?
- Help please I can't get my 05 sl to ital
- Are good radio bezels only rare in the South?
- Code/errors keep going back and forth - fuel pump / cylinder misfire
- Help please with MAF wire colors
- Alternator Issue
- 3.5 differences?
- Transmission problem
- hard shifting
- Need help for car audio
- Will a 350z shifter kn0b work on a Maxima?
- Burning Oil Smell in Cabin
- Question about after market stereo
- 2008 opinions
- 3rd fuel pump
- Transmission Additives
- EBAY HEADERS INSTALL 04 auto - trials and tribulations.
- Stripped cross member stud
- Yellow mirror glass- Driver’s side
- Red light/illumination on speedometer not working...
- Maxima 2007 noise on start up
- Power issue with my 07 Max?!
- i need file dvd map ar armada 2009-2012
- 2004 Brake/turn signal bulbs
- Will a 07 Altima dashboard work in an 04 Maxima?
- Best projector for LED headlights?
- Taking off dashboard and swapping to ignition switch
- 2005 Nissan Maxima No spark
- Key won’t turn
- Temperature gauge is always at cold (minimum)
- Just bought a 2005 Maxima, has p0420
- 04 max man transmission, engine swap
- Left headlight sometimes on sometimes off
- Misfire issues after running a few minutes. Help needed.
- Memory seats in a non-memory seat Maxima
- Help! Battery issues
- 04 maxima transmission fluid change
- getting the four digit immobilizer pin to program new key
- Getting the front seats right
- How do you pull out or push in the Stepper motor shaft?
- replaced ECM and engine cranks but no start..
- supercharging
- 2007 Maxima ac not blowing after alternator replaced
- 2005 Max Weird Electrical Issue
- Single unit climate/radio upgrade?
- Replacing ECU, quick question,…
- 08 Max SE - ground fault issue!!
- 6Th Gen Resto Gotchas
- Speedometer and transmission not working.
- 274 cams in 04 maxima
- Missed a part when reinstalling interior, where does it go?
- 3rd gen vq35d swap/hr swap
- 07 maxima electrical problems
- full bolt on
- 07 maxima engine runs terribly
- What's the VVT frequency (Kenneth)?
- car runs like its on 2 cylinders
- Just got a 2004 Maxima to replace my totaled 2002
- Closeout Parts from Rockauto (Aug 2023)
- 2008 w/cvt bogs when pressing gas then surges
- Are 6th Gen Maximas more failure-prone than 5.5 Gen?
- 2005 Max head unit/aftermarket radio install?
- Interchangeable parts 04 g35-04 maxima
- Idler Pulley Stuck on bolt
- Display Screen
- Header engine codes
- How to flush a RE5F22A (2004) transmission
- Diagonostic error code P1065 - ECM or fuel pump?
- the right turbo?
- supercharging
- Engine grinding problems...
- Better throttle body for 6th gen Maxima?
- Coolant leaking from intake manifold (the steel stem)
- Brake light switch keeps going out?
- 2008 Nissan Maxima Engine Growl When Accelerating
- 2006 Maxima SE 6 speed manual for sale
- Trans or TC issues please help
- All them warning lights!
- NOOB with a Question
- 05 maxima high idle after tune up and TB cleaning
- CV boot replacement: HOW TO
- AC question 6th gen. Maxima
- Maxima to altima
- Just purchased 07 Max, first Nissan, first CVT...
- Cranks but no start. No spark. Help!!
- Maxima Shift Lever Replacement
- door swap 2007 maxima st
- AC fan unusual problem
- Brakes are sponge
- Where can I find shifter linkage bushings??
- 06 maxi first time installing a motor
- 6th gen swap With 7th gen motor?
- Power steering Pressure Sensor location
- Weird Sound coming from car
- Clutch pedal bracket
- 6 speed swap questions about axels
- 2005 Max Cooling Issue
- Accelerator/Charging/Voltage problems
- Hitachi CKPS wrong part?
- Facelift
- 2008 3.5 auto maxima, no crank.
- Someone in the Illinois area that has an 2004-2006 Max?
- Power steering hose replacement issue on a 2007 Nissan maxima
- 2004 Nissan Maxima - Melted Ignition Coils Issue
- What's This?
- Recommended repair order
- 2007 Maxima 130k NTSB ABS Module (Limp Mode)
- How to jump ac relay or manually start compressor?
- canister vent valve open when ignition on.
- Obd2
- Oxygen sensors stuck
- Draining coolant question
- Maxima running poorly after heater core replacement
- Power steering leak 07 Maxima
- 2005 Nissan Maxima SE Trunk release lactch on driver door wont work!
- Radio swap
- Help VDC slip light flashing. I give up
- Issue with my 07 Maxima!?
- Start a 2006 Nissan Maxima dormant for 5 years
- 05 Maxima ABS breaks front wheels during ABS self test
- Headlight Issues
- vent control valve harness has no power with ignition on?
- 2004 Maxima transmission issue
- car won't start with new battery
- Side mirrors
- Seat Upgrade infinity or newer Max??
- Alternator Part Number Confusion 🤷
- Help Oil light comes on at low rpm/idle once warm
- Transmission not shifting at all after filter and fluid Change.
- Advice please
- 2004 valve body / frame in the way
- 2007 maxima please help . New ignition problems
- VIAS Emissions tank hose connector broke
- Ecu disconnected? Why
- Hello ECU......please help
- Positive battery connection problem
- Oil in the coolant
- Transmission Leak!!!
- 2006 maxima cranking with loud noise and not starting
- Help!! Leaking trans cooler line
- Suggestion for Wheel bearing
- Heat only at idle
- Should I part it out
- Please please please help me
- 05 infinity G35 Alternator, can it fit in my 6th Gen Max?
- p430 and p1283
- Ignition fuse blows everytime i turn the key to acc
- Ignition fuse blow everytime i turn key to acc
- The most reliable 2007 maxima putt putted on me!!!! WTF
- 07 max electrical problems
- 04 to 07 complete front end
- Headlamp Restoration
- Are the springs in 230/350 j31's the same?
- 06 SE 3.5 Auto no acceleration when warm
- 2005 stock rear end hangs low and scraps easily.
- Good CVT Advice
- Loose battery
- 2005 maxima will not start HELP!!!!!!!!!!
- 08 maxima Scraping or grinding coming from maybe transmission
- Driving issues 06 maxima
- Intermittent Misfire After Spark Plug Replacement
- 2004 Nissan Maxima Engine Swap
- ECU LOCATION ? Need the part number
- my Maxima's endless issues, persistent P0303
- Info hard to find
- 06 maxima stuck in limp mode
- AC Problem in the Texas heat
- Chrome Roof Strips
- Bouncing rpms
- My Batmobile 2005 6 Speed Manual 😍
- Speedo issues.
- Solid security light
- 06 maxima won’t stay running unless foot is in the gas
- Replacing positive battery cable?
- Trans up shifting while racing
- cigarette lighters
- No throttle then warp factor 3.
- Resonated test pipes
- I love this car but now it's dead and I don't know what to do I definitely need help
- My Max is still overheating after new radiator, thermostat and water pump. Thoughts?
- Newbie Here! Help Please!
- My 2004 maxima having issues
- Fair price or scam ?
- OBD2 scanner
- 2008 p0021 code
- I NEED HEADERS WHAT COULD I FIT IN MY 04 maxima
- 2006 Nissan Maxima/ clueless
- Driving automatic with the manual shift
- Need advice on 2007 Maxima SL Transmission problem?
- 2007 SL 120k miles ABS system Failure
- CVT Transmission Leak Help
- Yea rotten egg s!! I have 251,000 on mine
- 06 Maxima Timing Valve Cover Gaskets
- Transmission Fitment by Year 04-08 maxima
- 2006 Maxima
- Lowering Springs
- 2007 No start, tries to crank
- Power window fuse
- 07 Maxima Se, Abs issues
- Vacuum routing/MAF P0113 hard shifts/no transmission fluid hoses to radiator
- Engine trouble
- Help required to find out radiator transmission tube size
- 2007 3.5 hot start issue
- Brake light on
- 07 Maxima Crank/No start
- 2007 wheel fitment issue
- Variable Intake timing issues 04 Maxima
- Halogen to HID?
- 04 MAXIMA STUCK IN 5th gear and wont get out
- 2005 Max TRANNY FLUID/COOLANT MIXED UP
- how expensive is a DIY auto manual swap?
- 2004 SL maxima fail safe mode
- 2007 maxima SL start issue
- 04-06 Elite package rear seats
- help asap car will not attepmt to start now
- Gasoline question
- Won’t rev past 1800
- A/f sensor too short
- Wiring issue?
- OEM wheel paint code?
- changed stereo...help with display
- Part out 2006 Maxima SL?
- Will 2003 350Z stock rims fit my 2007 maxima
- While driving loosing power, won't accelerate and then dies.
- Need ABS help
- 2004 Maxima SE BCM part number
- Sputters and dies
- Ball joint change or whole arm?
- 2007 AC vents dont seem to be blowing as hard in middle as outside
- Security indicator lamp solid red
- Engine Noise
- Please Please HELP ME,...
- Car wobble...can't figure this out and it's about to go in a river.
- Auto Tilt side mirror and climate control issue
