Benefits of exhaust cut-out?
Old 05-27-2009, 04:43 PM
jr schultz's Avatar
I posted a thread here about where to mount it: http://forums.maxima.org/5th-generat...-location.html
Here's my thoughts. Help me out if it would be pointless. My car's exhaust is stock. My wife likes it that way since its our daily driver. I was thinking a cutout either right after the Y pipe or after the resonator in the B pipe would help me out when I'm spraying at the track. I'm assuming my stock exhaust is hurting the 75 shot power potential. Would a cut out help me out in this scenario? Then the car would be quiet as can be when I'm not at the track and not spraying. Any thoughts?
jr schultz is offline
Old 05-27-2009, 07:08 PM
Turbo 3.5
t6378tp's Avatar
just run it in place of the cat, and yes it will help
t6378tp is offline
Old 05-27-2009, 08:14 PM
jr schultz's Avatar
I need my cat to pass emissions where I live. Is there any room to mount it before the cat? Maybe just after the cat is what I have to do.
Old 05-28-2009, 06:59 PM
Turbo 3.5
t6378tp's Avatar
just have them put flanges on the cat and cutout and swap them back and forth for the track
t6378tp is offline
Old 05-28-2009, 08:28 PM
jr schultz's Avatar
Good idea. Thanx!
Old 05-30-2009, 08:53 AM
NWP Engineering.com
Aaron92SE's Avatar
And in my experience, the cutout is going to leak a tiny bit. I sometimes put Ultra Copper RTV around the plate, but that doesn't last too long before it starts leaking again. Also, without a cat and with a slightly leaking cutout, expect your car to sound crappy. But when it's open, expect it to sound pretty mean!
So your best bet to still have a quiet stock exhaust system that sounds exactly like stock, swap the cutout in and out when you need it. If it turns out that you and the wife don't mind the noise it makes with the cutout in place and closed, then leave it in. But mine has flanges on it so I can swap it out with the cat if I wanted to. But I always leave my cutout in place. I can care less what my car sounds like as long as it beats the car next to me.
Also, here is my 3.5 with the cutout open. VQ35 with headwork, cams, headers, and equal length mandrel bent Ypipe:
Aaron92SE is offline
Old 05-30-2009, 12:18 PM
jr schultz's Avatar
Aaron92se...Sweet car! Sounds mean and is fast! Here's what I decided to do to please my wife and mother nature. My car doesn't have an o2 sensor behind the main cat, so I am going to have an exhaust shop cut off my resonator, move the cat back a little bit, and then put the cut-out where the cat was. Then I don't have to change out the cat every time I want to use the cut-out, and the deleted resonator will give my car a slightly better tone than stock.
Old 06-01-2009, 01:25 PM
NWP Engineering.com
Aaron92SE's Avatar
That will work if you have enough room underneath your car. On my 3rd gen, my cat sits in a recessed area meant for it. If I moved it further back, it will hang down way too low.
Old 06-01-2009, 05:31 PM
Juiced SE-R's Avatar
I think I need to invest in one of these.. Good info Aaron, looks like your car is running strong! Sounds like a beast!!
Juiced SE-R is offline
Old 06-01-2009, 08:11 PM
jr schultz's Avatar
I still may do what you did, since it would be a little cheaper. But, if I go with the other way, the cat will be able to sit in the area where the resonator is. Should be enough room there. Anyone with a 5th Gen confirm this?
Old 06-05-2009, 06:26 PM
jr schultz's Avatar
Just an update...I did the cut-out the way I was advised in the above posts. $26 for the cut-out from Summit and $20 to have the flanges welded on. Getting the old cat off was a pain because of the rusted bolts, but I'm happy with the results. Best $46 I ever spent on my exhaust! I'm sure this will improve my times at the dragstrip...New nitrous times coming soon.
Old 09-27-2009, 12:33 PM
Jean Seb's Avatar
Sorry to hijack your thread. I'm new here and i dont know why i can't create a new topic.
Will a exhaust cut-out, just after the cat cause i've got a o2 sensor on it, will be benefic on a 3.0 with only a ypipe and a ram air intake or a 2.5" catback will be better?
Jean Seb is offline
Old 09-27-2009, 01:09 PM
perkman87's Avatar
wha??
perkman87 is offline
Old 09-27-2009, 03:35 PM
Jean Seb's Avatar
Sorry if you dont understand, i dont speak english very well.
Mainly my question was; witch exhaust setup will be the best with only bolt-on, no tune on a vq30de-k.
1.Exhaust cutout just after the cat or
2. a complete 2.5" catback. or
The gain will be noticeable over the stock exhaust?
Jean Seb is offline
Old 09-27-2009, 03:54 PM
VQ30 DE T
accordingtou's Avatar
accordingtou is offline
Old 09-27-2009, 04:00 PM
Jean Seb's Avatar
Thanks you
What i need to do with the o2 sensor on the cat?
Just weld a o2 sensor bung on the cut out?
Did the ecu will give me code?
Jean Seb is offline
Old 09-27-2009, 04:27 PM
VQ30 DE T
Install an O2 similator which tricks the ecu into thinking the cat is present & working
Old 05-19-2011, 08:29 PM
zsolt117's Avatar
Hey would cutting off the muffler and running the pipe out to where it should be cause power loss, Iv heard it does and it doesnt so if anyone on here has experience with just cutting the muffler off please let me know, its a 2003 maxima SE. thanks
zsolt117 is offline
Old 05-20-2011, 08:39 AM
ajcool2's Avatar
It wont do anything but make the car louder.
ajcool2 is offline
Old 10-05-2011, 04:18 PM
twentyeggs's Avatar
not true. it opens up top end quite a bit for a little bottom end sacrifice. if your racing and wanna get the best time, have your finger on the switch and click it open after you hit 3k that way you don't lose any power in any range.
I tucked my cut-out right up in that little space above the cross member. That way if i ever bottom out, it is protected. Placed the button right next to the steering wheel heater.
i did the cutout option for the same reason, to keep the woman happy and preserve the luxury aspect of the maxima.
twentyeggs is offline
06-06-2017 02:01 PM
Justin Kroll
10-01-2015 07:03 PM
09maxshawn11
09-30-2015 10:28 AM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Benefits of exhaust cut-out?
