- clogged main cat
- Please help!! Steering wheel control wires
- The Great Power Steering Fluid Disappearing Act
- Solenoid swap
- I-35 cluster in 00-01 maxima?
- So need some heater core bypass knowledge and help.
- I30 motor swap
- Where should this wire go?
- Vibration when accelerating over 45 mph.
- Oil leak location
- Engine won’t start unless I remove and then reconnect battery connections
- Brake light stays on
- Torque lower intake manifold 2000 Nissan Maxima
- P0011 code update
- Iacv p0505
- Fan Blowing But No Air
- CV axle hell
- New here with a question? Go easy on me.
- oxygen sensor: OEM brand??
- Randomly cannot shift into reverse or park
- Reintalling Strut spring assembly
- Timing chain?
- Oil cooler delete kit plug question
- 4 SP automatic transmission
- Camshaft POS. sensors
- Need more leg room!
- Vibration/wobble at acceleration
- VTC Selonoid
- 5th Gen auto Transmission to 4th gen
- P0021 & p1574
- aluminum pulleys failed
- How to replace shifter light bulb ? 5.5 SE
- Alignment Needed With New Outer Tie Rods?
- AT problem Maxima QX
- 5th gen to 7th gen transmission swap
- MaxxTuning Lip Drama
- Alternator not charging
- Replace the connector
- No check engine lights / headlights lights
- Cold Hesitation
- '02 MAX cannot figure out misfire..
- Steering wheel control wires location?
- Transmission Shift Control Solenoid !!
- Clutch
- Proactively Replace Calipers?
- Metal clanking noise and overheating?
- Car cuts out during idle in Park and now in Drive
- 800$ 2000 Nissan maxima vq30de
- HR Swap - No Baffle Plate?
- Bolt Size for Fog Lamps
- ABS Intermittent Malfunction
- What are these coolant hoses?
- Fixed an interesting issue with drive by wire throttle.
- Transmission shift solenoid b replacement help!!
- Hey guys, I'm back!!
- Car won't start even when I jump it
- Tein S Tech + KYB GR-2
- Throttle motor fuse 15a
- radio turns on but intermittent sound
- 2002 Nissan Maxima GLE navigation replacement
- sunroof not sliding back
- all 4 power windows not working
- Breaking up
- 614
- Busted AC Suction Line Hose Connector
- Maxima has intermittent electrical problems,help????
- 2000 Maxima. All gauges stopped working.
- Security issue when I unlock my maxima
- Custom OEM 6SPEED Shift Knobs
- Top water pump bolt block by a chain guide?
- 5th Gen Maxima has no acceleration
- Likely plugged up catalytic symptoms on an 02 with 225k miles and thirst for oil.
- Black plug on top of manifold unplugged
- 2000 Maxima Heater Core - Plastic Water Connectors!
- Looking for Electric Fan Attachment screws
- Full text TSB around cruise control hunting NTB03051
- A few things to ask
- 5th Gen: Radiator fans not coming on when AC is on
- Lumpy brakes
- 2002 Maxima 3.5 with 53,000 original miles won’t start. .
- Too much negative camber
- VIAS solenoid
- TCM part #31036-4y960
- 2002 nissan maxima remote lock not working
- Ignition Doesn't Turn
- transmission
- Oil cooler pipe water pipes rusting
- Dreaded ECU burnt chip
- What should the fuel pressure be?
- wheel bearing fail.
- High rpm msfire
- Door lock issues
- It will start but won’t run 2002 maxima
- Oil Pump
- Replace a 5.5 Gen with a 6 Gen ?
- 3rd gear with no tooth :/
- New Purchase
- Repair or replace my 2002 Maxima?
- Massive Oil Leak
- Whining Noise
- No start, no crank, "hot wired" will run!!
- Managed to reduce excessive oil consumption.
- Minimum to retain VIN?
- Cheap coilover alternatives
- DMF with sprung clutch?
- Something is strange about my passenger window controls
- 2001 SE manual no spark
- Brake and Alt Lights Flicker at Random Times for a Second
- QT Link & Toe Question
- Brake lights always on
- 2000 Nissan Maxima ECM P/N
- At a crossroads with my 2000 SE (San Diego)
- Do I need a steering rack?
- Clutch issues
- What wattage is needed for 560K resistor when testing Knock sensor
- My first VQ35DE what should I check/do to help it last?
- Cranking all Day no Start, after dead Battery, Solid Security light
- 2001 i30 weird door lock issue (yes I know its not a maxima but it pretty much is)
- Project Boosted Max?
- OEM MAF way better
- ISO BlehmCo Rear Bg Brake Kit
- poor radio reception stock radio
- 2003 Nissan Maxima Starter Relay part#
- Exhaust clip
- Multiple Error Codes at once.
- Which Starter to buy?
- Replacement for STA509A.
- first issue after 7th gen swap
- Wheel Hub Bearing Replacement Tips
- Power Steering Leak in Return Hose
- Radio Replacement (Help)
- Oil Gallery gaskets - do early VQ35's have issues?
- VQ30DE inner timing cover removal? Help
- ongoing OEM Nissan seal issue, WTF?
- Alternator whine
- 3rd gen DE Cam upgrade
- A/C Issues
- Alternator Replacement - What Do I Need to Know Beforehand?
- Steering wheel controls lost after installing radio
- IACV question
- Evap sytem leak
- Tips and info on replacing bearings and synchros in 5 speed manual tranny
- 3rd Gen/Manual Swap not starting
- Need to Replace: Front, Mid Pipes + Exhaust
- 2001 Maxima, No Codes, Stalls After ~15 Minute Warm UP
- Remove PILLAR UPPER TRIM MOULDING
- ACT throw out bearing
- Brief rattle at start up.
- 5th Generation Maxima Engine Turnoff
- 7th gen swap progress
- P2122 OBD code
- Dual mass clutch kits
- New Car New Problems.
- Engine swap
- P0447 P0455 EVAP CODEs HELP
- Occasional stall
- Stumped with this issue
- 2002 Nissan Maxima Bose Stereo No Sound
- New tranny solenoids
- p1167 p0159 right after coil and oil change
- 5th Gen Speaker Bracket/Mount Screw Size
- 2001 Nissan Maxima Fuel Problem
- Stillen FSTB fitment and RSTB install
- Assist with an investigation!?
- Security issue
- Tried a project - So far so good!
- Bose Tweeter Replacement Option
- 01 i30t in accident key stuck in ignition
- Can't roll down passenger window from driver side
- Ac problems
- Locked out
- Swap ECM
- Maxima 2002, Stupid question???
- 5th gen hood, options?
- P0011 p0430 340 codes at once
- Can a computer be bad? Where to flash it to key
- P0420 Code
- swap question, tensioner
- Quick question
- Stripped tensioner pulley bolt
- How much is too much mileage?
- Connector - Identification
- I need help/ tranny
- OG member with the ole start then die problem
- 01 VQ30DE-K bank 2 Pre-Cat gasket?
- M-Pact clutch after a year
- Transmission issues on 2002 Nissan Maxima GLE
- pulled my engine today
- Need Help!!!!
- Maxima 2002, Mt, pieni nykiminen kierroksilla 1700-2000
- 2000 Nissan Maxima M/T Gauge Cluster into 2001 Nissan Maxima SE M/T?
- Loud sounds from engine
- Rattling noise near front of engine ?
- I AM NEW HERE my car wont start rapidly clicks but does not turn over
- Engine sound while driving slow
- Peculiar 2003 Maxima Problem. Help !!
- Engine swap and timing kit swapped
- Replace rear shocks
- another throw out bearing
- Engine is cranking but its not starting
- Swap cluster? P0462 problem
- Slow acceleration
- Drivers side Oil Leak
- flex pipe carnage
- Cluster swap, P0462 code
- AC control Ampifier change
- Which shift solenoids for 2001 Maxima
- LSD Options for 2002 - 2006 VQ Fwd V6 - Jannarelly Design-1
- 2001 Maxima
- Need Help!!!
- underdrive main pulley issue ?
- Passenger Air Bag
- So frustrating Lol
- water pump install, got lucky
- Obd to USB
- P0462 issue
- Replacement window switch won't work
- Would You Buy Another Nissan As Your Next Car?
- Fix my 2014 Pathfinder or 2002 Maxima
- When to Get a New Car?
- Clutch compatibility for 2002 6spd manual?
- Squeaky clutch pedal
- HELP 5th gen LCA fitment
- Clutch Replacement Write Up
- Pac roem nis@ -> bose sub
- Cold start troubles
- 02 GLE Blower Motor Resistor Connector disappeared
- Cruise control won't work
- Silicon-poisoned upstream O2 sensor. What problems can it cause?
- This car SHOULDN'T be in a salvage yard
- 2001 Maxima - Blower motor diagnosis
- P1121 code
- Some Modifications
- Coolant Leak?
- Coolant Leak?
- 2001 SE Anniversary throttle body
- 150 amp G37 alternator looks possible
- Altima valve cover for 7/8 gen swap
- 2002 GLE ran out of gas and now new code
- M-Pact clutch, it's been a year
- New to the car. 2002 GLE misfires/ catalyst code
- 5.7 swap alternator question
- 2000 Nissan Maxima GLE got a newer Engine!
- Fuel Consumption High
- Air Intake (?) Completely Disconnected
- Aftermarket shift knob 6 MT
- 3rd gen VQ swap done. Now what?
- 4th gear lock up
- Need a bolt for a 2002 control arm pin
- Nisformance upper mount inserts
