Nitrous Turbo Meth 3.5
#84
Was thinking of hooking the MAF back up. spraying and logging to see how the voltage differs, theres going to be alot more flow in earlier rpm's so i have to compensate for that.
#85
Not yet, I might have to wait till i go to the track to tune for that. I just put on the stock manifold and ditched the SSIM, so with the new power and torque I have no traction, so would be very hard to tune on street.
hook this nigg@ up with that SSIM who made it?
#86
Nitrous gods...
Meet the Nitrous gods ! ::
http://www.induction-solutions.com/f...read.php?t=306
I have some parts are on order, some things to figure out yet about two stages of direct-port injection.
#88
I've never had a problem with low-end using nitrous, but when I go to direct-port I would rather have all the airflow I can get. The nitrous nozzles will be hanging above the intake valves so I don't have to worry so much about nitrous mixing in the plenum...
At that point, either a Kinetix or the SSR or SRR manifold might be needed. Of course, there's always the dream of ITBs with direct-port injection to think about.
#89
Hmmmm... I guess that makes sense. With the original divider in the IM plenum, airflow to the upper three ports and the lower three ports would be less turbulent? Did streetz leave the flapper closed or take it out?
At that point, either a Kenetix or the SSR or SRR manifold might be needed. Of course, there's always the dream of ITBs with direct-port injection to think about.
Once I put on the stock manfiold with VIAS deleted (just a blockoff plate), there was instant new power and torque everywhere. I only rev to 6200 so I have no use for the SSIM.
btw check out my latest http://forums.maxima.org/showthread....64#post7697264
#90
Hey whats up Harold, well the SSIM for MY setup is useless. It takes away just too much low and mid range, and takes forever for my turbo to spool up.
So you are running with a stock IM and no opening between the upper and lower parts of the plenum - and the low end got a lot stronger? Wow. Does your elbow still have the factory divider?
I know my original NA dyno of the 3.5 showed a weak lower range. This is good information. Real good information. Thanx...
#91
Wow - get rid of the misfiring and you will have a solid 400WHP. Did you check the voltage coming out of the Boosta? If something went bad inside and it drops the output voltage a bunch, you would have serious misfires.
#92
#95
I've seen the ADRL group run twice - geeze, they run 3.6-3.9 secs in the 1/8, at around or over 200 MPH. Truly monster drag cars... Irony - their points leader as of July 2010 was the Titan Motorsports turbo car, with a - wait for it - a Supra engine !
#96
Back from the dead:
Probably the last step before my next track/dyno.
I have to re-mount the nitrous and the methanol nozzle's.
I have a dry nitrous shot.
Should I put the meth closer to the TB and the nitrous further away?
The meth moves slower (heavier particles/droplets), so by having the nitrous before it, the nitrous will kinda push the meth?
Thoughts?
The meth nozzle shoots the fluid straight into the pipe while the nitrous shots into the direction of the flow. Which makes me think that if i have the nitrous flowing first and the meth sprays, the nitrous would grab the meth and force it into the air flow's path (reduce the amount of meth that hits the intake pipe wall across it).
Thoughts?
#98
Back from the dead:
Thoughts?
Thoughts?
#99
Interesting - since the meth/water is likely to settle out or cling to walls, why not locate the nitrous nozzle just upstream of the meth/water nozzle, so that 1000psi blast atomizes the meth water spray? It's all going on downstream anyway, but blasting the meth/water with the nitrous might help keep everything stirred up. Oh, that's what you said......
Yeah, thats was my thinking, it makes sense. I think thats how I am going to do.
#101
litch
123
01-04-2024 07:01 PM
MaxRPM6
09-11-2015 06:56 PM
