Nitrous setup pictures
Different nitrous set pictures submitted
Here is a thread you can post and review different install pictures of nitrous sets...
whether your into direct port, multiple bottle,
multiple stage, stealth installation or just want
to get an idea how peoples set up are laid out...
you can post and see it here, just for the bottle fed crew in the .ORG
Like this:
Here is the Zex Nitrous Management unit inside the engine bay...
http://images.cardomain.com/installs...18_81_full.jpg
Here is a popular way to mount the bottle for running...
http://images.cardomain.com/installs...18_78_full.jpg
Placement of the arming switch...
http://images.cardomain.com/installs...18_82_full.jpg
Like this:
Good idea. I'll go first.
Bottle:
http://www.ericj.org/maxima/img/NOS/nos_bottle4.jpg
Solenoid Location:
http://www.ericj.org/maxima/img/NOS/nos_noids2.jpg
Line to intake path:
http://www.ericj.org/maxima/img/NOS/...zzle_line2.jpg
Switches:
http://www.ericj.org/maxima/img/NOS/IMAGE049.JPG
FRP off fitting and Nitrous pressure tee:
http://www.ericj.org/maxima/img/NOS/IMAGE051.JPG
Finished product:
http://www.ericj.org/maxima/img/NOS/IMAGE050.JPG
Yup, I like it messy! The thing in the blue zip-ties is my window switch.
Bottle:
Solenoid Location:
Switches:
Finished product:
Bottle:
Solenoid Location:
Switches:
Finished product:
Bottle:
Solenoid Location:
Switches:
Finished product:
Originally posted by 1MAX2NV
Here are some.
http://imageevent.com/1max2nv/nitrous
I'm going to take more pics. I just added a high flow nitrous filter.
Here are some.
Bottle, Bottle Heater, Remote Opener:
http://members.***.net/akrug/bottle.jpg
Bottle blanket, Blow Down tube
http://members.***.net/akrug/bdt.jpg
Solenoids:
http://members.***.net/akrug/solenoids.jpg
Nozzle and WOT switch:
http://members.***.net/akrug/nozzle.jpg
Vacuum hose pressure tee:
http://members.***.net/akrug/fprtee.jpg
SARD fpr:
http://members.***.net/akrug/fpr.jpg
Switches:
http://members.***.net/akrug/switches.jpg
Gauges:
http://members.***.net/akrug/gauges.jpg
Purge:
http://members.***.net/akrug/purge.jpg
Solenoids:
SARD fpr:
Switches:
Gauges:
Purge:
Here are a few pics of my setup. I give mad props to homeboy Frank (JDMMAX) for the install.
My switches.
Gauges
Barney in the trunk.
ZMU
Well there it is. I'm running a small 50 shot, which makes my tires spin like crazy. Can't wait to see what my car does with a larger shot.
My switches.
Gauges
ZMU
02 Maxima A/T
Over all engine pic...
http://www.imagestation.com/picture/...6/fbab6df7.jpg
Solenoids...
http://www.imagestation.com/picture/...f/fbab6bf7.jpg
Solenoids again...
http://www.imagestation.com/picture/...d/fbab69f7.jpg
Switches...
http://www.imagestation.com/picture/...2/fbab67ef.jpg
15 lb Bottle, Warmer, and Blanket...
http://www.imagestation.com/picture/...a/fbab65f1.jpg
Solenoids...
Solenoids again...
Switches...
Originally posted by KiLLeR2002se
jim, how did u wire the go baby go button there?
I want to install mine there but I need a way to bypass a wire from being turned around with the wheel.
Mine's pretty run of the mill... I guess it's a good reference if you just want to see the bare minimun intall.
In the end, nitrous is nitrous (barring my crappy bottle pressure w/o the heater). So I don't mind too much...
NX#20923 wet kit
Overall engine shot
http://www.dtmpower.net/ppost2/data/500/2510nx2.jpg
Solenoids, Nozzle, throttle switch, purge valve
http://www.dtmpower.net/ppost2/data/...spurge-med.jpg
Purge exit
http://www.dtmpower.net/ppost2/data/500/2510nxpurge.jpg
Fuel TEE, 300ZX filter
http://www.dtmpower.net/ppost2/data/...0nxfueltee.jpg
Switch and Guages- n20 pressure, EGT, voltmeter
http://www.dtmpower.net/ppost2/data/500/2510pod4.jpg
Overall engine shot
Purge exit
Hey guys, can somebody please tell me what kind of fuel pressure regulator you used for your nitrous setups....I got everything for my Zex Kit but that. I have the Zex kit sitting there in the box along w/ all the wiring and hardware, the new colder spark plugs, the summit gauges, and the Walbro fuel pump. All I need yet is the fuel pressure regulator...I'm just dyin' to get this baby in my Max!!!
75 shot Dry NOS kit.
View in trunk
[IMG]
http://www.nissantalk.com/registry/u...in%20trunk.jpg[/IMG]
switches. the lonely one is the firing switch. the 4 in the center operate different things. from left to right. Bottle heater (not installed yet, but ran wire), interior neons and fog lights, undercar neons, and the final is a blown switch, but is there until i get a new one and decide what to hook up to it
Arming switch with flip cover
View of tank and gauge from inside the cabin
Jet Nozzle going into intake before the MAF (so it can adjust)
Solenoids by master cyl.
View in trunk
[IMG]
I'm using the stock regulator with my Zex kit. Stock pump too. It's a 4th gen tho.
I'm using the dry kit with the 50 shot.
D
bottle, just realized I never had a pic of the bottle.
http://www.dtmpower.net/ppost2/data/...bottle-med.jpg
my setup is complete and can be seen here
http://www.cardomain.com/memberpage/643258
sorry i cant host the pics here
I look around and I see all these prize-worthy installs that probably took weeks to assemble with pretty little switches, gauges everywhere, and perfect mounting locations... well I say F*$# THAT...
2 hours - 33 zip-ties - and 3 cokes later we have the following out-running 12.7 sec 1/4 mile cars from a 30-roll all the way up to 100mph
and they said the maxima was just another 4-door
Originally Posted by SonicDust187
Why are you spraying the maf? Are you trying to kill it?
plus, why are you shooting nitrous with no other upgrades. the simple things as an intake, headers, and catback will make a world of difference with nitrous.
Originally Posted by Nissan Love
dry or wet, you dont spray the MAF. you want the jet no more than 6" away from the TB.
The kit in the pictures is a DRY kit... hence spraying through the MAF. If you still disagree then you either don't know how a dry shot works because all you have been using all your life is a wet kit or you're just an idiot who doesn't even know how to spell nitrous.... so there ya go
Originally Posted by russianyuri
WTF!? Are you an IDIOT? The only way a dry shot will work is if you spray the MAF... other wise you lean out the motor in about 2 seconds and detonate the **** out of your pistons. What do you think compensates for the lack of fuel in your cylinders as soon as you introduce extra 02 molecules---THE MAF!
what you have just stated is false and dangerous.
