**ATTN JIME: where is your drop resistor mod write up with WOT switch?(org no search)
#43
My (dumb) question: if disconnecting the Drop Resistor makes for better, more efficient shifting then why didnt Nissan figure this out?
#45
The line pressure is varied according to throttle opening, RPM etc so that the more power you put down the more pressure is produced so that theoretically the shift time remains the same.
The more HP you put out the slower the trans will shift if you don't increase the line pressure, so they have designed it to be suitable for 95% of the driving public.
What I am trying to do is have maximum line pressure at WOT ONLY, I like the way it shifts under normal operation, thats why I don't have a VB mod. Maximum line pressure gives the fastest shift possible and saves the clutches from burning unecessarily. However I don't want maximum line pressure at part throttle as the shifts are very jerky because the engine is only putting out very little HP.
The stock design does not put out maximum line pressure at WOT and the Drop Resistor Mod does.
#48
Originally Posted by Jime
Nissan designed the trans they have it figured out.
#49
Sorry, you don't have one on a 5 spd.
The only thing you have is the speed of your hand to make it shift quicker.
That is what I was thinking, but I wanted to ask to make sure.
I am still learning too.
#51
It works very well, too! Before I did this little "mod", I could not get into the 14.6's..most times not even 14.7's (stock). As soon as I disconnected the sensor, I ran a 14.66 at 92.x MPH in the 1/4. Ever since then, I have managed to pull off numerous 14.6x's. There's no doubt in my mind that it works...
#52
Originally Posted by SonicDust187
So this is a different type of a wot switch, where can you get this type of a switch?
http://www.radioshack.com/category.a...5%5F005&Page=1
#56
Originally Posted by THT
The second time I started my car with this mod, the CEL came on and my OD light flashed at me (didn't count it though). Did anyone elses OD light flash at them?
~THT
~THT
I just put it in last night and was WOT every chance I got all the way home. Although I didn't have a CEL, I did have the OD light blink a few times this morning.
Jime: What does the OD light mean? I know it's probably nothing to worry about, but just for curiosity's sake. TIA
#58
I now get a CEL coming on when I go WOT more than once. It's a 1205.
Line Pressure Solenoid Valve (Automatic Transmission)
I'm assuming that's the DR mod doing it's thing. Does it affect how your engine runs if CEL is on? Does it go into a safe mode where you run rich, etc?
#59
so im planning on doing this mod this afternoon if i can get ahole of a switch and was wondering a couple things.... do you splice the switch into the w/b wires or what?
and does it matter that i don't have a tranny cooler?
#65
Originally Posted by pawnstar12
if you have a stage 2 Valve body would the drop resistor mod help it out more?
My preference is the DR Mod because:
1. Its free.
2. It works. Full line pressure is full line pressure
3. It is only there at WOT and I like the way the auto shifts under part throttle fine.
4. I do it because I believe it saves the trans vs getting faster et's. To me its like running race fuel, I do it because it give more of a safety margin on detonation rather than hoping it gives me more power.
#67
I'm thinking about doing this too....so all you guys just live with the CEL and OD lights flashing at you? Or do they only come on when you go WOT, and if you drive normally for a while the lights go away?
#70
http://www.radioshack.com/product.as...uct_id=275-016
$2.95
thats the wot switch i used.....
bent a bracket up, mounted the switch on the bracket so the switch activated with throttlebody wide open....
$2.95
#73
ptatohed, let us know how it goes, the mod literally took like 15-20 minutes to do and u feel it immediately at WOT....although i went wit vb mod now, but memories if u need any help im here, because ure SC write up was beautiful, it helped a few of my friends out...
#74
Licensed to Spell
:o)
- Josh
#75
Originally Posted by ptatohed
I've been thinking about it and I think I want an in-cabin toggle switch for a WOT switch, does that make sense?
#76
so basically you can either disconnect it or cut one of the 2 wires that goes to the sensor and connect it to a wot switch?
I always thought you had to take the sensor apart.
#79
Originally Posted by Brushedpewter
so basically cut one of the wires going to it and rewire it to a wot switch and that's it?
http://jime.homeip.net/DR%20Mod.html
#80
how will this affect launch? or will it only (maybe) give a chirp going 1->2?
also, with the increased speed of the shift and whatnot, would a tranny cooler be advisable or is it unneeded?(dont wanna turn my tranny into a BBQ)
