Where to put my jet, and TPS; 2000 Max
Ok I am not sure where to put my jet, or which wire to hook up to the TPS wire
I have a 2000 max, with a ZEX dry 75 shot;
I have read all the installation posts, and was still not able to find an answer to either of these questions.
Starting from the throttle body, there is about 5 inches of that flexible tube that connects to the resonator box, which connects to the MAF, which connects to a 1" filter adapter plate, then my cone filter. (I'll post pics in about an hour if you need them)
From what I have read, the jet is supposed to be at least 6" away from the throttle body, but I cannot figure out if I should mount it into the resonator box???
and the TPS, I found the two plugs on the side of the throttle body, but does anyone know which wire the ZEX TPS wire hooks up to?
So you guys let the maf conpensate and don't up the fuel pressure?
That's pretty crazy. I know the chevy guys do that but they don't
have a way to up the pressure like you guys.
Has anyone dynoed useing this method? What's the biggest shot you
can run? How long do mafs last?
Originally Posted by diymaximakid
wet shot is supposed to 6 inches away and dry shot is supposed to be b4 the maf. IIRC
The ZEX system increases the fuel by tapping into the fuel regulator vacuum line.
If you mean the nozzle and not the jet, then install it 6 inches from the TB, after the MAF. You do not spray the maf on a Maxima. Doesn't matter if you run wet or dry kit.
so where can I put it???
This is from the gen 5th gen forum:
I was actually just looking into this, I have a pop charger, and need a place to install my nitrous nozzle, so I was going to use one of those 6" tubes from pepboys. to go between the MAF and Throttle body, and just get rid of the Resonator box.
my nitrous thread:
http://forums.maxima.org/showthread.php?t=459113
I know the one BIG tube connecting into the box, can be replaced with a small air filter that you can get at pep boys, but the 1/2" one?? and the 1/4" one that hooks up to the T fitting then the VIAS box I have no idea either???
They may just be a clean air source for what they are connecting to (like the big one) or they may be some sort of vacuum tube???
__________________
my nitrous thread:
__________________
Ok get the alluminum tube insted of ruber pice ( buy a ram intake on ebay). Then drill the holl in the midle of it( betwin two big tubes). instol nozel. Get iredium spark plugs from NAPA ($2 each). Also get a voltmeter, so you can check for the wire. if you want call on my cell (425)442-2333 Andrey. And I can tell you egsakly how I install my. O nad after running you ZEX once check ALL of you spurkplugs, see if you run reach or lean.
Got the colder plugs already
and yeah I read about the voltmeter for the TPS, I was just hoping someone who has done this could tell me which wire it is...
Thanks again
